Overclock vragen
  • 201 views sinds 30-01-2008
Ik heb 2 vragen, hoe weet ik wanneer me systeem onstabiel is ik merk af en toe dat er iets vast loopt maar ik heb prime voor ongeveer 30m gedraait en me systeem reset niet of loopt vast.
en klopt deze informatie?
http://www.tweaknews.net/...s=0&postorder=asc&start=0
1. first and foremost, make sure you have sufficient cooling. this is a must. good cpu, northbridge, ram, case, video, and even southbridge may be required
2. make sure all of your components can handle the stress of overclocking. pc3200 is a must for any platform. a good name brand psu of 400watts+ is recommended also.
3. now for overclocking . . .lock your agp/pci buses to 66/33mhz respectively. this is the first actual step for overclocking. the agp and pci run in a 2:1 ratio - if you can't find where to set the pci bus speed, just set the agp to 66mhz and the pci will set to 33mhz.
4. give your ram at least 2.8v so that it will be able to handle higher speeds. raising the fsb will also raise the speed that the ram runs at. it is a good idea to relax your memory timings so that it will be able to run with greater stability. timings of 3-4-4-8 are advised.
5. you may now raise your fsb in 5-10 mhz increments. after each increase, run a benchmark or stress test to test for stability. if the system is unstable, up the vcore .025-.05v or until stability is gained back. note that raising the voltage will result in more heat. watch your temps.
6. always monitor your temperatures, making sure they do not exceed recommended limits. i like to use this rule = p4's keep under 47c and amd's keep under 55c. although different series of these processors like to run at different temps, they are good estimates. these temps will ensure the processor's longevity.
7. if it appears that you hit a wall, (no matter what vcore you use, the system will not be stable) you should now use a divider. a divider allows the fsb and the memory to run at different speeds. (i.e. - a 5:4 divider will make the fsb run at 250mhz while the memory runs at 200mhz) this will give you more headroom so that you may max out the processor.
8. if the system does not post or fails to boot correctly, you will need to clear the cmos. this can be done 3 ways: by using a jumper and moving it from pins 1-2 to 2-3 and then back to pins 1-2 (see bios manual for more detailed instructiuons). you can also take out the motherboard's battery and unplug the power supply unit. leave these out for about 5min to fully clear the cmos. lastlly, some motherboards support holding the 'insert' key during the boot sequence. this will allow you to enter the bios during a no post to change the settings.
9. the fsb is not the only way to overclock a processor. some processors (namely amd processors) are unlocked - they will allow you to change the multiplier. it would be better to run a processor at 10*216mhz fsb than to run it at 13*166mhz fsb. they result in the same overall speed, however, with the raised fsb, your ram, cpu, and agp will communicate faster with one another.
10. remember that every component has a limit. each individual processor and memory stick has their own limit. some people get lucky and can acheive a higher overclock than others. don't be dissapointed if you hit a ceiling before others do. remember, you probably just turned a $100 cpu into a $300+ cpu.
  • Theo
  • Laatst online: 17:08
Theo
moederbord
Verwijderd schreef op zaterdag 18 november 2006 @ 22:41:
Laat Prime95 maar eens een nachtje draaien. Mocht hij 's ochtends nog steeds draaien is hij pas stabie; Een half uurtje prime95 is nog een stabiel systeem.
  • kahm-jai
  • Laatst online: 07-02-2022
kahm-jai
Kyon-Kyon Neko!
hij bedoelt, Geen stabiel systeem:
dus ja.. een nacht prime 95 draaien, 2x tegelijk bij dual cores. probeer een blend test, dan weet je zeker dat het geheugen het ook aankan.
en wat hierboven staat klopt wel ongeveer... maaruh... welk systeem probeer je eigenlijk over te clocken. Er is een verschil hoe je verschillende processors het beste kan overclocken.. en HOE..de theorie is grotendeels hetzelfde... maar ja... athlon XP en athlon 64 scheelt bv. heeel erg veel
Asus A8N-SLI, Athlon 64 3000+ @ 2,4 GHz, Corsair TwinX 2x512 3200XL 2xWD120GB, Apogee 6800 PCI-E@430/860, Enermax Noisetaker 495, Thermalright XP120, Nec3500, liteonDVD
  • -ErikE-
  • Laatst online: 13-10 22:45
`k heb weinig behoefte die hele lap gequote tekst door te lezen. Heb jij wat er staat vergeleken met de DOC en TCA FAQ`s? Dan zou je het inmiddels zelf wel weten. Wat zijn bijvoorbeeld de verschillen en zou je er een concrete vraag over kunnen stellen. Dat is ongeveer het niveau van GoT, heel veel zelf uitzoeken en vooral met gerichte vragen komen.
