lmsensors herkent geen sensors
  • 116 views sinds 30-01-2008
  • TommyGun
  • Laatst online: 09-10 09:02
TommyGun
Stik er maar in!
Hey
Ik heb eens voor de gein lmsensors geinstalleerd op mijn ClarkConnect (CentOS) bak met kernel 2.6.9-27.ccsmp. Alle benodigde packs ook geinstalleerd zoals bison, flex, m4 en sysfsutils. Vervolgens kon ik het uitstekend installeren. Echter gaat het fout bij sensors-detect;
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
We can start with probing for (PCI) I2C or SMBus adapters.
Do you want to probe now? (YES/no): yes
Probing for PCI bus adapters...
Use driver `i2c-piix4' for device 0000:00:0f.0: ServerWorks OSB4 South Bridge
We will now try to load each adapter module in turn.
Module `i2c-piix4' already loaded.
If you have undetectable or unsupported adapters, you can have them
scanned by manually loading the modules before running this script.
We are now going to do the I2C/SMBus adapter probings. Some chips may
be double detected; we choose the one with the highest confidence
value in that case.
If you found that the adapter hung after probing a certain address,
you can specify that address to remain unprobed.
Some chips are also accessible through the ISA I/O ports. We have to
write to arbitrary I/O ports to probe them. This is usually safe though.
Yes, you do have ISA I/O ports even if you do not have any ISA slots!
Do you want to scan the ISA I/O ports? (YES/no): yes
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM78-J' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Probing for `Winbond W83627HF' at 0x290... No
Probing for `Silicon Integrated Systems SIS5595'... No
Probing for `VIA VT82C686 Integrated Sensors'... No
Probing for `VIA VT8231 Integrated Sensors'... No
Probing for `IPMI BMC KCS' at 0xca0... No
Probing for `IPMI BMC SMIC' at 0xca8... No
Some Super I/O chips may also contain sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): yes
Probing for Super-I/O at 0x2e/0x2f
Trying family `ITE'... No
Trying family `National Semiconductor'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Fintek'... No
Probing for Super-I/O at 0x4e/0x4f
Some CPU may also contain embedded sensors.
Do you want to scan for CPU embedded sensors? (YES/no): yes
AMD K8 thermal sensors... No
Intel Core family thermal sensor... No
Sorry, no sensors were detected.
Either your sensors are not supported, or they are connected to an
I2C or SMBus adapter that is not supported. See doc/FAQ,
doc/lm_sensors-FAQ.html or http://www.lm-sensors.org/wiki/FAQ
(FAQ #4.24.3) for further information.
If you find out what chips are on your board, check
http://www.lm-sensors.org/wiki/Devices for driver status.
Vervolgens op de site nog wat gekeken en het volgende uitgevoerd;
cd /tmp
wget "http://www.lm-sensors.org/browser/lm-sensors/trunk/prog/detect/sensors-detect?format=txt"
perl "sensors-detect?format=txt"
Maar ook dat mocht niet baten. Enig idee of ik dit nog werkend kan krijgen? Lijkt me vreemd dat er op mijn bak (Dell PowerEdge 6450) niks van sensors zit. Kon hier verder niet veel over vinden helaas, en ik weet dus ook niet of iets daarvan hier tussen staat; http://lm-sensors.org/wiki/Devices
Zou leuk zijn als iemand meer weet.
B.v.d :)
  • MetalRush
  • Laatst online: 11-09 22:02
MetalRush
PAS OP, HÈ !
Dell PowerEdge 6450
...dan kan ik je vertellen dat je hier geen data uit zult krijgen.
Dell 'bespaart' o.a. op het niet (laten) plaatsen van sensoren.
Ik heb verschillende Dell machines gehad en geen van hen had sensoren.
Keep smiling... it makes people wonder what you're up to :)
  • TommyGun
TommyGun
Stik er maar in!
Da's dan wel weer jammer. Zou ik zelf iets kunnen plaatsen? Morgen eens wat over opzoeken :)
Bedankt voor je antwoord
  • Jk_W
Jk_W
I Think...
Zelf plaatsen is ook niet mogelijk.
Je zou hoogstens zelf thermometers kunnen toevoegen, maar die zullen niet met lmsensors uit te lezen zijn, maar gewoon extern zijn.
  • TommyGun
TommyGun
Stik er maar in!
Extern idd, mja helaas. Misschien eens naar thermometers kijken.
Bedankt iig
  • Thc_Nbl
  • Laatst online: 14-10 22:58
MetalRush schreef op maandag 04 december 2006 @ 00:48:
Nou ik had een dell Poweredge 2850 en daar heb ik prima de CPU temps en fan speeds uitgehaald met lm sensors.
dus of jij hebt iets fout gedaan, je jouw server heeft geen sensors.
of je hebt iets gemist.
kijk hier eens : http://linux.dell.com/monitoring.shtml
en hier wat ik heb gebruikt : http://www.uta.fi/~pauli.borodulin/dellomsa/omsa44.html
let wel ik heb de wel kernel 2.6.14 gebruikt op mijn sarge bakkie, en zelf even de kernel gemaakt.
Als je kernel 2.6.16 gebruikt of hoger zou het zo moeten werken.
ehhh.. noppes
  • Thc_Nbl
en welke ik vergeet en net tegen kwam:
http://linux.dell.com/debian_9g.shtml
/snap
Dell PowerEdge 9G servers (x9xx, 840, 860, SC1435, and SC440) can work well with Debian, provided you have a new-enough kernel or are willing to backport drivers from a new-enough kernel to your older kernel.
The three PowerEdge components that cause the most difficulty for new Debian sysadmins are the PERC 5 SAS RAID controllers (megaraid_sas driver), the SAS 5 non-RAID controllers (mptsas driver), and the Broadcom gigabit network adapters (bnx2 driver).
suc6
ehhh.. noppes
  • TommyGun
TommyGun
Stik er maar in!
