Medal of honor allied assault wil nie starten
  • 56 views sinds 30-01-2008
yo menZen. heb net de demo gedownload om beetje rond te goofen...
heb amd xp 1.6 1 gig ram en nvidia riva tnt2 32mb
krijg deze fcking mededeling:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 12 2001
----- FS_Startup -----
Current search path:
C:\PROGRA~1\EAGAME~1\MOHAAN~1\main\Pak5.pk3 (6 files)
C:\PROGRA~1\EAGAME~1\MOHAAN~1\main\Pak4.pk3 (284 files)
C:\PROGRA~1\EAGAME~1\MOHAAN~1\main\Pak3.pk3 (397 files)
C:\PROGRA~1\EAGAME~1\MOHAAN~1\main\Pak2.pk3 (490 files)
C:\PROGRA~1\EAGAME~1\MOHAAN~1\main\Pak1.pk3 (199 files)
C:\PROGRA~1\EAGAME~1\MOHAAN~1\main\Pak0.pk3 (1546 files)
C:\PROGRA~1\EAGAME~1\MOHAAN~1/main
2922 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 20
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Bedankt voor de mededeling dan maar.
  • KillerAce_NL
KillerAce_NL
If it ain't broke...
Je vidcard is niet geschikt.
***wel dus** 32mb is minimum.
Ff je drivers updaten bij Nvidia.com (wel de TNT2 drivers nemen !)
[ Voor 74% gewijzigd door KillerAce_NL op 06-09-2006 14:53 ]
euhm, ik heb de drivers gedownload en en als ik ze installeer krijg ik de mededeling dat de hardware oncampatibel is. fijn.
  • Cardinal
  • Laatst online: 01:53
Verwijderd schreef op woensdag 06 september 2006 @ 15:45:
Dat zou best wel eens kunnen kloppen, aangezien er in het bericht staat dat OpenGL geen Pixelformat kan openen, na een recovery probeert die het nogmaals, maar mocht niet baten. Zijn kennelijk meer mensen met dit probleem
  • Crash
  • Laatst online: 12:22
http://gathering.tweakers...ad+OpenGL&where=Dit+forum
Volgende keer graag zelf eerst zoeken naar een oplossing :z
