[office 2007 TR2] Kan oude bestanden niet openen
  • phemelrijk
  • Laatst online: 06-10 23:40
phemelrijk
Wat is dat dan ?
Ik kreeg vandaag een email van MS om office 2007 te updaten met de tech. refresh 2. Dat gedaan. Maar nu kan ik mijn ouder word documenten en excel documenten niet openen. Ik krijg de volgende melding. Heb al van alles geprobeer, virusscan uit. andere naam. Maar niets helpt :S Iemand die een oplossing weet? Files zijn virus vrij volgens scanner.
This error may appear because an antivirus program is not allowing the file to open. This can be caused by either:
The antivirus program needs to be updated due to a compability problem with this program.
There is a virus in the file but the antivirus program cannot properly remove or process the virus that it has found.
In either case, the file you are attempting to open should be treated as infected until you have updated your antivirus software to the latest updates available from the vendor. All major antivirus software manufacturers have created updates to address known compatibility problems with Microsoft Office programs. They also usually provide a virus signature file that is available for download from the Internet and must be updated regularly to properly scan for all known forms of viruses.
If you are experiencing this problem on a computer where a new version of antivirus software was recently installed from a CD-ROM, connect to the Internet and download the latest updates available from the manufacturer.
If you are experiencing this problem on a computer where the latest version of the software is installed, all signature files are up to date, and the file will not open (but other files do), then the file may be infected with a virus and the antivirus program cannot remove the infection.
The file could also be corrupt (damaged) and cannot be properly handled by either the antivirus software or the affected Microsoft Office program. In this case, it may be necessary to attempt recovery of the file using the related recovery utilities that may be available with the program, although not all program have file recovery or repair capabilities.
For more information about this issue, see the Microsoft Knowledge Base article 835404.
  • Reptile209
  • Laatst online: 19:13
Reptile209
- gers -
Verwijder je AV software eens en probeer opnieuw. Als dat niet helpt, herinstalleer Office (+TR). Als het dan werkt, kan je je AV opnieuw installeren en duimen dat het blijft werken.
Zo niet, begin bij 1 en zoek een ander office pakket of een andere AV ;).
Zo scherp als een voetbal!
  • Ramon
  • Laatst online: 16:59
Ik had het ook hoor, op m'n workstation had ik Office 2007 met de TR2 staan en bestanden daarmee worden ook niet gelezen in de Office 2007 zonder de TR2 die ik op m'n laptop had staan.
Enige wat ik kan bedenken is office 2007 - zonder TR2 - (op een andere pc?) installeren dan de oude bestanden openen en opslaan als .doc en dan TR2 weer installeren zodat je de bestanden kan gebruiken.
  • CH4OS
CH4OS
It's a kind of magic
Heb je Foutbericht wanneer u een Office-document probeert te openen of Outlook probeert te starten al doorgenomen? Oftewel: het Knowledge Base artikel van Microsoft support? :)
  • Lustucru
Lustucru
26 03 2016
titelfixje
Office 7007 en jij hebt al de hardware waarop je dat kunt draaien.\o/ :)
De oever waar we niet zijn noemen wij de overkant / Die wordt dan deze kant zodra we daar zijn aangeland
  • phemelrijk
phemelrijk
Wat is dat dan ?
Niesje schreef op maandag 02 oktober 2006 @ 18:51:
titelfixje
dat is wel erg ver vooruit jah, haha.
Maar ik zag op de MS site dat een compatibility update is, ik ga die ook even installeren en dan kijken wat er gebeurd :)
http://www.microsoft.com/office/preview/beta/converter.mspx
  • phemelrijk
phemelrijk
Wat is dat dan ?
Na de update doet alles het weer, alles opent weer als vanouds met de TR :)
Gelukkig :)