Beetje laat antwoord, maar daar had ik nog naar gekeken. Echter zie ik mijn type daar zoiezo niet tussen staan en echt duidelijk is die Dell site ook niet. Gaat mij voornamelijk om de HDD's, en daarvoor zag ik ook Nagios maar laatst genoemde is nou niet echt Linux-beginner vriendelijk :P
[ Voor 30% gewijzigd door TommyGun op 25-01-2007 16:20 ]
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Some 9G servers (PowerEdge 1950, 1955, 2900, and 2950) present their onboard NICs as Gb1 and Gb2 in BIOS, but these map to eth1 and eth0 respectively ("backwards") under Linux. This is fixed in kernel 2.6.19-rc3 and higher. You can also use udev rules to set the mapping as you may like.
Crap, ben ik even blij met m'n remote kvm :X
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • u_nix_we_all
TommyGun schreef op donderdag 25 januari 2007 @ 16:19:
Harddisk temps kun je zonder lmsensors doen, via SMART, ik gebruik hiervoor hddtemp.
Je CPU temp is misschien ook wel in /proc/acpi terug te vinden.
Nagios is een complete monitoring server die plugins gebruikt om data te verzamelen, maar die zijn dan ook weer afhankelijk van andere tools zoals lmsensors.
You don't need a parachute to go skydiving. You need a parachute to go skydiving twice.
  • TommyGun
TommyGun
Stik er maar in!
u_nix_we_all schreef op donderdag 25 januari 2007 @ 16:31:
In /proc/acpi/processor/CPU0
Info:
processor id: 0
acpi id: 1
bus mastering control: no
power management: no
throttling control: no
limit interface: no
Limit:
<not supported>
Power:
active state: C1
default state: C1
bus master activity: 00000000
states:
*C1: promotion[--] demotion[--] latency[000] usage[00000000]
C2: <not supported>
C3: <not supported>
Throttling:
<not supported>
In de mappen In /proc/acpi/ ac_adapter, battery, button, embedded_controller, fan, power_resource, thermal_zone staat verder geen informatie. Behalve dat in button dat er een power button op de server zit. Spannend hoor :P
In de enkele files van In /proc/acpi/ staat ook helemaal niks.
  • The-Hi_End
  • Laatst online: 17-08 10:21
geen /proc/acpi/thermal_zone/ staan?
  • TommyGun
TommyGun
Stik er maar in!
The-Hi_End schreef op donderdag 25 januari 2007 @ 19:53:
Leeg dus
  • u_nix_we_all
Als die files in /proc leeg zijn, kan het zijn dat je kernel niet met die opties geconfigureerd is,
of dat er kernel modules voor geladen moeten worden.
Maar het kan ook zijn dat jouw acpi het gewoon niet ondersteund
  • TommyGun
TommyGun
Stik er maar in!
Tja, van beide heb ik totaal geen verstand dus het zei zo dan maar. Toch bedankt allen
  • Paul
  • Laatst online: 10:50
Heeft die Dell geen IPMI? Dan heb je afaik helemaal geen lmsensors nodig :)
Edit: Hmm, het 2e cijfertje in het typenummer lijkt de 'generatie' aan te geven, waardoor jouw server te oud lijkt te zijn voor IPMI.
Heb je iets aan http://linux.dell.com/monitoring.shtml ? En dan met name http://linux.dell.com/fil...ontributions/omsa-51-live ? Als dat wel wil is er dus iig wel _iets_ mogelijk onder CentOS :) Geen lmsensors, maar toch...
[ Voor 71% gewijzigd door Paul op 27-01-2007 20:32 ]
Rhàshan - Aditu Sunlock
  • TommyGun
TommyGun
Stik er maar in!
Ja die links werden ook al gegeven in Thc_Nbl in "lmsensors herkent geen sensors" maar idd, mijn type nummer is nergens terug te vinden.
  • Paul
Ook niet in OMSA zelf als je eenmaal die live CD hebt gestart?
  • TommyGun
TommyGun
Stik er maar in!
Daar heb ik eigenlijk weinig behoefte aan. Geen zin in downtime en om fysiek te gaan kloten.
Maar het is geen ramp, was alleen leuk geweest. Thanks anyway
[ Voor 26% gewijzigd door TommyGun op 27-01-2007 21:15 ]
  • TommyGun
TommyGun
Stik er maar in!
Ik wil dit topic toch nog eens kicken, om een nieuwe poging te wagen.
Ik zag gisteren namelijk dat een ledje op de server af en toe oranje wordt / uit gaat maar ik weet niet voor hoelang dit al is. Dit ledje blijkt voor de temperatuur / fans te zijn, maar de fans draaien netjes en ook voelt alles koel aan. Het kan zomaar zijn dat dit al enkele maanden is, misschien omdat de nieuwe (stillere) fans langzamer draaien dan de oude...
Zie ook link.
Alleen de koelblokjes op de southbridge en RAID controller worden aardig heet, maar draait gewoon stabiel en dat is al sinds ik de server heb. Helaas geven de logs helemaal niks aan. Op de website van Dell zag ik wel het volgende staan;
WARNING: The SEC cartridge and heat sink assembly can get extremely hot during system operations. Be sure that it has had sufficient time to cool before touching it.
WARNING: When handling the SEC cartridge and heat sink assembly, take care to avoid sharp edges on the heat sink.
Maar de CPU's zijn gewoon koud tot lauw bij mij, dus tja...
Iemand die wat nieuwe input kan geven? Bedankt
[ Voor 18% gewijzigd door TommyGun op 03-04-2007 15:32 ]