Verder lijkt het me niet onverstandig om eerst eens met je ouwe pentium 3 pc`tje te gaan overclocken ipv gelijk je badass conroe op te stoken. Zo leer je namelijk veel beter de basics en kan er weinig misgaan, tis toch je ouwe pc`tje en weinig meer waard dus als er iets stuk gaat, maakt het weinig uit. Als je die Conroe of je GX2 opstookt, is dat ff een wat groter probleem voor de portemonnee van je financiers....
/me ja, -ErikE- kan heel goed googlen ;)
nuttig leesvoer:
klik
klak
klok
[ Voor 23% gewijzigd door -ErikE- op 19-11-2006 00:48 ]
ik had het over een p3 met een oud moederbord. kan ik ook stress prime 2004 gebruiken?
  • -ErikE-
Verwijderd schreef op zondag 19 november 2006 @ 00:48:
dat zie ik nergens staan, een goeie TS bevat alle info zodat je dit soort dingen niet meer hoeft toe te voegen.
1. waarom niet?
2. probeer het en meld het hier, leert iedereen die het leest er wat van. Jij hebt de hardware staan, de software heb je tot je beschikking, go for it!
ok
ik heb een p3 intel celeron van 100fsb naar 119 fsb overgeclocked want bij 120fsb starte windows niet meer toen heb ik de voltage verhoogd en starte me systeem niet meer toen heb ik de bios gereset en toen weer naar 119fsb verhoogd. dus hier het resultaat.
Afbeeldingslocatie: http://img2.freeimagehosting.net/uploads/a83d5d29a9.jpg
  • Mr Alfabet
  • Laatst online: 01-08 02:39
Verwijderd schreef op zondag 19 november 2006 @ 01:14:
ok
wat is nou je vraag? lees de posts hierboven nog eens door, en lees ze nog eens door, want blijkbaar heb je nog steeds niet begrepen wat -ErikE- bedoelt in zijn eerste post over got.
je eerste vraag is hoe weet je of je stabiel stabiel is, die is al beantwoord doortheodouma, je 2e vraag is beantwoord door -ErikE-, je 3e vraag ook.
Als ik de pci bus vast zet op 33mhz is dat 5x zo sloom als 125 mhz kan ik het niet gewoon op
125mhz vast zetten? http://pedrorocha.planetaclix.pt/Bios_SysClocks.jpg
Word hier vmem bedoelt? mijn moederbord kan maar tot 2.5volt kan ik dit in een keer omhoog
gooien?
Welke temperatuur mag de conroe niet overschrijden?, is dit de temperatuur die in de faq staat of
zou ik me hier geen zorgen over moeten maken als ik waterkoeling heb en de vcore voltage niet
verhoog? ander loopt windows toch wel vast of crashed me systeem?
Dit is mijn 2e systeem voor het overclocken
processor: qx6700
moederbord: evga (foxcon) nforce 680i sli ready
http://www.xtremesystems.org/forums/showthread.php?t=122339
gpu: 2x bfg 8800gtx sli ready
ram: 2g corsair dominator cas4 sli ready
geluid: fatality fps x-ram
drives/brander: sony blue ray drive
psu: 1000kw
hdd: 4x sata2 36g 10krpm raid0
met waterkoeling, waarschijnlijk
  • TEAMIKKE
Temp zou ik niet boven de 50 uit willen laten komen met zo'n CPU. Andere vraag heb ik geen antwoord op. In 1 keer verhogen lijkt me iig niet verstandig. Waarom wil je DAT systeem überhaupt nog clocken? Die 8800GTX SLI zijn véél sneller dan je CPU dus dat bottleneckt sowiezo al. Maar als je hem overclockt zul je dat verschil niet opheffen.
*Pure interesse: Waarvoor heb je zo'n ding nodig! Gamen? Server lijkt me raar met zo weinig schijfruimte. Erg duur grapje voor een gamemachine. Tikje overdreven IMO maar erg leuk om te hebben natuurlijk >:)
  • rimpeldinky
  • Laatst online: 13:35
rimpeldinky
nani?
