Lyngbox: HDTV, DVB-SAT+T ontvanger met harddisk
  • 4.871 views sinds 30-01-2008
Op de IBC in amsterdam (8-12 september 2006) is de Lyngbox geintroduceerd.
De Lyngbox is een HDTV (720p en1080i) satelliet ontvanger en een HDTV terrestrial ontvanger in één, verder is hij voorzien van een harde schijf om programma's op te nemen.
Ook beschikt hij over een netwerkaansluiting en heeft hij een OLED display.
alle specs op http://www.lyngbox.com/
Afbeeldingslocatie: http://www.lyngbox.com/subpages/about_lyngbox/gallery/front2.jpg
Afbeeldingslocatie: http://www.lyngbox.com/subpages/about_lyngbox/gallery/front1.jpg
Technical Features
* HDTV support (720p and 1080i)
* Supports H.264/MPEG-4 AVC and MPEG-2
* Inbuilt tuners for both satellite TV (DVB-S/DVB-S2) and terrestrial TV (DVB-T)
* Internal slot system which makes it possible to install an additional tuner card
* 4:3 and 16:9 TV screen format support and teletext decoding
* Dual Common Interface slots for usage with pay-TV-channels
* PVR functionality with inbuilt hard disk
* Possibilities to store recordings on an external DVD-recorder connected with USB2
* DiSEqC 1.2 support for controlling LNB and motorised dish
* Remote control as standard and a wireless remote keyboard as accessories
* Channel selection by typing the name (or the beginning of the name) of the channel on the keyboard
* View images from a digital camera connected to the LyngBox
* The LyngBox can store up to 50000 channels
LyngBox Special Features
* Free access to all LyngSat Network services (LyngSat, LyngSat Guide and LyngSat Maps) with exclusivity to the LyngBox. No other receiver has access to these services
* Always corrects channel names, not relying on service names in the DVB stream
* Family user profiles and parental lock. Each user can have their own selection of channels based on countries, languages and genres which will be updated automatically
Interfaces
* DVB-S2 input
* DVB-T input + output (pass-through)
* Expansion slot for additional tuner card
* 2 Common Interface slots
* HDMI-output.
* Component output
* Composite output
* SCART output (RGB and composite)
* S/PDIF optical output with AC-3 support
* Stereo audio (2 RCA)
* 4 USB 2.0 ports
* Ethernet connection (100BaseT)
Hardware Specifications
* Size (WxHxD): AxBxC cm
* STi7100 CPU (three cores: 1x266 MHz, 2x400 MHz)
* 96 MB System Memory
* 160 GB Hard Disk
* OLED front panel display
Guarantee & Warranty
* The LyngBox has a two years limited guarantee
Features
The LyngBox is a unique and easy to use product for the world wide market. It solves the most common problems experienced by users. The main features of the LyngBox include the following:
LyngBox is a receiver for HDTV
The LyngBox supports HDTV reception, from both satellite (DVB-S2) and terrestrial transmissions (DVB-T). The box has a DVB-S2 tuner to support the latest standard for satellite transmission.
LyngSat Network
The LyngBox uses a number of services from LyngSat Network, some of them specially developed for the LyngBox:
* LyngSat provides the LyngBox with up-to-date channel and satellite information
* LyngSat Maps automatically calculates which satellites that can be received from the users location with the available equipment
* LyngSat Guide is an extensive TV guide covering all the world
Automatic Channel List Installation
One of the biggest problems with satellite TV is that the channel list in a conventional satellite receiver is static. It requires a lot of knowledge by the user to add new channels, so much knowledge that many viewers avoid watching the ever increasing selection of satellite TV channels.
To know if a channel is receivable with a specific type of equipment, the LyngBox can use LyngSat Network to automatically install all receivable channels.
Automatic Channel Update
A common problem is that channels seem to disappear suddenly. The reason is that TV companies want to optimize their coverage area and/or decrease their transmission costs. The viewer will think that the channel has stopped transmitting, since there is normally no tuning advice or information about the move.
With the LyngBox, all channel information is automatically updated from LyngSat Network, so the viewer is not affected when the channel moves or changes parameters.
Focus on free-to-air TV channels
The LyngBox simplifies identification, installation, and updates of the large number of Free-to-Air channels available. The integration of LyngSat Network let the user identify all channels that are possible to install with the available equipment.
