user-name-password Speedtouch 780WL KPN
  • 5.615 views sinds 30-01-2008
Hi,
I'm sorry I'm not writing in dutch, but I do not peak the language yet.
I'd like to access the CLI interface of the Speedtouch 780WL experia box thourough the telnet <IP> line in the propt of windows.
I've tried, but the default:
username: Administrator
password: <blank>
do not work.
Does anyone know how to help me out? Has anyone been succesful in accessing the router this way?
Thanks a lot,
Marco.
Username is probably admin and not administrator
  • McKaamos
McKaamos
Master of the Edit-button
As far as I know, it should be impossible to access the Experiabox in this way.
There is no default password for it.
I think you can change things through the KPN website. You should have gotten a frew booklets with the Experiabox explaining how.
speedtouch 780WL is experiabox right? Afaik, KPN always uses alcatel hardware, somtimes sold under a different name.
if not, try using the username and password you use for the webinterface.
[ Voor 27% gewijzigd door McKaamos op 09-11-2006 10:33 ]
Hi, thanks a lot.
In fact it is the experia box...
I'll try both way, with 'admin' and <blank>, or using the username and passoword for the webinterface.
What I would like (and need) to do is open a few more ports which are blocked by default.
Do you know any other way to do it, maybe?
Thanks again,
Marco.
  • NRGetic
  • Laatst online: 17-07-2024
NRGetic
Fanatic
What about downloading manuals?
http://www.speedtouchdsl.com/support.htm
.....and go to the 780WL section nearly at the bottom.
I used to be schizophrenic, but we are okay now.
Obviously, I've done it before posting my thread...
I knmow the rule: don't ask for help without helping yourself out before.
I've tried to follow the manuals. And in fact it was there that I found out that the default username should be <administrator> but that doesn't work.
I've tried to disable the firewall, but that has not changed things. Hence, I've tried with the CLI interface, but as I couldn't login I didn't get any further.
  • NRGetic
NRGetic
Fanatic
Check this out. This is the way you should login to CLI.
http://img353.imageshack.us/my.php?image=st780wlclimd5.jpg
When you are not able to login this way, a password must have been set earlier.
I assume you have bought this speedtouch from a computer or web shop?
