[LCD TV] LG 47LB2RF
  • 147 views sinds 30-01-2008
Afbeeldingslocatie: http://be.lge.com/ne/download/product/ETC/47LB2RF/47lb2rf_l_lge.jpg
Link: http://nl.lge.com/prodmod...lay=47LB2RF&model=NOTHING
Full-HD TV Lineup
LG LCD TV 47LB2RF model offers full HD picture quality. The
viewers can experience with true high definition resolution
(1080p), which is 200% clearer picture than normal HD. The
model has luxurious design in Noble Black color. It is
equipped with LG’s exclusive XDTM Engine and improves the
picture quality with its 3D Noise Reduction and 3D Digital
Comb Filter.
Omschrijving Model 47LB2RF
HD Ready Yes / Yes
Size (inch) 47 inch / 42 inch
System
Analog Terrestrial Yes
Module
Display 8 ms S-IPS LCD with EEFL Backlight
Picture Format 16:9 WideScreen
Resolution 1920x1080p
Contrast Ratio 1600:1 (Al) Dynamic
Brightness (Cd/m²) 550 cd/m²
Panel Mode 1920x1080, 1366x768, 1280x720, 1024x768, 852x480,
848x480, 640x480
XD Engine XD engine 3
XD Engine Control Auto, Advanced control
XD Engine Control Cinema, On/Off
XD Engine Control Black level, Low/Mid/High
XD Engine Control XD Contrast On/Off
XD Engine Control XD Colour On/Off
XD Engine Control XD Noice reduction
XD Engine Control MPEG NR 1-10
Cinema 3:2 mode (natural motion) Yes
Enhanced Line Doubler Yes
Auto Booster (Analog) Yes
Auto Off Yes
Color Reproduction Electronic part: 14 bit
Color Reproduction Panel: 8 bit
Supported Signals NTSC,PAL,SECAM,HD 720p,1080i,1080p,
VGA~UXGA
Picture Control Dynamic, Standard, Mild, User1,User2
DCDi Yes
Digital Comb Filter 3D
Color Temperature Control Normal, Warm, Cool,
User(Contrast/Brightness/Colour/Sharpness/Red/Green/Blue)
Enhanced Noise Reduction Yes (3D)
Aspect Ratio Correction Spectacle, Full, Orginal, 4:3, 16:9,
14:9, Zoom1, Zoom2
Sound
Speaker System 2Ch 8 units (incl woofer)
Sound Type NICAM A2
Audio Output 10w x 2 30 w woofer
AVL (Automatic Volume Leveller) Yes
Surround System Surround MAX
Sound Control XTS Pro,Flat,Music,Movie,Sports,User(7 band
Equalizer) Speaker On/Off
Equalizer 7 Band EQ
Function
Text TV Memory 1500 pages
AV Input Navigation Yes
Index Display Yes
Intelligent Eye Yes
X Studio No
PIP (Picture In Picture) Yes (Two Tuners)
Split Screen (Double Window) Yes (Two Tuners)
Auto/Manual Programing Yes
POP (1 3 Pictures) Yes (Two Tuners)
Clock Yes
Sleep Timer Yes
On/Off Timer Yes
Auto Off Yes
Key Lock Yes
TimeShift No
Connections (Side)
Memory Card Slot -
Component (Y/Pb/Pr) 1 (480i/p,576i/p,720p,1080i/p)
S-Video 1
AV (Composite) 1
Head Phone 1
Connections (Back)
Tuner 1 (Two tuner)
Scart (Full) 1 (RGB,S-video,Video In/out)
Scart (Half) 1 (S-video,Video in)
AV In (Composite) 1
AV Out (Composite) -
S-Video -
HDMI Input 2
DVI Input -
RGB In (D-sub 15pin) 1
RGB Out (D-Sub 15pin) -
PC Audio in 1
Control RS-232c
IR Jack G Link (IR Jack)
Head phone -
General
AC input 100~240V, 50/60Hz
Power Consumption 47LB2RF: 310W
Stand-by 3W
Dimension
WxHxD (mm) with Stand 47LB2RF: 1280x828x315.
