[2003] Kan geen mirror aanmaken
Ik heb 2 schijven van elk 20 gb in mijn server, C (system volume) is 10 gb, van de rest wil ik een data partitie maken die gemirrored word met een 10 gb partitie van mijn andere schijf. Krijg het niet voor elkaar. De help van 2003 geeft dit aan:
Open Computer Management (Local).
In the console tree, click Disk Management.
Where?
Storage
Disk Management
Right-click the unallocated space on one of the dynamic disks on which you want to create the mirrored volume, and then click New Volume.
In the New Volume Wizard, click Next, click Mirrored, and then follow the instructions on your screen.
Notes
To perform this procedure on a local computer, you must be a member of the Backup Operators group or Administrators group on the local computer, or you must have been delegated the appropriate authority. To perform this procedure remotely, you must be a member of the Backup Operators group or Administrators group on the remote computer. If the computer is joined to a domain, members of the Domain Admins group might be able to perform this procedure. As a security best practice, consider using Run as to perform this procedure.
To open Computer Management, click Start, point to Settings, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
You can create mirrored volumes only on computers running Windows 2000 Server, Windows 2000 Advanced Server, Windows 2000 Datacenter Server, or the Windows Server 2003 family of operating systems.
You need two dynamic disks to create a mirrored volume.
You can mirror an existing simple volume.
Mirrored volumes are fault tolerant and use RAID-1, which provides redundancy by creating two identical copies of a volume.
Mirrored volumes cannot be extended.
Both copies (mirrors) of the mirrored volume share the same drive letter.
Er staat dus (in het vet) dat ik op de unallocated space van een van de schijven rechst moet klikken en dan "New Volume" moet kiezen, deze optie staat er helemaal niet bij.. Er staat alleen "New Partition" Wie kan mij helpen?
Deze mag dicht, is al gelukt.
  • Zwelgje
  • Laatst online: 17-08 09:02
en nu de oplossing graag, want zo werkt dat hier op een forum
Geef dan nog even aan hoe, da's handig voor mensen die misschien hetzelfde probleem hebben :)
  • Archie_T
  • Laatst online: 20:56
Geen dynamic disks?
  • Zwelgje
onzin, juist om te mirroren moet je dynamic disks hebben
  • Archie_T
Zwelgje schreef op zondag 22 oktober 2006 @ 17:54:
Dat bedoel ik ook ;) Hij had dus geen dynamic disks, en dus geen New Volume maar alleen New Partition. Had wellicht iets duidelijker moeten zijn.. Sowwy
  • Zwelgje
Archie_T schreef op zondag 22 oktober 2006 @ 17:56:
no hard feelings :>
Idd geen dynamic disks, nu wel aangepast.
Thx voor de reacties.
  • Zwelgje
maar... maar... in je openingspost staat nb die tekst in het bold :X
ik citeer:
einde citaat
[ Voor 57% gewijzigd door Zwelgje op 22-10-2006 22:35 ]
Zwelgje schreef op zondag 22 oktober 2006 @ 22:34:
ik citeer:
einde citaat
Ja sorry niet goed gekeken,
