[Exchange 2007] Installatieproblemen
  • 539 views sinds 30-01-2008
Dag Tweakers,
Ik ben bezig met het installeren van een evaluatieversie van Exchange 2007, louter om even te kunnen kijken wat voor mij de verbeterpunten inhouden..
Tijdens de installatie krijg ik echter de volgende melding:
Summary: 5 item(s). 1 succeeded, 2 failed.
Elapsed time: 00:00:45
Organization Prerequisites
Completed
Elapsed Time: 00:00:33
Hub Transport Role Prerequisites
Failed
Error:
There was a problem accessing the registry on this computer. This may happen if the Remote Registry service is not running; it may also indicate a network problem.
Iemand al ervaring met dit probleem?
Ik heb gechecked of de RR service draait en dat doet hij..
Mvg,
Luke
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Welke virusscanner enz gebruik je allemaal? En wat zie je allemaal in de eventlogs en de logfile van exchange-install?
Mijn spoorwegfotografie
De setup van exchange 2007 maakt een groot aantal log files aan, kijk daar eerst eens in:
Van http://www.microsoft.com/...cles/e2k7setuptopten.mspx
Even with all the robust and user-friendly prerequisite checking in Exchange 2007 Setup, it is possible that Setup could hit a snag and fail. To troubleshoot Setup, use the log files located at %systemdrive%\ExchangeSetupLogs. You will see several log files in this directory. The most relevant is the ExchangeSetup.log file. To find out where Setup ran into problems, search this file for "[ERROR]".
Other files in the ExchangeSetupLogs directory include the following:
• *.msilog files. These files include additional logged information about specific parts of the installation.
• *.ps1 files. These files are Exchange Management Shell scripts that Setup calls during the installation. To view where in the installation process each of these scripts was run, search for the file name in the ExchangeSetup.log file.
• Prerequisites check logs. These logs are located in the PreReqs directory, which contains logs and data files from the Setup prerequisite checks. These filenames all start with "ExBPA" because the prerequisites are checked by using the engine from the Exchange Best Practices Analyzer Tool.
In de normale log vind ik dezelfde melding:
[6-1-2007 16:36:38] [1] [ERROR] There was a problem accessing the registry on this computer. This may happen if the Remote Registry service is not running; it may also indicate a network problem.
In de andere logs zie ik verder geen buitensporige meldingen staan..
Ik gebruik trouwes verder geen virusscanner en/of andere programma's, het is gewoon een servertje dat even vrij was waar ik een evaluatieversie van server 2003 r2 (SP2) op heb gezet en nu een versie van Exchange, echt alleen om even te kunnen zien wat het allemaal inhoud..
  • sanfranjake
sanfranjake
(overleden)
De remote registry-service draait ook?
En file/printersharing. TCPIP netbios helper enz enz?
De services draaien allemaal jep
  • sanfranjake
sanfranjake
(overleden)
Ook al op je domaincontrollers gekeken of zich daar misschien wat problemen voordoen? DNS verkeerd oid (doe even een ipconfig /all van de exchangeserver en de dc's). netdiag, dcdiag...
  • Gamerkoe
  • Laatst online: 26-11-2025
Bij het installeren van Exchange 2007 SP1 op mijn 'Home Server' krijg ik problemen. Ik draai hierop Server 2008 (Windows 2k8) en heb hierop de AD geinstalleerd. Exchange waarschuwt mij al dat dit niet lukt in de standaard manier, omdat de MSExchange services niet automatisch start (dit is voor mij wel te overleven), Bron.
Ondersteuning - Volgens verschillende websites is Exchange 2007 icm Server 2008 niet mogelijk, maar de SP1 versie van Exchange moet dit wel voor elkaar krijgen. Bron1, Bron2.
