Freekick (Online voetbalmanagement) topic
  • 416 views sinds 30-01-2008
  • Loona35
  • Laatst online: 22-10 18:34
Afbeeldingslocatie: http://www.freekick.org/forum/templates/subSilver/images/logo_FK.gif
About
Het leek me leuk om eens een Freekick topic (Inmiddels 25.000 leden) te maken. Waarom? Het is op enkele essentiële vlakken heel anders dan Hattrick. Het volgend stukje komt van de website van Freekick en legt de verschillen uit. De stijl waarin het geschreven is helaas tamelijk pro-freekick maar laat je als hardcore-hattricker (zoals ook ikzelf) er niet door afschrikken. Grootste voordeel t.o.v. HT vind ik de training. Iedere speler kan trainen en dat gebeurt ook continue en niet op enkel de vrijdag ochtend. Afijn, lees het maar eens en laat horen of je speelt.. of eens wilt proberen.
(TOG = The Other Game = Hattrick)
Freekick focuses on matches, tactics and transfers. I didn't like the way TOG had so much focus on things that had nothing to do with what happened on the field. In FK, there is no "ideal" tactic that will work every week - you need to look at your strengths and your opponents weaknesses to win.
Freekick's interface takes a wee while to come to grips with, but once you get the hang of it it is nice to use.
Transfers are a bit different - you see the average bid, not the highest bid, so I would recommend studying transfers in FK to try and determine what you should/shouldn't pay for certain players.
Perhaps the most important thing about FK is realising that players need to be strong in multiple skills to be useful. ie, a striker with Scoring 90, Offensive Positioning 20 and Ball Control 20 will be almost useless in FK, because they will never be in a position to actually shoot. Study the manual where there is a table for the skills needed for each position, it will be very good to know.
Also, the way potentials work in FK is a bit different to TOG IIRC. Look for young players with high potentials in complementary skills - they could be future stars. Also, note that players can be trained above their potentials, but at a much slower rate.
Every skill is important for outfielders. But some of them are more..
Another big difference is the 'Transfer-Salary':
So always remember, that there will be high costs following, if you buy an expensive Player!!
In Freekick you CAN win games against better teams, with the right tactics. The game does not only depend (in TOG the midfield has a MUCH greater influence) on your midfield.
You don't, but I mean don't win a game by just having a good midfield!
In FreeKick you always know WHY you've won or lost.
You just have to read the matchreport.
In TOG there is at least one game per season after which I have no idea why I won/lost due to statistics and matchreport!!
And that's why every newbie should from the start always take the time to read the matchreports !!!
>> HT user in FK tip: Assume that information in match reports are relevant instead of the opposite.
Unlike in HT spending a lot of money on the youth is not a necessity.
It is one way to play the game but not the only one.
You can be very successful manager by spending your money on buying your players in the transfer list as well.
This is a huge difference between HT and Freekick.
Especially if you are a new manager, you should consider waiting a while before investing in the youth big ammounts of money.
Oh, and if you do choose to train youths and pour money into them, don't bloody sell every good draft you get! It's not a good way of getting money, it probably won't cover what you put into the youth squad every week, and you are letting go of players. Economy is not the focus of the game, money only represents what players you could get for it.
Of course if you have a great player that just doesn't fit in to your team, like if you only ever play passing and draft a FW with great AE but can't use him, then by all means sell. If you desperately need the money, then by all means - sell him. But do not make selling drafts your strategy at making money. If you want money and don't need young players, just stop investing. It's far easier and far more cost-efficient.
As a TOG player you should remember that:
- Constitution is important for all positions!!!
- Training is not limited to those playing that week
- no home and away games
- no home team advantage
- no weather forecasts
- playing Pressing in FK creates more chances, not less (In TOG Pressing means always challenge rivals attack. Always try to get ball. But, in FK it means get on rivals under pressure.)
- different rating system for players
- no random goalscorers
- no monetary bonuses for winning the league, having the topscorer etc.
- senior players train faster then youngsters, not the other way around
- players in FK have a stamina level
- TOG tactics or strategies will not work in FK
- One-skilled players are useless
- Get to understand that every (outfield) player uses every skill at some point
- Midfielders do some of the defending
- Don't trust your Head Coach to do anything, learn what to do and do it yourself (even if you set it badly, you learn from it)
- Players low in stamina should generally not be used
- Experimentation is the key to knowledge
- Friendlies have no effect on your players. They start the game as if they had full stamina, and after the game they return to whatever level of stamina they had. Don't use friendlies to get experience or extra training for youngsters, just use them to experiment on tactics and to have some fun.
