SSH ontoegankelijk na update
  • dawuss
  • Laatst online: 01-02 20:46
dawuss
gadgeteer
Sinds ik bij mijn debian server een security update heb uitgevoerd (waarvan ik nu niet meer bij de logs kan om te achterhalen wat er nu precies allemaal geupdate is), is deze via ssh ontoegankelijk geworden.
Ter illustratie:
Vanaf een machine met public key authentication
29
30
31
32
33
34
mango:~ dawuss$ ssh -vv dawuss.student.utwente.nl
OpenSSH_4.2p1, OpenSSL 0.9.7i 14 Oct 2005
debug1: Reading configuration data /etc/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to dawuss.student.utwente.nl [130.89.170.243] port 22.
debug1: Connection established.
debug1: identity file /Users/dawuss/.ssh/identity type -1
debug2: key_type_from_name: unknown key type '-----BEGIN'
debug2: key_type_from_name: unknown key type 'Proc-Type:'
debug2: key_type_from_name: unknown key type 'DEK-Info:'
debug2: key_type_from_name: unknown key type '-----END'
debug1: identity file /Users/dawuss/.ssh/id_rsa type 1
debug1: identity file /Users/dawuss/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_3.8.1p1 Debian-8.sarge.4
debug1: match: OpenSSH_3.8.1p1 Debian-8.sarge.4 pat OpenSSH_3.*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_4.2
debug2: fd 3 setting O_NONBLOCK
debug1: An invalid name was supplied
Configuration file does not specify default realm
A parameter was malformed
Validation error
Validation error
debug1: SSH2_MSG_KEXINIT sent
Connection closed by 130.89.170.243
Vanaf een andere Mac:
OpenSSH_3.4p1+CAN-2004-0175, SSH protocols 1.5/2.0, OpenSSL 0x0090609f
debug1: Rhosts Authentication disabled, originating port will not be trusted.
debug1: ssh_connect: needpriv 0
debug1: identity file /Users/dawuss/.ssh/id_rsa type -1
debug1: match: OpenSSH_3.8.1p1 Debian-8.sarge.4 pat OpenSSH*
debug1: Local version string SSH-2.0-OpenSSH_3.4p1+CAN-2004-0175
Read from socket failed: Connection reset by peer
debug1: Calling cleanup 0x17d98(0x0)
En voor de zekerheid ook nog even vanaf een linux machine
[dawuss@www ~]$ ssh -vv dawuss@dawuss.student.utwente.nl
OpenSSH_4.4p1, OpenSSL 0.9.8d 28 Sep 2006
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
/etc/ssh/ssh_config line 39: Unsupported option "GSSAPIAuthentication"
debug1: identity file /home/dawuss/.ssh/identity type -1
debug1: identity file /home/dawuss/.ssh/id_rsa type -1
debug1: identity file /home/dawuss/.ssh/id_dsa type -1
debug1: Local version string SSH-2.0-OpenSSH_4.4
Het gaat dus om OpenSSH 3.8.1 op een Debian machine (maar dat stond ook al in de logs). Googlen op de verschillende debug messages leverde me vooral anderen op met gelijke problemen, maar geen oplossingen.
Heeft iemand enig idee wat hier aan de hand is?
micheljansen.org
Fulltime Verslaafde Commandline Fetisjist ©
  • CyBeR
CyBeR
Je bent een prutser.
Nah, 't is vanaf deze kant niet te zeggen wat er aan de hand is. Je zult bij die machine langs moeten gaan, of iemand van de colo (?) dat even laten doen.
  • BoAC
  • Laatst online: 19-10 15:00
BoAC
Memento mori
Als libc is geupdated heb je dikke kans dat het herstarten van de ssh daemon voldoende is.
Dat is een bekend probleem en ik heb het ook wel eens gehad ;)
Ik heb al een paar libc updates gehad op debian unstable, en daar stelde hij telkens automatisch voor om sshd ff te restarten.