Verwijderd schreef op dinsdag 21 november 2006 @ 16:53:
PCI bus is ALTIJD 33 mhz, 125 blaas je meteen alles op... misschien bedoel je PCI-E bus speed? of de FSB?
gooien?
de ze info is gericht op ddr/ddr2 geheugen, jouw p3 heeft dat niet dus gewoon in kleine stapjes verhogen als nodig
een conroe mag 70 ~ 80 graden stressed hebben (in de core, dit meetje met intel TAT) als je systeem te warm word gaat alles ineens ENORM traag en als laatste zal het vastlopen (note dit is niet om stabiel over te clocken, stabiel zou ik je core rond de 60 ~ 70 houden maximaal)
processor: qx6700
psu: 1000kw
nou dit is een behoorlijk systeem :o hier zou ik heel voorzichtig mee overclocken, zou zonde zijn als je meteen wat opblaast! :) gewoon met stapjes van 5 fsb omhoog gaan tot het instabiel word, dan kijken of je een vcore verhoging nodig hebt etc :)
[ Voor 11% gewijzigd door rimpeldinky op 21-11-2006 17:12 ]
*burp*
rimpeldinky schreef op dinsdag 21 november 2006 @ 17:09:
ja ik bedoel pci bus en agp, waar vind ik deze instellingen meestal?
  • Hammetje
  • Laatst online: 14-10 22:09
je grote vriend :
Frequently Asked Questions T&C
heb je hier niet genoeg aan? Probeer google... Enkele duizenden resultaten zullen vast wel wat informatie hebben die je kan gebruiken
"Het is pas haute cuisine als het de frituurpan heeft gezien" - @VanRoyal (2021)
  • ThinkPad
  • Laatst online: 15:01
1000kw
Wie betaalt de stroomrekening? Jij of je ouders O-)
1000Watt = 1kW, hehe typfout
  • Renegade!
  • Laatst online: 22-12-2025
Ik weet niet wat je van plan bent maar als je er niets vanaf weet blijf er gewoon af :o Of zend het op naar mij natuurlijk ;) Wat ik wil zeggen is moest je dit systeem hebben dat je nogal het allersnelste hebt wat er op dit moment te krijgen is dus is het totaal niet nodig om nu al te gaan overklokken. Je zou beter enkele overklock topics hier op GoT volgen en tegen dat het overklokken nodig zal zijn zal je er dan alles vanaf weten.
Tot binnen enkele jaartjes! :w
  • Janssen
  • Laatst online: 09-08-2024
Jezus moet je de history van die gast zien http://gathering.tweakers...find/poster/185109/topics
En een 1000KW voeding? Hahahaha laat me niet lachen joh! PICS!
Janssen schreef op woensdag 22 november 2006 @ 08:47:
http://www.xoxide.com/pcpc-1kw-turbocool-quad-sli.html
:D!
  • sky-
sky-
\lA
1kw is toch wel wat anders dan 1000kw hoor
don't be afraid of machines, be afraid of the people who build and train them.
  • skelleniels
  • Laatst online: 10-10 23:53
Hoeveel heb jij betaald voro dat systeem? :o
http://specs.tweak.to/16567
  • TEAMIKKE
Teveel :P Die PSU kost al 450 dollar op die Xoxide site :o Erg duur grapje.
  • aMaZeR
  • Laatst online: 21-12-2025
Heb je je spullen nou al binnen Timocloned?
Het lijkt erop dat je allemaal vragen stel, terwijl je de hardware nog nieteens heb. Begin daar is mee, misschien dat je dan zelf al een hoop van je vragen beantwoord krijgt.
i7-7700K @ 5GHz (wc) | ASUS Maximus IX APEX | 2x8GB G.Skill Trident Z | Asus 1080 ti | Seasonic 750w PRIME
ik heb nog een vraag, klopt deze info, en zijn er nog tips voor het overclocken van mijn 2 8800gtx bfg's?
http://forums.guru3d.com/...fd355d833752509ea&t=74787
  • aMaZeR
hahaha....en gewoon doorgaan met vragen stellen......... 8)7
Heb je die kaarten al uberhaupt?
  • Janssen
Laat maar !
[ Voor 34% gewijzigd door Apen-nootjes op 29-11-2006 10:03 ]