Screenshots
Links
  • FREEKICK.org homepage
  • Er zijn een hoop meer links maar eerst ff checken of er genoeg mensen zijn die het spelen. Er is ook een organizer bijv. zoals bij HT.
[ Voor 10% gewijzigd door Loona35 op 19-09-2006 09:45 ]
Niets kan tegen Hattrick op :)
  • Loona35
Of het er tegenop kan laat ik maar in het midden.. speel zelf ook HT nogsteeds..
Fijn vind ik iig aan FK:
- je hoeft niet te gaan daytraden om bij de top te horen
- geen onrealistische lonen zoals HT die hanteerd voor een 'goddelijke' speler
- training van alle spelers
  • hoedjevanpapier
  • Laatst online: 09-04 12:15
hoedjevanpapier
1, 2, 3, 4 .....
Ik duik er even in...
Tweevoudig GoT cup winnaar met HvP's XI tal(143980)
  • Loona35
het leeft dus (nog?) niet echt op GOT .. jammer :)
  • Fleximex
  • Laatst online: 18-10 09:43
Freekick is niet meer!
Wat jammer. Ik was een paar maanden geleden weer begonnen aan dit geweldige online management spel. Lees nu tot mijn spijt op de website dat ze met onmiddellijke ingang stoppen. Financiële problemen zijn de oorzaak.
Mooi en realistisch geschreven stukje door The Referee:
http://freekick.org/
Wat ik leuk vond aan Freekick was dat het van week tot week ging en in feite heel simpel was, maar toch vrij diep ging. Het tempo lag lekker laag in tegenstelling tot bijvoorbeeld het recentere TopEleven wat veel mensen spelen. De match engine was echt het hoogtepunt van dit online spel en daarom ging het merendeel van de tijd in het maken van tactieken en doorselecteren van de selectie.
Ook was de balans tussen spelers kopen en talenten werven was erg goed. Je kon een keuze maken tussen kopen en voor de jeugd gaan en, hoewel niet optimaal, zelfs een tussenweg.
Overigens is het opvallend dat ze nu gestopt zijn want pas geleden was er nog een redelijk grote update, waarbij het transfersysteem op de schop werd genomen.
Ondanks dat het aantal Nederlandse leden op volgens mij nog geen 900 lag hebben een redelijk aantal Nederlanders dit spel gespeeld.
Ik zelf ben nooit hoog gekomen. Toen ik het voor het eerst speelde, liep de Nederlandse competitie tot de 3de amateur divisie en was het al een hele klus om van de 2de amateur naar de 1ste amateur divisie te promoveren. Iets wat mij toen ook niet gelukt is.
Recenter toen ik het spel weer oppakte liep het tot de 2de amateur divisie volgens mij en was het iets makkelijker om in de 1ste amateur divisie te komen.
Mijn club heette, in beidde periodes dat ik speelde, trouwens FC Fleximex (heel orgineel :+). Ik was zelf niet zo actief in de community van Freekick zelf. Ik las de fora wel soms, maar reageerde nooit.
Mijn mooiste (misschien tegelijk ook droevigste) herinnering aan Freekick was hoe ik bijna stuntte in de internationale beker tegen een tegenstander (Nederlands team) die een veel beter team had en in de 3de divisie speelde. Ik zat in de 2de amateur divisie en in de laatste minuut van de verlenging, bij 1-1, kopt een van mijn spitsen een Afbeeldingslocatie: http://www.fleximex.com/tweakers/uitstekend.png bal richting goal en zijn keeper was aarzelend en maakte een Afbeeldingslocatie: http://www.fleximex.com/tweakers/goed.png redding en had de bal toch. Ik verloor uiteindelijk na strafschoppen.
Afbeeldingslocatie: http://www.fleximex.com/tweakers/vreselijk.png :'( om te zien dat het spel nu stopt. Het was Afbeeldingslocatie: http://www.fleximex.com/tweakers/legendarisch.png ;)
Ijdele hoop?: misschien kunnen ze nog als Kickstarter terugkomen? Ik zou ze graag steunen.
[ Voor 86% gewijzigd door Fleximex op 08-01-2014 12:49 ]
