Hulpvaardig -->
Technical specifications
Operating system:
Microsoft® Windows® XP Professional
Processor &Chipset:
Mobile Intel® Centrino™ technology featuring:
Intel® Pentium® M processor with 2MB L2 Cache and 533Mhz or 400Mhz FSB. Supports Enhanced Intel® SpeedStep® Technology
Intel® 915GM Express chipset
Intel® PRO/Wireless 2200BG network connection (dual-mode 802.11b/g) Wi-Fi CERTIFIED™ solution, supporting Acer SignalUp™ wireless technology
Memory:
DDRII memory, upgradeable to 2 GB using two soDIMM modules
HDD:
ATA/100 hard disc drive
Storage
DVD-Dual Double Layer drive, or
DVD/CD-RW combo drive
Display:
15" XGA color TFT LCD with 1024 x 768 pixel resolution
16.7 million colours
Simultaneous LCD and CRT display with LCD panel resolution at 70 Hz
MPEG-2/DVD hardware-assisted capability
Graphics:
Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0
DualView™ support
Simultaneous LCD and CRT display, with LCD panel resolution at 70 Hz
MPEG-2/DVD hardware assisted capability
Multimedia:
Audio system with two built-in speakers
MS-Sound and Sound Blaster Pro™ compatible
Built-in microphone
Communication:
10/100Mbps Fast Ethernet; Wake-on-LAN ready
56K ITU V.92 modem with PTT approval; Wake-on-Ring ready
Intel® PRO/Wireless 2200BG network connection (dual band 802.11b/g) Wi-Fi CERTIFIED™ solution
Acer SignalUp wireless technology support
Bluetooth® (manufacturing) option
I/O Interfaces:
3x USB 2.0 ports
1x external display (VGA) port
1x PC Card slot (Type II)
1x Modem (RJ-11) port
1x Ethernet (RJ-45) port
1x speaker/ headphone/ line-out jack
1x microphone/ line-in jack
1x DC-in jack for AC adapter
Security:
Slot for Kensington lock
BIOS user and supervisor passwords
Power supply and battery:
ACPI 2.0 CPU power management standard: supports Standby and Hibernation power-saving modes
29.6W or 65W Li-ion battery pack
Up to 4 hours battery life for model using 8-cell battery
1.5-hour rapid charge, 3.5-hour charge-in-use
65 W AC Adapter
Keyboard &Special Controls:
88-/89-key Acer FineTouch™ keyboard with 5-degree curve,inverted "T" cursor layout, 2.5 mm (minimum) key travel, internationallanguage support
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key,user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® (for models with bluetooth/WLAN only)
Weight and dimensions:
364 (W) x 279 (D) x 33.9/38.9 (H) mm
2.91 kg for 15.0” LCD model
Je probleem is vrij algemeen omschreven en kan aan heel veel dingen liggen. Wat heb je zelf al geprobeerd? Doet de laptop het ook als de accu er niet inzit (op de netstroom)? Als eens een andere adapter geprobeerd?
- Je scherm kan brak zijn (al is het dan raar dat ie zomaar op stand by gaat en het wel weer doet als hij eruit komt).
- Je videokaart kan aan zijn einde zijn
Als je er echt niet zelf uitkomt, ga eens langs de winkel waar je hem gekocht hebt. Misschien kunnen die je verder helpen
