Ubuntu start zonder chipset drivers bij cold boot
  • BCC
  • Laatst online: 21:27
Vaag probleem, bij een goede boot van Ubuntu ziet mij dmesg er zo uit (relevant stuk)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
[17179588.660000] Linux agpgart interface v0.101 (c) Dave Jones
[17179588.664000] hw_random: RNG not detected
[17179588.668000] agpgart: Detected an Intel 845G Chipset.
[17179588.668000] agpgart: Detected 8060K stolen memory.
[17179588.808000] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[17179589.084000] agpgart: AGP aperture is 128M @ 0xe0000000
[17179589.084000] i810_smbus 0000:00:02.0: i810/i815 i2c device found.
[17179589.084000] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[17179589.500000] input: PC Speaker as /class/input/input1
[17179589.532000] usbcore: registered new driver usbserial
[17179589.532000] drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
[17179589.532000] usbcore: registered new driver usbserial_generic
[17179589.532000] drivers/usb/serial/usb-serial.c: USB Serial Driver core
[17179589.540000] drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
[17179589.540000] pl2303 2-1:1.0: pl2303 converter detected
[17179589.540000] usb 2-1: pl2303 converter now attached to ttyUSB0
[17179589.540000] usbcore: registered new driver pl2303
[17179589.540000] drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
[17179589.812000] **** SET: Misaligned resource pointer: db4c0d02 Type 07 Len 0
[17179589.812000] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
[17179589.812000] PCI: setting IRQ 9 as level-triggered
[17179589.812000] ACPI: PCI Interrupt 0000:00:1f.5[B] -> Link [LNKB] -> GSI 9 (level, low) -> IRQ 9
[17179589.812000] PCI: Setting latency timer of device 0000:00:1f.5 to 64
[17179590.132000] intel8x0_measure_ac97_clock: measured 56558 usecs
[17179590.132000] intel8x0: clocking to 48000
[17179590.180000] input: PS/2 Generic Mouse as /class/input/input2
[17179590.204000] parport: PnPBIOS parport detected.
[17179590.204000] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[17179590.224000] ts: Compaq touchscreen protocol output
[17179590.532000] 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
[17179590.536000] 8139cp: pci dev 0000:01:06.0 (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
[17179590.536000] 8139cp: Try the "8139too" driver instead.
[17179590.620000] 8139too Fast Ethernet driver 0.9.27
[17179590.620000] ACPI: PCI Interrupt 0000:01:06.0[A] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
[17179590.620000] eth0: RealTek RTL8139 at 0xe0316000, 00:06:93:20:14:fb, IRQ 11
[17179590.620000] eth0:  Identified 8139 chip type 'RTL-8100B/8139D'
[17179590.888000] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[17179591.000000] Intel ISA PCIC probe: not found.
[17179591.168000] lp0: using parport0 (interrupt-driven).
[17179592.008000] NET: Registered protocol family 17
[17179592.036000] device-mapper: 4.4.0-ioctl (2005-01-12) initialised: dm-devel@redhat.com
[17179594.564000] ip_tables: (C) 2000-2002 Netfilter core team
[17179647.996000] pcc_acpi: loading...
[17179648.028000] ACPI: Power Button (FF) [PWRF]
[17179648.028000] ACPI: Power Button (CM) [PWRB]
[17179648.116000] ibm_acpi: ec object not found
[17179655.812000] [drm] Initialized drm 1.0.1 20051102
[17179655.836000] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LNKA] -> GSI 5 (level, low) -> IRQ 5
[17179655.840000] [drm] Initialized i915 1.4.0 20060119 on minor 0
[17179661.180000] ppdev: user-space parallel port driver
[17179679.884000] IPv6 over IPv4 tunneling driver
[17179690.404000] eth0: no IPv6 routers present
Bij een koude boot mist dit stuk echter, oftewel: de chipset drivers worden niet gestart. Dit zorgt er dus voor dat een heleboel dingen niet werken (muis, netwerk, etc). Ik begrijp echter niet wat er mis gaat. rebooten lost het 9/10 keer op, maar soms moet ik wel 6x rebooten voor dat het wel goed gaat. Iemand ideeën?
[ Voor 165% gewijzigd door BCC op 06-09-2006 16:30 ]
  • sariel
  • Laatst online: 22-09 15:35
Eeuhm.....kan je ook 2 keer dezelfde informatie sturen, zodat we kunnen zien wat er gebeurd? Nu copy-paste je twee compleet verschillende stukken log zonder enige overlap.....dus hoe moeten wij hier iets uit halen?
Copy.com
  • BCC
Sorry, copy paste foutje.
Dit is in iedergeval nu het relevante stuk.. het begin en het eind van beide dmesg berichten is verder hetzelfde. Die kan ik ook wel posten, maar dan wordt het een hele grote lap met dmesg spullen.
Ik heb dit al een aantal kernel versies (draai nu Ubuntu Dapper Drake).
[ Voor 255% gewijzigd door BCC op 06-09-2006 17:27 ]
  • BCC
-- kick --
