Mtkflash -> sata drive
  • Remko
  • Laatst online: 19-10 09:39
Hoi,
Ik probeer een aangepast firmware te zetten op een sata drive, echter kom ik er niet helemaal uit Mtkflash herkent de drive niet en dient dus aanpast te worden, hieronder de info:
2. Finding The Correct Values
Install your SATA Controller's Driver (If it isn't Already Installed).
You will need to Open up MSInfo32.exe (Start>Run, Type "MSinfo32.exe" w/o Quotes, Press OK), with MSinfo open (Should Look Something Like This) Click the + next to "Components", Click the + next to "Storage" Now Click on SCSI (Some Chipsets Have this Info under IDE) You Should See Something That looks Like This
Name ****** ATA Controller
Manufacturer
Status OK
PNP Device ID PCI\VEN_2211&DEV_4433&SUBSYS_31491106&REV_80\3&61A AA01&0&78
I/O Port 0x00006655-0x00006662
I/O Port 0x00000000-0x00000003
I/O Port 0x00008877-0x00008884
I/O Port 0x00000000-0x0000000F
I/O Port 0x00000000-0x000000FF
IRQ Channel IRQ 20
Driver c:\windows\system32\drivers\driver.sys (5.1.2600.201, 74.63 KB (76,416 bytes), 5/15/2006 7:00 AM)
All of that Should Look Different in Your Info, Next to Name it Should Say Something About "****** ATA" if it Doesn't Try Scrolling Down and/or Make Sure Your in the Right Place,
What You Are looking For in This is 8bytes (16 Numbers/Letters) That MTKFlash Can Identify Your Chipset with, The First 4bytes are Found in The "PNP Device ID" (2 Numbers/Letters = one byte)
So From This Example Your Line So Far Should be 11223344 (Need it Explained Better? Click Here)
The Next 4Bytes are Found in 2 Different Lines of "I/O Port" Hex Values, You Want to Identify The 2 Lines That Have a 7Byte Difference, Extract the Last 4 Digits of the First Section of Numbers/Letters from Them and Swap the 2 Bytes (As You did with The "PNP Device ID" Line)
This is Only Known to Work if You Use The 2 "I/O Port" lines With a Difference of 7 in Order (as Shown Above), As They are Values for The Primary Master and Slave SATA Device,
So in this Example Your line Should be 55667788 (Need it Explained Better? Click Here),
Put Together The 4bytes of Hex (8 Numbers/Letters) That You Have From The "PNP Device ID" Line and the 4 You have from The "I/O Port" Lines and You Have The Values You Need to Insert in to Your MTKFlash.exe File.
Note: Your "I/O Port" Values can be found in "I/O Port" Line's 1 and 3.
De vraag is dus, wat zou dan onderstaande dienen te zijn? Bovenstaande voorbeeld is met cijfers maar hier zitten ook letters in :?
Naam NVIDIA nForce 430/410 ****** ATA Controller
Fabrikant NVIDIA Corporation
Status OK
PNP-apparaat-ID PCI\VEN_10DE&DEV_0266&SUBSYS_02661849&REV_A1\3&267 A616A&0&70
I/O-poort 0x00000F80-0x00000F87
I/O-poort 0x00000F00-0x00000F03
I/O-poort 0x00000E80-0x00000E87
I/O-poort 0x00000E00-0x00000E03
I/O-poort 0x0000E000-0x0000E00F
Geheugenadres 0xFEBBD000-0xFEBBDFFF
IRQ-kanaal IRQ 21
