VPN PPTP connection problem (OS X 10.4.8)
  • 103 views sinds 30-01-2008
Hi,
I can't get a VPN connection to work, (using linksys wrt54g v.2.2) on my macbook. Getting Connecting, authenticicating, disconnecting and then" The connection was terminated by the communication device. Please verify your settings and try again." In my opinion it cannot be the router that's the problem because my roommate can get it to work using the same wireless network.
I opened (tried...) ports 1723TCP and 1024-65535TCP. Firewall off etc. The manual (university) futhermore states that ip protocol 47 (GRE) must be allowed but if I understand it correctly this has something to do with the router (I have enbled PPTP-Pass Through).
Maybe I didn't get the opening of the ports right I created new ones by opening system preferences>shared>firewall>new>other>name=VPN>TCP portnumber(s)=1723 and the same for the 1024-65535 ports
Please help thnx,
Tom
  • Viper®
Try changing the MTU size to a lower value.
You could try to change it as well in the router
source: http://nscsysop.hypermart.net/mtusize.html
There are times when it is necessary to set the MTU size on a PC to a lower value than the default, in order to successfully use Client-Site VPN.
The encryption header of the VPN will take up space in an Ethernet data packet, leaving less room for actual data. You may find that small files will transfer across a VPN, but not larger files, because of fragmentation issues. In this case, lowering the MTU value on the PC to something around 1350 (your situation may require larger or smaller values) can get things working. You should experiment. You may also need to set the MTU size down on any target servers inside the LAN, though you should not need to adjust anything on a BorderManager VPN server.
MTU size is a registry value specification in Windows. The following programs can be used to easily set the MTU value. You will have to reboot for a new MTU value to take effect.
Thnx for the fast reply. I'll start experimenting but in the mean time did I get the rest right?
Thnx in advance
ps. Does this MTU changing also work on a Mac(book)?
[ Voor 19% gewijzigd door Verwijderd op 13-10-2006 15:53 ]
Iemand nog een tip??? wil vooral graag weten of het openen van de pooten op deze manier goed is gedaan...
alvast thnx
  • Borizz
  • Laatst online: 22-10 19:44
Verwijderd schreef op zondag 15 oktober 2006 @ 18:39:
alvast thnx
Ik heb er wel een: post je bericht volgende keer gelijk in het Nederlands, dit is gewoon een Nederlands forum :) .
Voorderest lijkt je port forward wel in orde, maar ik zie het nut er niet van in om alle poorten in de range 1024-65535 te forwarden.. Je hoeft alleen de benodigde poorten (1723) te forwarden.
If I can't fix it, it ain't broken.
Dit wordt aangegeven op de site van de universiteit...
FIREWALL OF ROUTER CONFIGURATIE
Als er gebruik gemaakt wordt van een personal firewall of een breedbandrouter, of als deze staan tussen de VPN client en de VPN server, dan moeten de volgende poorten en protocollen worden toegestaan.
Client porten: 1024-65535/TCP
Server poort: 1723/TCP
Protocol: PPTP
Toestaan: IP PROTOCOL 47 (GRE)
(zie http://www.erna.nl/vpn/vpn_access.html )
maar ik snap dus echt niet meer wat er dan nu verkeerd gaat, ik heb op meerdere forums (fora..) gelezen dat de linksys wrt54g wel ens problemen zou kunnen geven maar via het zelfde draadloos netwerk doet de vpn (ook zelfde) het bij iemand anders wel.
Geen andere studenten aan de Erasmus Universiteit met een mac(book)?
  • Borizz
Als client van een VPN, hoef je zelf geen poorten te forwarden naar je lokale computer. Wel moet je ervoor zorgen dat uitgaand verkeer over deze poorten toegestaan is. En dat het GRE protocol doorgelaten wordt.
Aangezien het voor iemand anders wel werkt met dezelfde verbinding, ligt het waarschijnlijk aan de instellingen op je macbook.. Heb je daar toevallig geen firewall op draaien?
