geen idee een 8500 x1600 pro nog wat, ff wat gegevens via riva tuner kunnen jullie hier wat mee?
$ffffffffff ----------------------------------------------------------------
$ffffffffff Northbridge information
$0400000000 Description : VIA KT400/600 series
$0400000001 Vendor ID : 1106 (VIA)
$0400000002 Device ID : 3189
$0400000003 AGP bus : revision 3.0
$0400000004 AGP status : enabled
$0400000005 AGP rate : 4x 8x supported, 8x selected
$0400000006 AGP SBA : hardwired, enabled
$0400000007 AGP FW : not supported
$ffffffffff Display adapter information
$0000000000 Description : Radeon X1600 Series
$0000000001 Vendor ID : 1002 (ATI)
$0000000002 Device ID : 71c2
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 3.0
$0000000005 AGP status : enabled
$0000000006 AGP rate : 4x 8x supported, 8x selected
$0000000007 AGP SBA : hardwired, enabled
$0000000008 AGP FW : supported, disabled
$0000000009 Base address 0 : e0000000 (memory range)
$000000000a Base address 1 : none
$000000000b Base address 2 : df000000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : 0000d800 (I/O range)
$000000000e Base address 5 : none
$ffffffffff ATI specific display adapter information
$0900000000 Graphics core : RV530 (4tmu)
$0900000002 Memory bus : 128-bit
$0900000001 Memory type : DDR2 SGRAM
$0900000003 Memory amount : 512MB
$0900000004 Core clock : 499.500MHz
$0900000005 Memory clock : 396.000MHz (792.000MHz effective)
$0900000006 Reference clock : 27.000MHz
$ffffffffff Ring bus memory controller timings
$0900000109 tCL , CAS latency : 7
$0900000108 tRC , Active to active : 26
$0900000110 tRCDR , RAS to CAS read : 6
$0900000120 tRCDRA, RAS to CAS read with auto-precharge : 6
$0900000111 tRCDW , RAS to CAS write : 6
$0900000121 tRCDWA, RAS to CAS write with auto-precharge : 7
$0900000112 tRP , Row precharge : 6
$0900000114 tRRD , Row active to row active command : 4
$0900000115 tR2W , Read to write turnaround : 7
$0900000117 tW2R , Write to read turnaround : 11
$0900000119 tR2R , Read to read turnaround : 6
