Al redelijk vaak in verschillende varianten gezien meestal een programma die de layout vern**kt.
Op deze plek in de registry kun je alle programma's vinden. Maar het is echt een rot klus om diegene te vinden die het probleem geeft.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
[edit]
Was even zoeken met google maar check het volgende topic en dan de 2de post: http://help.lockergnome.c...ograms-ftopict229824.html
Ik quote het maar even:
[edit]
Courtesy of Kelly
Microsoft-MVP Windows� XP-Shell/User
2004 Windows MVP "Winny" Award
Add or Remove - White Space
http://www.kellys-korner-xp.com/xp_a.htm#ws
[[This is generally due to the DisplayIcon having a negative number. From
here you can either remove the negative number or remove the last
application listed:
Start/Run/Regedit:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{} ]]
AutoCad Fix
http://www.kellys-korner-...s/autocadaddremovefix.zip
Autodesk Land Desktop 3 Fix
http://www.kellys-korner-...ddesktop3-addre...efix.zi
I have AutoCAD LT 2000i. The white space in Add or Remove Programs usually
shows up after the AutoCAD LT 2000i listing. If you want to tweak the
registry...
{5783F2D7-0065-0409-0000-0060B0CE6BBA}
Value Name: DisplayIcon
Value Type: REG_SZ
Value Data: C:\Program Files\AutoCAD LT 2000i\aclt.exe,-1
Notice the aclt.exe,-1?? You can change it to read aclt.exe,1
Or you can run one of the fixes. I have both autocadaddremovefix.zip &
autodesk-landdesktop3-addremovefix.zip. They both include icons.
autocadaddremovefix.vbs is the one that works for me. It's easier to use
the fix than changing the -1.
I get the white space in Add or Remove Programs every time that I add or
remove a program. It isn't always AutoCAD LT that has the white space after
it, sometimes it's another program. At any rate, one of the fixes will
work. Until the next time. Wink
autocadaddremovefix.vbs adds an autocad.ico icon to the %systemroot%\web
folder. It also adds this to the registry >>
{5783F2D7-0101-0409-0000-0060B0CE6BBA}
Value Type: REG_EXPAND_SZ
Value Data: %systemroot%\web\autocad.ico
autodesk-landdesktop3-addremovefix.vbs adds an acad.ico icon to the
%systemroot%\web folder. It also adds this to the registry >>
{5783F2D7-0138-0409-0000-0060B0CE6BBA}
Value Data: %systemroot%\web\acad.ico
From snowman...
AutoCAD 2002 is
Hope this helps. Let us know.
Wes
[ Voor 96% gewijzigd door Verwijderd op 25-10-2006 20:46 ]
Het is gelukkig nu nog maar alleen zwart wit, maar ben er nog niet helemaal dus.Verwijderd schreef op woensdag 25 oktober 2006 @ 20:41:
[edit]
/edit:
Het is me gelukt, het was "Electronic Arts Game Updater" in die zelfde Uninstall map in het register, ga nu alleen ff kijken hoe ik het kan fixen maar dat zal nog wel ff duren denk ik. Deze Updater zat bij Need for Speed Porsche Unleashed.
[ Voor 14% gewijzigd door Speedy55 op 25-10-2006 23:00 ]
ik had het zelfde probleem. het lag ook aan de EA game updater. ik heb uit het register {hkey_local_machine-->software-->microsoft-->windows-->current_version-->uninstall} de EA game updater gedelete.
het probleem was daarmee opgelost bij mij
