Developer Accused Of Unreadable Code Refuses To Comment
Je kan de laatste versie eens proberen of anders lijkt mij het zinvolste direct contact op te nemen met de makers
Of wacht
, nog slimmer, eens even kijken op de pagina van de add-on of het known is
En ja hoor:
Of wacht
En ja hoor:
Volgende keer toch iets meer moeite proberen te doen voordat je een topic opent?== KNOWN ISSUES WITH FIREFOX 1.5 ==
1. You cannot open the JavaScript Debugger a second time after closing it - this is not our bug! It is a bug with Firefox 1.5. If we find a way around it, we will of course include it, but until then you must restart Firefox 1.5 to reopen the debugger.
The problem, as far as I know, is that Firefox 1.5 objects to the missing files worse the second time you try to open the window. The unofficial version changed more than just the version, it also removed references to these files. That will stop some features working on Mozilla Suite/SeaMonkey.
If you want to, try using this official version on a nightly build of Firefox from trunk (codenamed Minefield) - it happily opens many times, because they've fixed the bug since Firefox 1.5.
If you still want to make comments without understanding anything about what's going on, do it somewhere else. Alternatively, if you actually want to work around the issue properly, take your code to Bugzilla, where development work belongs.