Users with a motorized antenna have an additional advantage from the LyngBox. It might be possible to keep track of all channels at one satellite position, but to do it for all receivable satellite positions is almost a full-time job. Many users don't even know which satellates they can tune in to. The integration with LyngSat Maps automates this work. The channel list is ready and kept up-to-date without any effort.
You can also watch channels with conditional access by installing "pay-TV-cards" in the dual common interface slots of the LyngBox.
A global and interactive TV guide
LyngSat Guide provides the user with a global and interactive TV guide. The guide is integrated into the LyngBox, but can also be used as a standalone website.
One-Touch Recording
The integration with LyngSat Guide makes it easy to schedule recordings. Just press the recording button when browsing the TV guide to record a program. The powerful PVR also give the possiblity to edit recorded programs and to store recordings on an external DVD-recorder connected with USB2.
Control Recordings From Internet
The user can command the LyngBox to record TV programs using the webbsite LyngSat Guide, from any computer with an Internet connection.
You don´t need to be worried if you forgot to set a recording before leaving home. Just log in on the LyngSat Guide website and set new recordings
The receiver is developed with focus on quality reception and ease of use
The sensitive DVB-S2 tuner in the LyngBox can tune in to satellites other receivers can not reach.
Usability for the LyngBox is guaranteed by the intuitive user interface and the automatic channel maintenance enabled by the integration with LyngSat Network. The user can concentrate on the main objective, watching TV
Dual Tuner
Makes it possible to watch and record both terrestrial and (DVB-T) and satellite (DVB-S/S2) channels. A third tuner is possible to add as an option for simultanous watching and recording from the same source.
Photo Viewer
The LyngBox can display your photos in full HDTV resolution. It is possible to connect a digital camera to the USB-connectors and display photos, or copy the photos to the inbuilt hard disk of the LyngBox.
User Profiles
Each user of the LyngBox can have an own profile with separate channel lists. The channel lists for all profiles are of course kept up-to-date with the LyngSat synchronization. It is possible to protect profiles with password (parental lock).
Note: Since the LyngBox communicates with LyngSat Network on Internet, it is recommended to have an Internet connection to the LyngBox.
[ Voor 48% gewijzigd door Verwijderd op 09-09-2006 17:52 ]
  • rimave
  • Laatst online: 07:35
Wow, wat een gaaf ding. Ik was al een beetje aan het speuren naar een nieuwe ontvanger, maar deze heeft echt alles wat ik zoek: HDD, linux based, HDTV. Strak! Komt ie ook naar NL? :9
  • GaMeOvEr
  • Laatst online: 16:45
GaMeOvEr
Is een hork.
Concurrent van de nog uit te komen Dreambox 8000. :)
Aannames zijn fataal.
  • 6killer
  • Laatst online: 17:03
Mooi ding en mooie specificatie lijst. Zijn/worden er nog prijzen bekend gemaakt? Want dit ziet er naar uit dat t wel een prijzige kast is met al deze features, ben benieuwd of dat allemaal vlekkeloos werkt.
  • nwnc
  • Laatst online: 25-11 16:54
6killer schreef op zaterdag 09 september 2006 @ 22:09:
What is the price of a LyngBox?
The price level will be around euro 600 for end-consumers (incl. VAT). This will of course vary depending on regional campaigns and packages. There is no fixed price set yet.
Inventaris
GaMeOvEr schreef op zaterdag 09 september 2006 @ 21:07:
De dreambox heeft geen HDMI alleen DVI maar ondersteunt geen HDCP, dus ben je afhankelijk van alternatieve software/emulatie om gecodeerde HDTV kanalen te bekijken. Dus geen HDTV nederlandse zenders, of welke gecodeerde HDTV zender dan ook (bijna allemaal)
De Lyngbox heeft HDMI, dus ook HDCP.
  • kazuka
  • Registratie: Juli 1999
kazuka
Building Better Worlds
Verwijderd schreef op zondag 10 september 2006 @ 09:47:
Als je hem gewoon aansluit via de beschikbare Component interface heb je dat probleem toch niet meer?
Ben benieuwd naar deze receiver. Het wordt voor mij of deze, of de DM8000
  • GaMeOvEr
GaMeOvEr
Is een hork.
