[Vista] Onmogelijk om .reg te importeren?
  • 125 views sinds 30-01-2008
  • Hermanvh
  • Laatst online: 17-03 10:14
Hermanvh
webOS fan, hacker, developer
Ik probeer het volgende .reg bestand in Vista x64 te importeren, maar het lukt met geen mogelijkheid :( Zelfs niet wanneer ik regedit als admin draai :'(
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\Root\LEGACY_PPSIO2]
"NextInstance"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\Root\LEGACY_PPSIO2\0000]
"Service"="ppsio2"
"Legacy"=dword:00000001
"ConfigFlags"=dword:00000000
"Class"="LegacyDriver"
"ClassGUID"="{8ECC055D-047F-11D1-A537-0000F8753ED1}"
"DeviceDesc"="PPDevice"
"Capabilities"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\Root\LEGACY_PPSIO2\0000\Control]
"ActiveService"="ppsio2"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\ppsio2]
"DisplayName"="PPDevice"
"Type"=dword:00000001
"Start"=dword:00000002
"Group"="Extended Base"
"ErrorControl"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\ppsio2\Enum]
"0"="Root\\LEGACY_PPSIO2\\0000"
"Count"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Enum\Root\LEGACY_PPSIO2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Enum\Root\LEGACY_PPSIO2\0000]
"Service"="ppsio2"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\ppsio2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_PPSIO2\0000]
"Service"="ppsio2"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_PPSIO2\0000\Control]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ppsio2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ppsio2\Enum]
De foutmelding is: Cannot import d:\scanner2\scanner.reg: Error accessing the registry.
Ook bij het handmatig aanmaken van de sleutel krijg ik een foutmelding: Cannot create key: You do not have the requisite permissions to create a new key under Root.
Ik kan nergens terugvinden hoe ik wel deze rechten kan krijgen :( Iemand suggesties?
webOS all the way!
  • elevator
elevator
Officieel moto fan :)
Op deze manire handmatig een driver aan gaan maken is wel bijzonder ranzig hoor?: o
Maar goed - doe eens een 'Run as administrator' op regedit en start vanuit regedit de 'Import from file' op ? :)
  • Hermanvh
Hermanvh
elevator schreef op dinsdag 28 november 2006 @ 20:31:
I know, installer is 16 bits dus doet het zowieso niet in Vista :'( Vandaar maar op de handmatige manier ;)
Helaas regedit als admin en dan importeren werkt ook niet :'(
webOS all the way!
  • alt-92
alt-92
ye olde farte
Sowieso heb je dan al genoeg aan de CurrentControlSet.
Als het print subsystem tenminste niet teveel afwijkt want dit is inderdaad een beetje overbelegen ;)
  • elevator
elevator
Hermanvh schreef op dinsdag 28 november 2006 @ 20:42:
Je krijtg dezelfde meldingen? En als je handmatig naar CurrentControlSet gaat (met die regedit als admin) kan je dan wel keys bijmaken? :)
  • Hermanvh
Hermanvh
elevator schreef op dinsdag 28 november 2006 @ 20:55:
Dus ook niet :( Lijkt wel of ik echt gelocked ben :( Zelfs in SAFE mode niet :'(
webOS all the way!
  • elevator
elevator
Probeer gewoon eens ownership en rechten te pakken in regedit? (rechtsklikken, permissions, etc) ? :)
(wel na het maken van een goede backup enzo he :) )
  • Hermanvh
Hermanvh
elevator schreef op dinsdag 28 november 2006 @ 21:01:
Dat lukte gisteren ook niet voor de Enum key, maar nu blijkbaar wel voor de subkeys :) Kijken of m'n scanner het nu ook gaat doen ;)
webOS all the way!
  • Hermanvh
Hermanvh
Helaas :( Vista schakelt hem uit, omdat ie niet compatibel is :(
webOS all the way!
  • anandus
Hermanvh schreef op dinsdag 28 november 2006 @ 22:59:
Wat een verrassing :P
Nee hoor, j/k, maar wacht anders in ieder geval tot Vista voor particulieren uitkomt, wie weet komt er nog een driver voor uit.
Mail anders dan of nu de maker? :)
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Tja vind ik ook neit zo gek bij een 16bits app op 64bits vista.
Mijn spoorwegfotografie
  • Hermanvh
Hermanvh
sanfranjake schreef op dinsdag 28 november 2006 @ 23:10:
Driver is 32 bits voor een 8 jaar oude scanner ;) Alleen install app was 16 bits :'(.
Helaas gaat de maker geen drivers meer maken voor x64. Onder x86 werkt het wel, dus ik heb maar besloten om een nieuwe scanner te kopen die wel onder x64 werkt :)
webOS all the way!
