Installatie van Postgresql
  • Varienaja
  • Laatst online: 14-06-2025
Varienaja
Wie dit leest is gek.
Hoi. Ik heb een iMac met OSX 10.4.8. Alles is bijgewerkt. Ik heb X11 en de develop-tools geinstalleerd van de OSX-installatiecd.
Ik ben nu bezig postgresql te installeren vanuit darwinports. Dat is helemaal goed gedaan, maar nu moet ik nog een laatste commando ingeven om een default database aan te maken. En dat gaat helaas mis:
29
sudo su postgres81 -c '/opt/local/lib/postgresql81/bin/initdb -D /opt/local/var/db/postgresql81/defaultdb'
Password:
The files belonging to this database system will be owned by user "postgres81".
This user must also own the server process.
The database cluster will be initialized with locale C.
fixing permissions on existing directory /opt/local/var/db/postgresql81/defaultdb ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/global ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_xlog ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_xlog/archive_status ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_clog ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_subtrans ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_twophase ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_multixact/members ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_multixact/offsets ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/base ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/base/1 ... ok
creating directory /opt/local/var/db/postgresql81/defaultdb/pg_tblspc ... ok
selecting default max_connections ... 10
selecting default shared_buffers ... 50
creating configuration files ... ok
creating template1 database in /opt/local/var/db/postgresql81/defaultdb/base/1 ... FATAL:  could not create shared memory segment: Invalid argument
DETAIL:  Failed system call was shmget(key=1, size=1318912, 03600).
HINT:  This error usually means that PostgreSQL's request for a shared memory segment exceeded your kernel's SHMMAX parameter.  You can either reduce the request size or reconfigure the kernel with larger SHMMAX.  To reduce the request size (currently 1318912 bytes), reduce PostgreSQL's shared_buffers parameter (currently 50) and/or its max_connections parameter (currently 10).
        If the request size is already small, it's possible that it is less than your kernel's SHMMIN parameter, in which case raising the request size or reconfiguring SHMMIN is called for.
        The PostgreSQL documentation contains more information about shared memory configuration.
child process exited with exit code 1
initdb: removing contents of data directory "/opt/local/var/db/postgresql81/defaultdb"
Ik moet dus OF shmmax verhogen OF max_connections/shared_buffers in postgresql.conf lager zetten.
shmmax heb ik geprobeerd te veranderen in /etc/rc maar dat heeft tot effect dat de waarde voor shmmax nu al -1 gerapporteerd wordt!?
postgresql.conf heb ik gevonden in /Library/postgreSQL8/data maar daar staan hele andere settings voor max_connections en shared_buffers, dus dit is niet het config-bestand dat wordt gebruikt bij het aanmaken van een default database?
Hoe krijg ik m'n postgresql-installatie werkend?
Siditamentis astuentis pactum.
  • JaQ
  • Laatst online: 22:23
JaQ
Tip van flip: google eens op shmmax en OS X. Eerste hit: en dan doorbladeren levert:
> skittlebrau:~ postgres$ grep shm /etc/rc
Luke-Lonergans-Computer:~ lukelonergan$ cat /etc/sysctl.conf
kern.sysv.shmall=327680
kern.sysv.shmmax=335544320
#kern.sysv.shmall=268435456
#kern.sysv.shmmax=268435456
> skittlebrau:~ postgres$ sysctl -a | grep shm
Luke-Lonergans-Computer:~ lukelonergan$ sysctl -a | grep shm
kern.sysv.shmmax: 335544320
kern.sysv.shmmin: 1
kern.sysv.shmmni: 32
kern.sysv.shmseg: 8
kern.sysv.shmall: 327680
(uit de postgresql maillist)
have fun
En ook deze link ziet er goed uit:
http://developer.postgres...res/kernel-resources.html
[ Voor 8% gewijzigd door JaQ op 24-10-2006 22:33 ]
Egoist: A person of low taste, more interested in themselves than in me
  • Varienaja
Varienaja
Ik had al geprobeerd die shmmax te verhogen, maar de grootte daarvan moet blijkbaar deelbaar zijn door 4096. Nu is alles voor elkaar.
Nu wil de database niet starten, omdat hij als user postgres gestart moet worden (andere gebruikers hebben geen toegang tot de database-bestanden), maar daar zal ik met wat prutsen wel uitkomen. Dank voor de hulp zover! :-)
