[excel] bestand openen in Openoffice en geen password meer?
  • 476 views sinds 30-01-2008
  • idef1x
  • Laatst online: 17:24
Heb je je excel bestand beveiligd met een paswoord om te voorkomen dat iemand hem aanpast, blijkt dat je bij het openen hiervan in OpenOffice helemaal geen paswoord meer nodig hebt :?
Beetje apart :?
  • Outerspace
  • Laatst online: 16:25
Outerspace
Admin General Chat
En als je het bestand in OpenOffice beveiligd met een wachtwoord, heb je er dan wel met Excel last van?
Wauw, een sig!
  • djexplo
  • Laatst online: 31-07 15:50
Microsoft dismisses OpenOffice password removal
Cell protection 'not a security issue' says Microsoft
Tim Smith, Computeract!ve 24 Apr 2006
Microsoft has played down a feature in open source rival OpenOffice.org that removes some password protection on Office applications.
When users open someone else's Excel file in OpenOffice.org's Calc (the OpenOffice equivalent of Excel) it removes any password protection applied to cells and worksheets by the author, so that hidden information can be read, edited and saved.
It is still possible to protect an entire Excel document with passwords. But removing cell and sheet protection could lead to accidental changes being saved by others sharing an Excel document in OpenOffice.org.
The same is true for any password protection applied to elements of a Word document opened using OpenOffice.org's Writer application.
Darren Strange, Office product manager at Microsoft, said that although the open source community had "not respected" the feature and that it could could present "a bit of a problem" to Office users, it was not "security feature".
"It works well for us but it is not a feature other vendors with different functionality would neccesarily have to implement. OpenOffice is not circumventing any security in Office here," said Strange.
He pointed out that the next version of Office, 2007 will include a beefed-up set of Information Rights Management tools, which will offer a higher level of security. Microsoft claims it will prevent screengrabs from being taken of sensitive documents.
John McCreesh, marketing project co-lead for OpenOffice.org, said that the removal of protection passwords from Excel files was a feature of Calc, not a bug.
He argued that OpenOffice users are warned that saving in the Excel format will remove the password. But he could not say how Excel users who create a file that will be used by others can protect hidden information from OpenOffice users.
Anyone that wants to protect passwords that will be opened in different spreadsheet applications should instead use the Oasis OpenDocument file format, which includes password protection, argued McCreesh.
"The user has already been warned that saving in Excel format will not be password protected; they then have to choose OpenDocument Format, where the 'Save with password' option is clearly visible," he said.
The Excel file format, he added, is a "dying legacy".
More information on protecting Excel files can be found on the Microsoft KnowledgeBase.
'if it looks like a duck, walks like a duck and quacks like a duck it's probably a duck'
alle wachwoorden op subbestandsniveau zijn in ms office eenvoudig te omzeilen. het wachtwoord op bestandsniveau zelf heeft tot nu echter nog nooit gefaald - en kan alleen gebruteforced worden, wat al snel een uitzichtloze taak wordt van zodra het lang genoeg is.
  • idef1x
djexplo schreef op dinsdag 26 september 2006 @ 11:54:
"He argued that OpenOffice users are warned that saving in the Excel format will remove the password. "
Hmmm dat is dan niet correct wat John McCreesh zegt. Ik krijg alleen de melding dat bepaalde formatting niet meer zal werken wanneer ik het wil opslaan als een excel 97/2000/XP formaat..niets over paswoord (tenzij ze dat ook onder formatting voorstaan, maar ik eigenlijk niet)..
Maarre bedankt voor de info....das duidelijk :)
[ Voor 4% gewijzigd door idef1x op 26-09-2006 16:51 ]
  • idef1x
Outerspace schreef op dinsdag 26 september 2006 @ 11:51:
Ja ook last van, maar ik vermoed dan erg sterk dat wanneer je het in excel formaat opslaat OpenOffice alle paswoorden eruit laat (ook met Openoffice weer openen heb je geen password meer nodig). Dus vermoedelijk kan dat dan alleen als het in ods wordt opgeslagen.
  • idef1x
Verwijderd schreef op dinsdag 26 september 2006 @ 13:10:
Ben er ook bang voor alleen moet ik daarvoor bij de fileserver beheerder zijn. Is ook een beetje jammer dat je niet zelf je documenten voldoende kan afschermen :(
idef1x schreef op dinsdag 26 september 2006 @ 16:59:Ben er ook bang voor alleen moet ik daarvoor bij de fileserver beheerder zijn. Is ook een beetje jammer dat je niet zelf je documenten voldoende kan afschermen :(
nee, ik bedoel net dat als je een wachtwoord zet op een officedocument om het te kunnen openen, dat dit juist veilig is. enkel .pst (outlook mailbestanden) zijn eenvoudig te kraken.
  • idef1x
Hmm ja bedoeld dus dat niemand het kan openen zonder paswoord? Daar heb ik dit geval dan niet zoveel aan, want het was juist mijn bedoeling dat iedereen het mag bekijken, maar niet aanpassen.
Of snap ik even niet wat je bedoeld?
zoals ik zei heb je op verschillende niveau's wachtwoorden:
ww op blad : makkelijk te omzeilen
ww op vba project : makkelijk te omzeilen
ww om bestand enkel lezen te openen : makkelijk te omzeilen
ww om bestand te openen : niet te omzeilen indien lang genoeg.
de eerste drie worden niet echt als een veiligheidsprobleem beschouwd door MS, en ik kan hen daar grotendeels in volgen.
