Multiplayer port joint task force
  • 39 views sinds 30-01-2008
Welke port gebruikt joint task force voor het multiplayeren??
kom niet door mijn router heen )-:
  • Hoyden
  • Registratie: December 1999
  • Laatst online: 16-10 22:28
Summary #1910
Online game port
Answer #1910
If you want to host a game in Joint Task Force, please forward port 7901 on your router to your internal IP. Typically leave the outside IP 0.0.0.0
Please download and install the latest patch v1.1 from our web site below to make sure you're running version 1.1.
Or you can download from:
http://www.strategyinform...taskforce/patch/9140.html
Patch has some enhancements for multiplayer and makes co-op run much more smoothly.
http://www.sierra.com/en/home/downloads.html
Zie natuurlijk:
http://www.sierra.com/en/home/support/sierra_support.html
[ Voor 88% gewijzigd door Hoyden op 22-09-2006 22:08 ]
  • Crash
  • Laatst online: 11:25
Kwestie van beter zoeken dus ;)
