[LINUX]AdvanceMame / AdvanceMenu
ik heb suse 10.2 x64 geinstalleerd en daarop wou ik graag AdvanceMAME gaan draaien. nu is het gelukkig gelukt om AdvanceMAME te compileren en te installeren.
nu ben ik dus bezig met de installatie van de frontend voor AdvanceMAME genaamd AdvanceMenu.
bij ./configure gaat alles goed maar zodra ik make intoets krijg ik een compilefout. ik weet niet of iemand hier ervaring mee heeft maar hier is de make
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
suse102x64:/home/mstreurman/Downloads/advancemenu-2.4.13 # make
obj/menu/linux/blend/menu/emulator.o
./advance/lib/rgb.h:52: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:53: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:54: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:55: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:62: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:63: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:64: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
./advance/lib/rgb.h:65: warning: ‘packed’ attribute ignored for field of type ‘u                                         int8’
advance/menu/emulator.h:44: error: extra qualification ‘emulator::’ on member ‘a                                         ttrib_compile’
advance/menu/emulator.h:366: error: extra qualification ‘generic::’ on member ‘l                                         oad_info’
make: *** [obj/menu/linux/blend/menu/emulator.o] Error 1
suse102x64:/home/mstreurman/Downloads/advancemenu-2.4.13 # make -j3
obj/menu/linux/blend/menu/emuxml.o
obj/menu/linux/blend/menu/game.o
./advance/lib/rgb.h:52: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:53: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:54: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:55: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:62: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:63: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:64: warning: ‘packed’ attribute ignored for field of type ‘uint8’
./advance/lib/rgb.h:65: warning: ‘packed’ attribute ignored for field of type ‘uint8’
advance/menu/emulator.h:44: error: extra qualification ‘emulator::’ on member ‘attrib_compile’
advance/menu/emulator.h:366: error: extra qualification ‘generic::’ on member ‘load_info’
make: *** Waiting for unfinished jobs....
advance/menu/emuxml.cc: In function ‘void process_error(state_t*, const char*, const char*)’:
advance/menu/emuxml.cc:86: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘XML_Size’
advance/menu/emuxml.cc:88: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘XML_Size’
make: *** [obj/menu/linux/blend/menu/emuxml.o] Error 1
make: *** [obj/menu/linux/blend/menu/game.o] Error 1
