[Cisco2950] Reset to factory defaults
  • DaSquad117
  • Laatst online: 20-10 13:32
Ik heb hier een Cisco 2950 gekregen. Nu weet ik daar niks van paswoord van, dus wil ik hem resetten.
Dus ik steek de power cabel in en blijf op 't mode knopje drukken, zodat ik kan wijzigingen aanbrengen in 't flash filesystem. Ik wil de configuratie wissen. Maar ik krijg 't volgende:
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950-24 starting...
Base ethernet MAC Address: 00:14:a9:fd:de:40
Xmodem file system is available.
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
load_helper
boot
switch: flash_init
Initializing Flash...
flashfs[0]: 359 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4674560
flashfs[0]: Bytes available: 3066880
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
switch: load_helper
switch: dir flash
unable to stat flash/: permission denied
switch:
Ik heb dus geen toegang tot de flash :?
Kan ik op één of andere manier er toch toegang tot krijgen?
  • Bl@ckbird
Zie:
http://www.cisco.com/en/U...186a008007e83c.html#13149
Getting "Permission Denied" error message during the bootup.
This error message appears when the boot parameters are not set correctly. In most of the cases, when setting the boot parameters during or after the upgrade, the word flash: is mistyped or completely missed.
Go to Setting BOOT Parameters at ROMMON (Switch: Prompt) to verify and set the BOOT parameters correctly.
If setting the BOOT parameters to the correct filename does not resolve the issue, perform an X-Modem upgrade, as the file present on the Flash memory could be corrupted or invalid.
Voor een X-Modem recovery, zie:
http://www.cisco.com/en/U...6a0080169696.shtml#topic2
(Step 4)
~ Voordelig Zelf Vliegen? ~ Sent using RFC 1149. Note: No animals were harmed during this data transfer. ~
  • DaSquad117
Thanx!. Inderdaad een verkeerd commando, 't moest flash: zijn. 8)7
