Krijg USB hdd niet gemount
  • 145 views sinds 30-01-2008
  • TommyGun
  • Laatst online: 09-10 09:02
TommyGun
Stik er maar in!
Hallo;
Ten eerste heb ik al het een en ander gezocht maar ik kom er niet helemaal in uit. Ik draai ClarkConnect (CentOS) en probeer een USB hdd te mounten. Hierbij wat commando's die ik uit heb gevoerd en de daarbij horende resultaten;
[root@gateway ~]# lsusb
Bus 001 Device 011: ID 0c0b:b311 Dura Micro, Inc. (Acomdata)
Bus 001 Device 002: ID 03f0:2304 Hewlett-Packard DeskJet 656c
Bus 001 Device 001: ID 0000:0000
29
30
31
[root@gateway ~]# dmesg| grep usb
usbcore: registered new driver usbfs
usbcore: registered new driver hub
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
usb 1-1: new full speed USB device using address 2
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 1 proto 2 vid 0x03F0 pid 0x2304
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
usb 1-2: new low speed USB device using address 5
usb 1-2: device not accepting address 5, error -110
usb 1-2: new low speed USB device using address 6
usb 1-2: device not accepting address 6, error -110
usb 1-1: control timeout on ep0in
usb 1-2: new low speed USB device using address 9
usb 1-2: device not accepting address 9, error -110
usb 1-2: new low speed USB device using address 10
usb 1-2: device not accepting address 10, error -110
usb 1-2: new full speed USB device using address 11
usbcore: registered new driver usb-storage
drivers/usb/class/usblp.c: usblp0: out of paper
drivers/usb/class/usblp.c: usblp0: ok
[root@gateway ~]# mount
/dev/sda3 on / type ext3 (rw)
none on /proc type proc (rw)
none on /sys type sysfs (rw)
none on /dev/pts type devpts (rw,gid=5,mode=620)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /boot type ext3 (rw)
none on /dev/shm type tmpfs (rw)
none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
29
30
31
32
33
34
35
36
37
[root@gateway ~]# cat /proc/bus/usb/devices
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=0000 ProdID=0000 Rev= 2.06
S:  Manufacturer=Linux 2.6.9-27.ccsmp ohci_hcd
S:  Product=OHCI Host Controller
S:  SerialNumber=0000:00:0f.2
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=  0mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   2 Ivl=255ms
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=12  MxCh= 0
D:  Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=03f0 ProdID=2304 Rev= 1.10
S:  Manufacturer=HEWLETT-PACKARD
S:  Product=DESKJET 656C
S:  SerialNumber=TH19118FMR
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=  2mA
I:  If#= 0 Alt= 0 #EPs= 2 Cls=07(print) Sub=01 Prot=01 Driver=usblp
E:  Ad=81(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
I:  If#= 0 Alt= 1 #EPs= 2 Cls=07(print) Sub=01 Prot=02 Driver=usblp
E:  Ad=01(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=82(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 11 Spd=12  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=0c0b ProdID=b311 Rev= 1.19
S:  Manufacturer=DMI
S:  Product=Ultra HDD
S:  SerialNumber=073006001586
I:  If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Staan wat stukjes in van m'n printer enzo maar goed. Hoe kan ik nu die drive mounten? Ik weet hoe je vaste schijven kunt mounten maar ik kan niks zonder ik een naam weet of wat dan ook. Zou zo niet weten waar ik moet zoeken.
Iemand die hulp kan bieden?
B.v.d
  • TommyGun
TommyGun
Stik er maar in!
Okay ik heb het al voor elkaar gekregen met behulp van http://www.novell.com/coolsolutions/feature/11637.html
Toch bedankt.
  • Nielson
  • Laatst online: 08:35
Normaal geproken worden usb mass storage devices als virtuele scsi schijf gezien, dus bijvoorbeeld als /dev/sda. Waar heb je momenteel CC op geinstalleeerd, want het lijkt alsof nu je / (/dev/sda3) en /boot (/dev/sda1) ook al op een scsi of usb schijf staan. Doe eens fdisk -l om te kijken welke schijven er weergegeven worden.
/edit Ah, had eerst moeten f5'en :)
[ Voor 5% gewijzigd door Nielson op 01-11-2006 21:06 ]
  • TommyGun
TommyGun
Stik er maar in!
Ja je had gelijk, het was sdb1 :) Zie mijn post boven je.
Het enige probleem wat ik nu heb is dat ik niet kan schrijven. Moest denken aan NTFS maar heb deze schijf eerder gebruikt maar toen gewoon via IDE. Wel vreemd dus. Helaas krijg ik bij cfdisk een "Command not found".
