[Gentoo] X, dri op ati
Avond,
ik weet dat het een hel is met de ati drivers maar ik ben koppig en dus al dagen bezig mijn atikaart aiglx te laten draaien, werkt uiteraard niet want ik blijf al hangen bij het aan de praat krijgen van dri
x.org conf stukje van belang
Section "dri"
        Group 27
        Mode 0666
EndSection
Section "Module"
        Load  "dri"
        Load  "glx"
EndSection
Section "Device"
        Option     "UseFBDev"                   "true"
        Option     "EnablePageFlip"
        Driver      "radeon"
        VendorName  "ATI Technologies Inc"
        BoardName   "RV280 [Radeon 9200 PRO]"
        BusID       "PCI:1:0:0"
verder is /var/log/Xorg.0.log aan het liegen want die zegt (niet helemaal chronologisch)
29
30
31
32
33
34
35
36
37
38
39
(II) RADEON(0): [dri] Found DRI library version 1.2.0 and kernel module version 1.25.0
II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
        compiled for 7.1.1, module version = 1.0.0
        ABI class: X.Org Server Extension, version 0.3
(II) Loading extension XFree86-DRI
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(**) AIGLX enabled
(II) Loading extension GLX
(II) RADEON(0): [dri] Visual configs initialized
II) RADEON(0): [DRI] installation complete
(II) AIGLX: Loaded and initialized /usr/lib/dri/r200_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: Searching for BusID pci:0000:01:00.0
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
(**) RADEON(0): DRI Finishing init !
(II) RADEON(0): X context handle = 0x1
(II) RADEON(0): [drm] installed DRM signal handler
(II) RADEON(0): [DRI] installation complete
(**) RADEON(0): EngineRestore (32/32)
(II) RADEON(0): [drm] Added 32 65536 byte vertex/indirect buffers
(II) RADEON(0): [drm] Mapped 32 vertex/indirect buffers
(II) RADEON(0): [drm] dma control initialized, using IRQ 18
(II) RADEON(0): [drm] Initialized kernel GART heap manager, 5111808
(II) RADEON(0): Direct rendering enabled
allemaal positief dunkt mij
maar toch heb ik nog steeds
frits # glxinfo |grep direct
direct rendering: No
na nog wat gedoe vind deze jongen nu
frits # LIBGL_DEBUG=verbose glxinfo
name of display: :0.0
libGL: XF86DRIGetClientDriverName: 4.2.0 r200 (screen 0)
libGL: OpenDriver: trying $LIBGL_DRIVERS_PATH/r200_dri.so
libGL error: dlopen $LIBGL_DRIVERS_PATH/r200_dri.so failed ($LIBGL_DRIVERS_PATH/r200_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib/xorg/modules/dri/r200_dri.so
libGL error: dlopen /usr/lib/xorg/modules/dri/r200_dri.so failed (/usr/lib/xorg/modules/dri/r200_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to find driver: r200_dri.so
/usr/lib/xorg/modules/dri/r200_dri.so is er inderdaad niet , na wat googlen blijft dat die bij mesa zou moeten zitten
iemand een idee hoe ik dit oplos
