[JS] Hover werkt niet in IE7
  • radem205
  • Laatst online: 02-02-2022
Hey,
Ik heb een hover effect ingebouwd in mijn website waarmee informatie wordt getoond bij een mouseover van een betreffende button.
Nu heb ik om de hover ook te laten werken in IE gebruik gemaakt van onderstaande hover.htc bestand:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
<attach event="ondocumentready" handler="parseStylesheets" />
<script>
var csshoverReg = /(^|\s)(([^a]([^ ]+)?)|(a([^#.][^ ]+)+)):(hover|active)/i,
currentSheet, doc = window.document, hoverEvents = [], activators = {
    onhover:{on:'onmouseover', off:'onmouseout'},
    onactive:{on:'onmousedown', off:'onmouseup'}
function parseStylesheets() {
    if(!/MSIE (5|6)/.test(navigator.userAgent)) return;
    window.attachEvent('onunload', unhookHoverEvents);
    var sheets = doc.styleSheets, l = sheets.length;
    for(var i=0; i<l; i++)
        parseStylesheet(sheets[i]);
    function parseStylesheet(sheet) {
        if(sheet.imports) {
            try {
                var imports = sheet.imports, l = imports.length;
                for(var i=0; i<l; i++) parseStylesheet(sheet.imports[i]);
            } catch(securityException){}
        try {
            var rules = (currentSheet = sheet).rules, l = rules.length;
            for(var j=0; j<l; j++) parseCSSRule(rules[j]);
    function parseCSSRule(rule) {
        var select = rule.selectorText, style = rule.style.cssText;
        if(!csshoverReg.test(select) || !style) return;
        var pseudo = select.replace(/[^:]+:([a-z-]+).*/i, 'on$1');
        var newSelect = select.replace(/(\.([a-z0-9_-]+):[a-z]+)|(:[a-z]+)/gi, '.$2' + pseudo);
        var className = (/\.([a-z0-9_-]*on(hover|active))/i).exec(newSelect)[1];
        var affected = select.replace(/:(hover|active).*$/, '');
        var elements = getElementsBySelect(affected);
        if(elements.length == 0) return;
        currentSheet.addRule(newSelect, style);
        for(var i=0; i<elements.length; i++)
            new HoverElement(elements[i], className, activators[pseudo]);
function HoverElement(node, className, events) {
    if(!node.hovers) node.hovers = {};
    if(node.hovers[className]) return;
    node.hovers[className] = true;
    hookHoverEvent(node, events.on, function() { node.className += ' ' + className; });
    hookHoverEvent(node, events.off, function() { node.className = node.className.replace(new RegExp
('\\s+'+className, 'g'),''); });
    function hookHoverEvent(node, type, handler) {
        node.attachEvent(type, handler);
        hoverEvents[hoverEvents.length] = {
            node:node, type:type, handler:handler
    function unhookHoverEvents() {
        for(var e,i=0; i<hoverEvents.length; i++) {
            e = hoverEvents[i];
            e.node.detachEvent(e.type, e.handler);
function getElementsBySelect(rule) {
    var parts, nodes = [doc];
    parts = rule.split(' ');
    for(var i=0; i<parts.length; i++) {
        nodes = getSelectedNodes(parts[i], nodes);
    }   return nodes;
    function getSelectedNodes(select, elements) {
        var result, node, nodes = [];
        var identify = (/\#([a-z0-9_-]+)/i).exec(select);
        if(identify) {
            var element = doc.getElementById(identify[1]);
            return element? [element]:nodes;
        var classname = (/\.([a-z0-9_-]+)/i).exec(select);
        var tagName = select.replace(/(\.|\#|\:)[a-z0-9_-]+/i, '');
        var classReg = classname? new RegExp('\\b' + classname[1] + '\\b'):false;
        for(var i=0; i<elements.length; i++) {
            result = tagName? elements[i].all.tags(tagName):elements[i].all;
            for(var j=0; j<result.length; j++) {
                node = result[j];
                if(classReg && !classReg.test(node.className)) continue;
                nodes[nodes.length] = node;
        return nodes;
</script>
HTML code:
<ul class="loginmenunav">
            <li id="login1"><a href="http://www.adigo.nl/login/mindmap">MINDMAP</a>
                <div class="loginmenunav_tekst1">
                    Bekijk hier uw persoonlijke Mindmap, welke Adigo gebruikt om gegevens met u uit
te wisselen.