[root@gateway ~]# fdisk /mnt/sdb1/
last_lba(): I don't know how to handle files with mode 41ff
U zult geen partitietabel kunnen wegschrijven.
[ Voor 99% gewijzigd door TommyGun op 01-11-2006 21:13 ]
  • TommyGun
TommyGun
Stik er maar in!
Edit; foutje. Zie hierboven
[ Voor 81% gewijzigd door TommyGun op 01-11-2006 21:09 ]
  • Nielson
TommyGun schreef op woensdag 01 november 2006 @ 21:06:
Moet je niet fdisk /dev/sdb gebruiken ?
  • TommyGun
TommyGun
Stik er maar in!
Nielson schreef op woensdag 01 november 2006 @ 21:29:
[root@gateway ~]# fdisk /dev/sdb
Kan /dev/sdb niet openen
  • capedro
  • Laatst online: 20-05 09:15
En als je eens het volgende uitvoerd:
fdisk -l /dev/sd?
Fdisk kijkt dan welke sd-devices te lezen zijn... :P
Een voorbeeldje:
opteron-tux ~ # fdisk -l /dev/sd?
Disk /dev/sda: 81.9 GB, 81964302336 bytes
255 heads, 63 sectors/track, 9964 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1          17      136521   83  Linux
/dev/sda2              18         142     1004062+  82  Linux swap / Solaris
/dev/sda3             143        9964    78895215   83  Linux
opteron-tux ~ #
en zo kan je ook andere sd devices met partities opsporen 8)
hopelijk is dit geen mosterd na de maaltijd
[ Voor 4% gewijzigd door capedro op 02-11-2006 14:26 ]
My weblog
  • TommyGun
TommyGun
Stik er maar in!
Zie boven je, ik dien hem wss te formateren naar FAT32. Maar ik heb geen flauw benul van hoe ik dat moet doen. Had al wat gezocht maar dat ging meer over NTFS versus Linux
  • TommyGun
TommyGun
Stik er maar in!
Ik heb het dus al voor elkaar gekregen. Geformat met mke2fs -j /dev/hdxx
Anyway; hij is wel traag met benaderen. Heb er TorrentFlux op draaien en duurt wel een minuut of 2 / 4 / 6 voor ik er eindelijk op zit. (Stuk of 20 torrents tegelijk.) Daarbij haal ik ook maar 40kb's ofzo als ik ze wil leechen naar m'n werkstation. Ligt dit gewoon aan het feit dat het USB is? Vroegah toen ik gewoon direct een IDE schijf gebruikte ging het super snel.
(Torrents downen wel met m'n volle speed, 900kb's zo ongeveer)
Danke
Initializing USB Mass Storage driver...
scsi3 : SCSI emulation for USB Mass Storage devices
  Vendor: DMI       Model: Ultra HDD         Rev: 1.19
  Type:   Direct-Access                      ANSI SCSI revision: 02
SCSI device sdb: 156301488 512-byte hdwr sectors (80026 MB)
sdb: assuming drive cache: write through
 sdb: sdb1 < sdb5 >
Attached scsi disk sdb at scsi3, channel 0, id 0, lun 0
USB Mass Storage device found at 3
USB Mass Storage support registered.
kjournald starting.  Commit interval 5 seconds
EXT3 FS on sdb5, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
usb 1-2: control timeout on ep0in
[ Voor 46% gewijzigd door TommyGun op 06-11-2006 20:03 ]
  • laurencevde
  • Laatst online: 02-10-2025
je hebt hem aan een usb-1 poort gehangen, en da's inderdaad niet zo snel...
Have a taste of freedom. It is sometimes a bitter pill. To me though, this is the sweetness of the GPL
  • TommyGun
TommyGun
Stik er maar in!
Hm dat doet me ergens aan denken. Ik heb een schijf van 320 GB (Toshiba, WD) zo kant-en-klaar gekocht en die werkt perfect op mijn _werkstation_. Als ik daar echter mijn "home-made build" 80gb schijf aan hang (die dus aan mijn server hangt) dan krijg ik een melding dat hij op een USB1 port zit. Terwijl dit bij de Toshiba niet zo is. (Ja, zelfde kabel, zelfde stroom.)
Zou er misschien iets mis kunnen zijn met de connector van de usb behuizing? Heb al verschillende jumper settings geprobeerd maar dat was het niet. Of zie jij echt in mijn post hierboven dat de port usb 1 is? Zoja; waaraan zie je dat?
Bedankt
[ Voor 8% gewijzigd door TommyGun op 07-11-2006 16:30 ]