Ik gok dat men daar wel een oplossing voor vind, anders vind die box 0 aftrek in de markt. :)
  • 6killer
nwnc schreef op zaterdag 09 september 2006 @ 23:02:
Aha, dat is een behoorlijk verschil met de Dreambox maar dit is natuurlijk ook een nieuw product. Deze komt alleen pas in februari op de markt de Dreambox was volgens mij nu al ergens gepland.
6killer schreef op zondag 10 september 2006 @ 13:06:
Februari?? Waar haal jij die info vandaan, heb ik iets niet gelezen?
  • nwnc
Verwijderd schreef op zondag 10 september 2006 @ 18:01:
http://www.lyngbox.com/distributor.html?SubPage=faq en dan op Distributor Info klikken.
Inventaris
  • 6killer
Zoals hierboven via de link ook te vinden is, komen er wel enkele modellen in november, maar als je zoeen wil hebben moet je denk geluk hebben en een premium willen betalen. (overigens was die faq gisteren volgens mij nog niet bereikbaar, of ik heb verkeerd gekeken)
[ Voor 3% gewijzigd door 6killer op 10-09-2006 19:57 ]
6killer schreef op zondag 10 september 2006 @ 19:56:
De modellen in november zijn voor de distributeurs, en niet voor eindgebruikers.
  • 6killer
Verwijderd schreef op zondag 10 september 2006 @ 20:12:
Dat klopt, maar dat wil niet zeggen dat je ze dan niet kan kopen alleen je zal of goede banden met iemand moeten hebben of een premium betalen maar lijkt me niet onmogelijk mocht je het willen.
  • Neus
  • Laatst online: 10-11 15:52
Een zeer interessant produkt; mits de prijs redelijk is...
Very funny, Scotty... Now beam down my clothes !
  • Neus
Uit de FAQ op hun site:
The indicative price level will be around euro 600-700 for end-consumers (incl. VAT). This will of course vary depending on regional campaigns and packages. There is no fixed price set yet.
  • jozy
  • Laatst online: 23-11 17:28
is het ook mogelijk om een aparte insteekkaart te kopen en die erin te zetten die DVB-C ondersteund en daarmee bijv casema digitale tv erop te ontvangen?
op de site staat dit namelijk niet specifiek vermeld, alleen de mogelijk om dual tuners te maken zodat je kunt openmen en afspelen tegelijk. Maar als je ook DVB-C erop kan ontvangen, zit alles mooi in 1 box en zoiets is nou net wat ik zoek
  • Black Piet
Een klein kickje...
Heeft iemand van de vorige posters nu al persoonlijke ervaringen met deze box? O-)
Mooooooeeeee......
  • 6killer
Black Piet schreef op zaterdag 13 januari 2007 @ 12:14:
Een klein kickje...
Verkoop begint pas in februari/maart, dus tenzij iemand een test of review versie krijgt blijft het nog even wachten.
  • Black Piet
..kuch...kickje...kuch.... :o
Even een kleine update van dit topic...
http://www.aftonbladet.se...ry/0,2789,1043235,00.html
Ny tv-box kan ge dig tusentals kanaler
Svensk bakom den nya super-boxen - förenklar tittandet i hela världen
Har du svårt att bestämma vilket program du ska se på? Nu kan du ställas inför ännu tuffare val i tv-soffan.
Eller vad sägs om upp till 4 000 kanaler i din tv på ett enkelt sätt?
Det kan nämligen den nya svenska satellitboxen Lyngbox, som börjar säljas till hösten, erbjuda.
Prylbloggen
Läs Aftonbladets Peter Petterssons prylblogg
Vill du titta på polska barnprogram eller såpopera från Egypten? Med en ny svensk uppfinning kan du se upp till 4 000 kanaler från olika länder på din tv, skriver tidningen Ny Teknik.
Det krävs att man har en motordriven parabolantenn, som går att rikta åt olika håll, för att få in kanalerna.
Den nya svenska uppfinningen Lyngbox är en satellit-tv-mottagare som automatiskt hämtar och uppdaterar information från världens största nätsajt för satellit- och kabelinformation, Lyngsat.com.
Därigenom kan den visa upp till 4 000 gratis satellitkanaler – från länder som är inom Sveriges täckningsområde. Den tar också in alla kanaler från det digitala marknätet.