                </div>
            </li>
            <li id="login2"><a href="http://www.adigo.nl/login/wijzigen">GEGEVENS WIJZIGEN</a>
                <div class="loginmenunav_tekst2">
                    Wijzig uw persoonlijke gegevens, zoals uw e-mailadres en / of wachtwoord.
                </div>
            </li>
            <li id="login3"><a href="http://www.adigo.nl/login/uitloggen">UITLOGGEN</a>
                <div class="loginmenunav_tekst3">
                    Log uzelf uit op de website. U kunt dan geen gebruik meer maken van de extra
functies totdat u zich weer heeft ingelogd op de website.
                </div>
            </li>
        </ul>
CSS code:
29
30
31
32
33
34
.loginmenunav_tekst1, .loginmenunav_tekst2 {
    position: absolute;
    width: 326px;
    left: -999em;
    background-color: #E9E9E9;
    border: 1px solid #004168;
    font-family: Arial, Helvetica;
    font-size: 11px;
    color: #4C4C4C;
    font-weight: normal;
    padding: 3px 3px 3px 3px;
.loginmenunav_tekst3 {
    position: absolute;
    width: 285px;
    left: -999em;
    font-size: 11px;
    color: #4C4C4C;
#login1:hover .loginmenunav_tekst1 {
    left: auto;
#login2:hover .loginmenunav_tekst2 {
    left: auto;
#login3:hover .loginmenunav_tekst3 {
    left: auto;
Nu werkt het allemaal mooi in Firefox en IE < 7, maar om één of andere reden werkt het niet IE7.
Weet iemand hoe dit komt?
  • crisp
  • Laatst online: 21:50
crisp
Devver
Pixelated
IE7 ondersteund gewoon :hover op alle elementen, maar alleen in standards-compliant mode. Waarschijnlijk gebruik je dus geen (volledige) DTD waardoor IE in quirksmode draait.
De .htc wordt niet toegepast vanwege deze simpele check:
JavaScript:
(overigens geen fool-proof IE-check, persoonlijk zou ik conditional compilation gebruiken hoewel ik niet weet in hoeverre dat mogelijk is binnen een htc)
[ Voor 20% gewijzigd door crisp op 29-12-2006 22:45 ]
Intentionally left blank
  • radem205
Ik snap het niet helemaal geloof ik. Moet ik die check nu weghalen of moet ik wat anders veranderen zodat ie in standard compliants mode werkt?
  • crisp
crisp
Devver
Pixelated
radem205 schreef op zaterdag 30 december 2006 @ 11:42:
Dat laatste lijkt mij het meest wenselijk nietwaar? ;)
  • radem205
Je geeft aan dat ik waarschijnlijk niet de volledige DTD (DocType Declaration naam ik aan) gebruik. Ik gebruik onderstaande doctype:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
Dit is toch correct of zie ik wat over het hood?
als je er nog een xml pi voor hebt staan wordt het toch quirksmode (sowieso als er wat voorstaat) volgens mij zit die bug er in IE7 nog in (toch? - crisp?)
verder issie ook niet correct tenzij je idd xhtml verstuurt, wat me onwaarschijnlijk lijkt want dat werkt niet in IE (ook niet in 7). Een volledige xhtml doctype zonder xml pi triggert overigens wel weer standards mode
  • crisp
crisp
Devver
Pixelated
Verwijderd schreef op zaterdag 30 december 2006 @ 19:27:
Een XML prologuedeclaration* zal in IE7 geen quirksmode meer triggeren vziw, maar anything else voor de DTD wel nog steeds...
De compatibility guidelines raden het gebruik van PI's en XML declarations ook af indien XHTML als HTML wordt verstuurd.
* en ook ik zat fout mbt de juiste naamgeving, Lachlan legt hier goed uit wat het verschil is tussen een prologue, een XML declaration en processing instructions :)
Must-read is ook deze post van Lachlan Hunt mbt XHTML ;)
[ Voor 42% gewijzigd door crisp op 30-12-2006 23:10 ]