WxHxD (mm) with out Stand 47LB2RF: 1280x719x137.
Weight (Kg) with Stand 47LB2RF: 64,24.
Dit lijkt me toch een mooie TV te zijn. Jammer genoeg kan ik er maar weinig (ervaringen) over vinden. Met behulp van dit topic kunnen we er misschien wat verzamelen en de discussie openen.
Toch wat meer info kunnen vinden:
Er loopt een thread op avsforum:
http://www.avsforum.com/avs-vb/showthread.php?t=725067
en eentje op avforum:
http://www.avforums.com/forums/showthread.php?t=417116
  • Tim45
  • Laatst online: 04-11-2024
Ben al een tijdje op zoek naar een nieuw scherm. Tot op heden kwam ik uit bij de Sony 46X2000, JVC 46Z7OB en de Toshiba 47WLG66P, maar nu ik deze LG ontdek heb is dit een goede kanshebber. Helaas is er idd nog weinig te vinden online, daar mij vertelt is dat deze nog niet leverbaar is in Nederland.
De specificaties zijn toch zeer interessant, maar nog meer de prijs. Bij Igor's Internet Shop staat hij voor € 2350, een koopje dus. Wat mij nog even tegen houdt is het online kopen. Heb nu al bij 2 apparaten gehad dat een bedrijf failliet ging.
  • Tim45
Heeft niemand iets te melden over dit prachtige scherm?
Deze week deze TV gezien, en ik moet zeggen: kijkhoek en zwartwaarde is om te janken... jammer
  • Tim45
Verwijderd schreef op donderdag 21 december 2006 @ 22:05:
Waar heb je hem gezien Bikks ? Volgens de specificaties zou deze LG toch een kijkhoek moeten hebben van 178-178, zoals vele anderen met dit formaat.
specificaties zeggen niet alles... Als ik moet afgaan op specs, dan zijn er ene hoop SUPER tv's. Het is hoe alles met het geheel kan omgaan hoe goed de TV het ervan afbrengt. TV heb ik gezien in Mediamarkt in Hasselt (België).
De beste TV qua kijkhoek en zwartweergave is de Sony X2000/W2000, maar dat zijn dan wel toestellen met een iets hoger prijskaartje
  • masser120
  • Laatst online: 13-08 04:43
Ik heb het scherm bij de mediamarkt gezien vandaag:
Mooie kleuren enzo, maar helaas: het zwart is veel minder zwart dan bij de meeste vergelijkbare schermen.
  • Pred87
  • Laatst online: 04-12-2025
S-IPS schermen staan er geloofk om bekend dat het contrast (en dus de zwartwaardes) niet al te best is. De kleurweergave is meestal wel een stuk beter.
Wat hebben sommigen hier toch met dat full HD gebeuren, alsof een TV met 1080P resolutie de heilige graal is. Heb zelf diverse LG (lcd) toestellen aan gezien (zowel in winkels als prive thuis bij mensen) en vind de zwart weergave bij dit merk ronduit teleurstellend. OK de heel betaalbare prijs maak weer veel goed, maar ik krijg soms de indruk dat de meeste kopers alleen afgaan op het getal 1920x1080P, en dan pas verder kijken! :o
Als je echt mooi zwart wilt zien, kun je beter Philips kopen (wel plasma uit de Cineos serie) :)
  • basset
  • Laatst online: 09-10 13:49
Verwijderd schreef op vrijdag 29 december 2006 @ 04:50:
Als je ECHT mooi zwart wil moet je gewoon Plasma kopen en niet eens de Philips, echter zijn er ook andere redenen om niet een plasma te kopen. Hangt van persoonlijke voorkeur af.
Ik vind de huidige LG's en Philipsen wel "zwarter" dan de sharps, en sony's. Deze hebben een blauwe zweem over hun zwart, waarbij de LG/Philips panelen dat niet meer hebben als je er recht voor zit. In hoeverre het detail in zwart er is kan ik niet zo beoordelen. Daar moet ik meer schermen goed voor kunnen bekijken.
Hop,hop,hop!
