[Vista] Drivers Terratec Sixpack 5.1+
  • 224 views sinds 30-01-2008
  • Poeh
  • Laatst online: 10-10 23:46
Windows Vista herkent mijn Terratec Sixpack 5.1+ geluidskaart niet. Op internet lees ik dat er inderdaad problemen zijn:
Windows Vista Build 5365 Hardware Compatibility List
Has problems, but can be solved:
Terratec SixPack 5.1 (based on Crystal SoundFusion CS461x) (32 Bit)
Ik heb al geprobeerd de drivers van de Crystal geluidskaart te downloaden, maar die kan ik voor Vista of voor XP nergens vinden. Heeft iemand een oplossing hiervoor?
EDIT:
Een mailtje naar Terratec leert mij het volgende:
Dear Terratec-Customer,
unfortunately we have to tell you that the product you are asking for
has already finished its entire lifecycle, which means that also
technical support has been terminated.
As every company with a huge capacity of product lines and innovations
we cant guarantee support for products that are end-of-life, which
means that they have not been taken off the market more than three
warranty cycles plus a certain grace period ago.
The latest drivers for your product are still available in our
download section.
From the description above it should be clear that the product is
rather old in any case, so we would like to recommend you switching to
a new product with guaranteed driver support and sophisticated
technical assistance via phone or internet. You can find detailed
information about the latest Terratec Products at www.terratec.net.
You can also call our Pre-Sales support for questions before
purchase between 18-20h MET, the telephone number is : 0800-83772832 [TERRATEC]
(toll-free within all german telephone networks) or +49-2157/8179100
(international).
Best Regards,
Your Terratec Technical Service
Daar word ik dus ook niet veel wijzer van!
[ Voor 59% gewijzigd door Poeh op 18-12-2006 16:09 ]
  • Poeh
anyone?
  • Poeh
Echt niemand?
  • elevator
elevator
Officieel moto fan :)
Als je zoekt op "Crystal SoundFusion CS4610" (dus 0 ipv x aan het einde) vind je iig iets van drivers op driverguide.com - wil het daarmee toevallig niet lukken? :)
  • Poeh
Ik heb bij DriverGuide een driver gevonden voor o.a. Windows 2000, maar Vista kan daar geen geschikte stuurprogramma's in vinden.
Verder had ik hier http://www.cirrus.com/en/support/drivers/audio/OS3.html nog de driver 'WDM Driver for CS4630' gevonden en daar vindt Vista wel een driver, gaat deze vervolgens installeren, maar komt al vrij snel met een BSOD: PFN_LIST_CORRUPT.
We zoeken verder...
  • Poeh
En we hebben het gevonden!!!!
Na lang zoeken en eindeloos proberen toch een geschikte driver, weliswaar voor Windows 2000, gevonden op de volgende website:
http://soundcard.freedriv...00.3022-Windows-2000.html
Bij mij werkt deze laatste driver niet?? Ik krijg beslist geen geluid.. Boehoe... Hoe heb je dat dan toch voor elkaar gekregen?