Förenklar livet
Redan tidigare har de med motordriven parabolantenn kunnat få in ett stort antal kanaler, men tv-tittaren har själv behövt hålla reda på adresser och positioner för kanalerna, vilket har begränsat hur många kanaler det är praktiskt möjligt att ha.
– Den stora fördelen med den här apparaten är att den förenklar livet betydligt för de som är intresserade av många satellitkanaler. De slipper ställa in och uppdatera sina boxar. Men man ska komma ihåg att de kanaler som är gratis är det av en anledning. Det är inte alltid de bästa kanalerna, säger Aftonbladets prylexpert Peter Pettersson.
En annan fördel med att Lyngbox arbetar genom internet är att man också kan fjärrstyra den över nätet. Användaren skulle alltså till exempel kunna sitta i Venezuela och över nätet programmera sin Lyngbox i Sverige att spela in ett program från en satellitkanal från Ryssland.
ESA med och utvecklade
Mannen bakom både Lyngsat och Lyngbox är svenske Christian Lyngemark.
Boxen, som är hd-tv klar, har utvecklats i samarbete med en rad svenska it- och teknikföretag samt europeiska rymdstyrelsen ESA. Den börjar säljas hösten 2007 och kommer att kosta runt 6 000 kronor.
– Jag tror att den finner sin marknad bland tv-intresserade villaägare med god ekonomi. Ska man köpa en satellitbox i den högre prisklassen är den ett bra alternativ, säger Peter Pettersson.
Even door Bablish halen en je leest in hoofdlijnen het artikel...
Helaas moeten we nu tot het najaar wachten als ik de berichten mag geloven op de hoofdsite...
Mooooooeeeee......
  • jozy
hij mag nu wel is uit komen maar we moeten blijkbaar nog wachten tot eind 2007
  • el frikandel
  • Laatst online: 08-10-2025
Volgens de geheel vernieuwde website was de officiële introductie van deze high definition satelliet ontvanger met harde schijf 7 september jl.
zie ook LYNGBOX.COM
  • edterbak
  • Laatst online: 23-11 10:26
Is het geen grap?
Hij heeft alles wat een mens kan wensen. En dat alles op het netstroom van 85-265Volt....
Let op de naam: Lyngbox > leugendoos??
Dit draadje loopt ook al een tijdje... Ik ben sceptisch, tot dat iemand een ervaring post.
[ Voor 26% gewijzigd door edterbak op 10-09-2007 23:55 ]
  • el frikandel
edterbak schreef op maandag 10 september 2007 @ 23:51:
Is het geen grap?
Aangezien erop het bekende satellietforum al voldoende mensen zijn die hem laatst in werking hebben gezien twijfel ik niet over het bestaan ervan.
  • edterbak
el frikandel schreef op dinsdag 11 september 2007 @ 19:37:
Ik ben om! :*) Interessante doos!
  • joey6666
  • Laatst online: 23-04 18:02
anders ga je even naar IBC in Rai amsterdam, ze staan daar met een stand
  • Black Piet
Hmmmm.....
De site van Lyngbox is weer geupdate met specs....... Volgens de site komt ie nu pas weer in S4 van 2007 (dus nu...) :+
Ik ben erg benieuwd naar wat links naar reviews...
Mooooooeeeee......
  • el frikandel
In Duitsland is hij inmiddels leverbaar
Zie de Duitse prijsvergelijking-site: http://www.idealo.de/prei...47_-media-hd-lyngbox.html en leverbaar voor €679,- met 160GB. disk
Kan deze doos ook streamen vanaf een netwerk share?
  • Black Piet
Beetje ordinary topic kick. Maar dit apparaat is nu beschikbaar voor 499.
Video formats
* Supported resolutions:
o 576i, 576p, 720p, and 1080i
Enige nadeel is dat de videoformaten niet 1080p ondersteunen.
Mooooooeeeee......
  • aart44
  • Laatst online: 07:31
Black Piet schreef op maandag 09 februari 2009 @ 19:46:
Video formats
Er is momenteel nog geen enkele ontvanger op de markt die 1080p uitgeeft en uitgezonden wordt er nog helemaal niets in 1080p dus waarom een nadeel??
Maar het lijkt er op dat de box geflopt door een aantal bugs is dat zal de reden zijn dat de prijs gezakt is.
