[JS] new Function, by reference voorkomen
  • 119 views sinds 30-01-2008
Ik heb de volgende testcase, waarvan beide dispatches alert('b') teruggeven, waarvan ik wil dat de eerste netjes alert('a') terug gaat geven. Hoe kan ik zorgen dat de xmlString by value wordt doorgegeven en niet by reference :?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
<script type="text/javascript">
function EventManager(){
    this.types = new Array();
EventManager.prototype.addListener = function(type,action,lifespan){
    if(this.types[type] == null){
        this.types[type] = new EventQueue();
    this.types[type].add(action,lifespan);
EventManager.prototype.dispatch = function(type){
    if(this.types[type] != null){
        var eventQueue = this.types[type];
        var events = eventQueue.getEvents();
        for(var i=0,j=eventQueue.getLength();i<j;i++){
            events[i].action();
            switch(events[i].lifespan){
                // once     : event triggered only once
                // default  : event is always triggered
                case 'once':
                    events[i] = null;
                break;
EventManager.prototype.getListeners = function(type){
        return this.types[type];
    }else{
        return null;
function EventQueue(){
    this.events = new Array();
EventQueue.prototype.add = function(action,lifespan){
    this.events.push({action:action,lifespan:lifespan});
EventQueue.prototype.getEvents = function(){
    return this.events;
EventQueue.prototype.getLength = function(){
    return this.getEvents().length;
function foo(){
    var self = this;
    this.eventManager = new EventManager();
    var xmlString = 'alert(\'a\')';
    var func = function(){new Function(xmlString).call(self)};
    this.eventManager.addListener('a',func);
    xmlString = 'alert(\'b\')';
    this.eventManager.addListener('b',func);
foo.prototype.dispatch = function(){
    this.eventManager.dispatch('a');
    this.eventManager.dispatch('b');
var test = new foo();
test.dispatch();
</script>
  • crisp
  • Laatst online: 19:04
crisp
Devver
Pixelated
closure vermijden of expliciet scopen?
Intentionally left blank
Hmm dat is niet zo mooi dan. Ik wilde het toepassen binnen een lus, maar dan moet je dus diverse losse functies in een array/object gaan stoppen om het te gebruiken. Voor zover ik weet kun je de closure niet vermijden in mijn situatie.
for(var i=0,j=cs.length;i<j;i++){
        var node = cs[i];
        switch(node.nodeName.toLowerCase()){
            case "listeners":
                var cschildren = node.childNodes;
                for(var k=0,l=cschildren.length;k<l;k++){
                    var ev = cschildren[k];
                    var func = function(){new Function(getNodeValue(ev)).call(newNode)};
                    newNode.eventManager.addListener(ev.nodeName,func);
            break;
[ Voor 8% gewijzigd door Verwijderd op 19-11-2006 00:27 ]
  • crisp
crisp
Devver
Pixelated
natuurlijk wel:
JavaScript:
var func = createFunction(getNodeValue(ev), newNode);
function createFunction(func, obj)
    return function()
        new Function(func).call(obj);
Crisp, maar ga je in de closure niet ook die functie by reference doorgeven, dus eigenlijk min of meer hetzelfde verplaatsen naar de createFunction? :?
  • crisp
crisp
Devver
Pixelated
nee, elke keer dat je createFunction aanroept genereer je een compleet nieuwe scope
crisp schreef op zondag 19 november 2006 @ 13:16:
Hmmz grappig, ik ga het meteen even uitproberen. Enige nadeel kan dan denk ik zijn dat je memory leaks krijgt, maar eerlijk gezegd kan me dat even gestolen worden. Alvast bedankt! :)
En het werkt! _/-\o_
[ Voor 5% gewijzigd door Verwijderd op 19-11-2006 19:34 ]
  • frickY
  • Laatst online: 03-10 19:20
Crisp, bedankt!
Stoei ook vaker met dit probleem wanneer ik vanuit een loop een onclick wil zetten met bijvoorbeeld de loop variabele i, welke in een functie moet worden gestopt.
Voorheen deed ik dat door i op te slaan als het id van het item, en in de functie aanroep te verwijzen naar this.id.
In het vervolg weet ik dat ik het zo kan doen;
item.onclick = new Function("alert(" + i + ");");
  • crisp
crisp
Devver
Pixelated
frickY schreef op maandag 27 november 2006 @ 14:38:
of zo:
JavaScript:
item.onclick = createClickHandler(i);
function createClickHandler(i)
    return function() { alert(i); };
  • user109731
@crisp: waarom zou je dat laatste gebruiken, om performance redenen? (functie constructor is langzaam?) :)
  • crisp
crisp
Devver
Pixelated
Grote prutser schreef op maandag 27 november 2006 @ 15:03:
jep, afhankelijk van de JS-implementatie is de constructie met de closure 25% tot 800% sneller
