[2003] Event ID 781, 4625 en 10026
  • 397 views sinds 30-01-2008
  • Akuma2000
  • Laatst online: 21-10 11:58
Heeft iemand enig idee wat deze Event ID's betekenen?
Het is geen error melding, maar gewoon een informatie punt.
Event Type: Information
Event Source: COM+
Event Category: None
Event ID: 781
Date: 1-11-2006
Time: 11:21:43
User: N/A
Computer: MIJNPC
Description:
The COM+ sub system is suppressing duplicate event log entries for a duration of 86400 seconds. The suppression timeout can be controlled by a REG_DWORD value named SuppressDuplicateDuration under the following registry key: HKLM\Software\Microsoft\COM3\Eventlog.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Source: EventSystem
Event ID: 4625
Date: 1-11-2006
Time: 11:21:40
User: N/A
Computer: MIJNPC
Description:
The EventSystem sub system is suppressing duplicate event log entries for a duration of 86400 seconds. The suppression timeout can be controlled by a REG_DWORD value named SuppressDuplicateDuration under the following registry key: HKLM\Software\Microsoft\EventSystem\EventLog.
Event Source: DCOM
Event ID: 10026
Date: 1-11-2006
Time: 11:21:31
User: N/A
Computer: MIJNPC
Description:
The COM sub system is suppressing duplicate event log entries for a duration of 86400 seconds. The suppression timeout can be controlled by a REG_DWORD value named SuppressDuplicateDuration under the following registry key: HKLM\Software\Microsoft\Ole\EventLog.
Ik heb al flink zitten googlen en op eventid.net gekeken, op de microsoftwebsite etc etc. Kan er echt weinig over vinden :S
Misschien dat een GoT'er het hier weet :D
Alvast bedankt voor jullie reacties.
HighFlow.nl // PinballShop.nl
  • Akuma2000
Hmm.. misschien heeft het te maken met het volgende?:
Event Source: MSDTC
Event Category: TM
Event ID: 4193
Date: 31-10-2006
Time: 22:47:00
User: N/A
Computer: MIJNPC
Description:
MS DTC started with the following settings (OFF = 0 and ON = 1):
Security Configuration:
Network Administration of Transactions = 0,
Network Clients = 0,
Inbound Distributed Transactions using Native MSDTC Protocol = 0,
Outbound Distributed Transactions using Native MSDTC Protocol = 0,
Transaction Internet Protocol (TIP) = 0,
XA Transactions = 0
Filtering Duplicate events = 1
  • BtM909
BtM909
Watch out Guys...
Ik vind overigens wel weer wat interessante posts via Google groups :)
Krijg je ook nog andere foutmeldingen in je eventviewer? Je zou eventueel de waarde kunnen aanpassen in je registry (als je tenminste ervaring ermee hebt of weet hoe je het moet doen) en dan kijken of er andere foutmelden (die nu gesuppressed worden) zichtbaar worden in je eventviewer.
  • Akuma2000
Ik geen ervaring met registry etc. Ik denk dat daar beter van af kan blijven :)
Ik heb volgens mij echt alle google groups doorgelezen, maar daar vond ik helaas ook mijn antwoord niet. :(
Ik heb geen andere foutmeldingen.
Maar bovenstaande zijn ook geen foutmeldingen he.
Is gewoon informatie. Ik vroeg me dus af of jullie dit ook hadden en of het normaal is.
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Dit is normaal als er zich veel meldingen voorkomen. Als je de oorspronkelijke dcom-error oplost zal dit ook weggaan :)
Wat had je zelf allemaal al gevonden? En welk OS gebruik je?
[ Voor 21% gewijzigd door sanfranjake op 01-11-2006 12:47 ]
Mijn spoorwegfotografie
sanfranjake schreef op woensdag 01 november 2006 @ 12:46:
idd, je zal de dcom error die voor deze meldingen verschijnt moeten oplossen. De meldingen die je hier laat zien, geven slechts aan dat dubbele meldingen worden onderdrukt om een overflow aan meldingen tegen te gaan.
  • Akuma2000
Ik draai Windows Server 2003 Enterprise.
Ik heb verder zelf niks gevonden (geen errors in applicaties en system).
Ik zou dus echt niet weten wat het is.
Maar is dit schadelijk of heeft dit nog erge dingen tot gevolg? Anders laat ik dit gewoon zo als dit niks ernstigs is.
  • sanfranjake
sanfranjake
(overleden)
Ik zet even [2003] vooraan de topictitel. Wat is er niet duidelijk aan dcom error? Door even te googlen kom je er snel genoeg achter wat dat betekent, en als je je eventlogs goed bekijkt zie je die error toch wel minimaal 1 keer voorbijkomen.
