Verzoek EXIF tag Nikon D70 te bekijken
  • 63 views sinds 30-01-2008
Kan iemand uit de onderstaande EXIF-info opmaken of de camera tijdens het maken van de foto op oneindig was gefocust of niet?
Bedankt voor de info!
__________________________
Make - NIKON CORPORATION
Model - NIKON D70
Orientation - Top left
XResolution - 300
YResolution - 300
ResolutionUnit - Inch
Software - Ver.1.02
DateTime - 2006:10:27 08:16:20
YCbCrPositioning - Co-Sited
ExifOffset - 216
ExposureTime - 1/200 seconds
FNumber - 6.00
ExposureProgram - Normal program
ExifVersion - 0221
DateTimeOriginal - 2006:10:27 08:16:20
DateTimeDigitized - 2006:10:27 08:16:20
ComponentsConfiguration - YCbCr
CompressedBitsPerPixel - 4 (bits/pixel)
ExposureBiasValue - -0.33
MaxApertureValue - F 5.86
MeteringMode - Multi-segment
LightSource - Auto
Flash - Not fired
FocalLength - 185.00 mm
UserComment -
SubsecTime - 0
SubsecTimeOriginal - 0
SubsecTimeDigitized - 0
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 3008
ExifImageHeight - 2000
InteroperabilityOffset - 24992
SensingMethod - One-chip color area sensor
FileSource - Other
SceneType - Other
CustomRendered - Normal process
ExposureMode - Auto
WhiteBalance - Auto
DigitalZoomRatio - 1 x
FocalLengthIn35mmFilm - 277 mm
SceneCaptureType - Standard
GainControl - None
Contrast - Normal
Saturation - Normal
Sharpness - Normal
SubjectDistanceRange - Unknown
Maker Note (Vendor): -
Data version - 0210 (808595760)
ISO Setting - 200
Image Quality - FINE
White Balance - AUTO
Image Sharpening - AUTO
Focus Mode - AF-S
Flash Setting - NORMAL
Flash Mode -
White Balance Adjustment - -196608
Exposure Adjustment - 68608
Flash Compensation - 67072
ISO 2 - 200
Tone Compensation - AUTO
Lens type - AF-D or AF-S
Lens - 618
Flash Used - Not fired
AF Focus Position - 17039376
Bracketing - 2097152
Color Mode - MODE1a
Light Type - NATURAL
Hue Adjustment - 0
Noise Reduction - OFF
Total pictures - 8215
Optimization - NORMAL
Omdat?
Misschien moet je hier kijken
"AF Focus Position - 17039376"
Maak eens wat andere foto's met focus op oneindig en wat andere standen, en kijk waarop ie dan staat.
[ Voor 93% gewijzigd door Verwijderd op 31-12-2006 12:29 ]
Ik heb de camera niet zelf, dus ik kan zelf niks proberen. Ik probeer een foto te analyseren gemaakt met een Nikon D70.
Bestaat er ook een tabel of omrekenformule waarmee je de betekenis van 'AF Focus Position - 17039376' kunt bepalen?
Bedankt.
  • YellowCube
  • Laatst online: 15:54
YellowCube
Wait...what?
ik denk eerlijk gezegd dat die AF Focus Position iets zegt over het gebruikte focuspunt (dus midden, links, rechts, boven of onder).
Deze lijkt me een optie: SubjectDistanceRange - Unknown.
Wat dus zou betekenen dat de focusafstand ergens in het oneindige ligt (en dus onbekend is).
My doctor says that I have a malformed public-duty gland and a natural deficiency in moral fibre and that I am therefore excused from saving the world
  • CptMorgan
  • Laatst online: 14:00
YellowCube schreef op zondag 31 december 2006 @ 13:51:
Volgensmij niet, bij mij staat die standaard op Unkown (Nikon D50) ik denk niet echt dat zomaar uit de EXIF te lezen valt?
C40 Twin Ultimate MY23 - Thunder Grey - 20" - Zappi v2.1 - 7470Wp O/W - Enphase
  • janklp
  • Laatst online: 07-09 21:34
janklp
FortyTwo Capital
cyberrobin schreef op zondag 31 december 2006 @ 13:56:
Dat geloof ik inderdaad ook niet. Plaats de foto eens, dan kunnen we er misschien meer over zeggen. Wel full size posten eh.
  • Floor-is
  • Laatst online: 16:24
Floor-is
5.2
Nou post liever een thumb met een linkje naar full-size :)
Bericht hierboven
Heeft dat niet te maken met dat er in AF-D lenzen afstandsinformatie word doorgegeven? En de gebruikte lens is AF-S.
  • Henk
  • Laatst online: 04-09 15:31
Verwijderd schreef op zondag 31 december 2006 @ 16:36:
AF-S is ook D :)
  • joho
  • Laatst online: 02-09 11:14
joho
Ik neem aan dat je het digitale bestand hebt. Trek dit dan eens door een andere exif info tool, eentje die ook de Nikon tags herkend.
Ik heb de net ExifTool (zie http://www.sno.phy.queensu.ca/%7Ephil/exiftool/) eens lotgelaten op mijn eigen foto's en zie een heel verhaal inclusief de volgende regels:
Circle Of Confusion : 0.020 mm
Depth of Field : inf (2.08 m - inf)
Focal Length : 17.0mm (35mm equivalent: 25.0mm)
Hyperfocal Distance : 3.54 m
Mischien dat deze info afhankelijk is van de body/lens combo, maar probeer het eens.
Joho, bedankt voor de link naar Exiftool. Hiermee heb ik leesbare afstandsinfo uit de foto kunnen halen:
Focus Distance: 31.62 m
Depth of Field: 7.08 m (28.47 - 35.56)
Hyperfocal Distance: 284.26 m
Misschien een bijzonder domme vraag (maar ik heb weinig ervaring met fotografie), denk je dat een object dat zich op enkele kilometers afstand bevond met bovenstaande instellingen scherp gefotografeerd kan worden?
Nogmaals dank voor de info.
  • Floor-is
Floor-is
5.2
Alsjeblieft en volgende keer zelf even google gebruiken he? ;)
Bericht hierboven