Installatie - De installatie gaat een check uitvoeren of Exchange te draaien is. Hier geeft de check al aan dat ik geen (DHCP & )DNS server draai, maar ik kan voor het versturen van e-mail wel een relayserver gebruiken. Misschien verkeerd gedacht, maar dan heb ik toch geen DNS nodig (voor DNS resolving!!)?? Ik bedoel dit icm, uiteraard heb je wel DNS nodig voor het internet e.d..
Setup - De setup faalt bij het opstarten van de services voor de roles, de HUB transport (waar is deze eigenlijk precies voor :? ), Mail role EN Client Access role. Bij het opnieuw proberen van 1 van deze roles gaat het ook mis en kan de service niet opgestart worden.
Om toch 1 en ander te proberen heb ik toen de server opnieuw opgestart wat vervolgens nog meer problemen geeft. De Server Manager start op, maar krijgt bij het verkrijgen van data (Data Collecting) niks meer in beeld, dit gaat in een aantal gebieden verder bij 'Roles' of 'Features'. Kijkend naar de services (na de herstart) dan duurt het opstarten van de Exchange services ERG lang. De System Attendant & Transport staan op 'Starting' en blijft minimaal 30 min zo staan. Een paar dagen daarna gekeken is Transport nog steeds aan het opstarten en is de System Attendant inmiddels wel op de status 'Started' gekomen.
Ik heb de MSExchange.org howto gevolgd, maar toch gaat het mis. Kan het probleem zich nu echt vestigen in de DNS (/DHCP) role die ik niet geinstalleerd/gebruikt heb? 8)7 |:(
Gaat straks de Windows Backup Feature uittesten en naar het punt vóór Exchange installatie ;) :)
20x SF170s + SMA SB3000TL-21 | PV Output
  • SneezyThunder91
  • Laatst online: 15-03 14:14
Voor exchange is zeker wel DNS nodig. Het draait in een AD omgeving. Hoe moet anders je exchange server met je dc praten en weten welke users etc. er zijn?
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Als je AD hebt dan heb je ook DNS. DHCP heeft er niets mee te maken, maar het feit dat je het steeds noemt wekt de indruk dat je niet precies weet waar je het over hebt.
Begin anders eens overnieuw en gebruik de howto die ik hiervoor geschreven heb: http://jetzemellema.blogs...ange-2007-in-windows.html
Als je nu ergens vastloopt, geef dan de exacte foutmelding.
  • SirDarkAngel
  • Laatst online: 10:46
Draai je de setup vanaf een remote session of vanaf de console? Onder welk useraccount voer je de installatie uit?
Check op de NICS of je file and printer sharing geinstaleerd hebt. Als je meerdere NICS hebt op allemaal bekijken.
Wilde altijd al iets over computers weten
En bekijk je setup logs ook eens voor Exchange.
  • Gamerkoe
Het is me wel gelukt met installeren toen ik de DNS server heb geinstalleerd!! Met de howto van Jazzy zou het moeten lukken.
  • Shaggy_NL
  • Laatst online: 12-10 00:20
Exchange op een AD-server is opzich niet zo'n super idee, doorgaans. En Exchange 2007 SP1 is idd aan te bevelen, en niet de non-SP Exchange 2007. De SP1 is een complete Setup. Dus niet een losse update die je er achteraan installeerd, maar een volwaardige installatie CD (DVD?).
Nog sterker, als je op een bestaande Exchange 2007 alsnog Exchange 2007 SP1 wilt installeren, gaat eerst Exchange 2007 er helemaal af. De Postvakken blijven staan en zullen weer worden gekoppeld bij het installeren van Exchange 2007 SP1.
  • alt-92
alt-92
ye olde farte
Exchange 2007 zonder SP1 kun je niet eens op een 2008 Server installeren ;)
  • paella
  • Laatst online: 19:26
Exchange op een AD-server is voor evaluatie prima. Zelfs in productie zal je op zich over het algemeen geen problemen tegenkomen, maar als je kan beginnen zou ik het inderdaad niet aanraden.
No production networks were harmed during this posting
