Root hint of Fowarden?
  • 79 views sinds 30-01-2008
Kan iemand mij het verschil vertellen als ik bijvoorbeeld Root Hints gebruik of dat ik mijn DNS Server gaat forwarden naar de DNS server van mijn ISP? En als ik b.v forward naar de ISP kan ik dan mijn Root Hints file gewoon verwijderen?
  • Question Mark
  • Laatst online: 17:03
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Adding a DNS Forwarder vs Root Hints
When using Root Hints DNS Requests work as follows:
Client : Asks Local DNS Server about an address for www.domain.com
Local DNS : Makes sure it isn't Authoritative for domain.com. Checks Local Cache for Previously Given Answer.
Then if the DNS Server can't find the answer in cache it continues...
Local DNS : Checks Root Hints file for Root Servers
Local DNS : Contacts Root Server (e.g. a.root-servers.net) and Requests the Authoritative Server for .com
A.Root-Servers.Net : Responds with a Server Responsible for the TLD (Top Level Domain). e.g. a.gtld-servers.net
Local DNS : Contacts TLD Server and Requests Authoritative Server for domain.com
A.GTLD-Servers.Net : Responds with Name Servers Addresses for domain.com. e.g. ns1.domain.com
Local DNS : Contacts ns1.domain.com and requests www Record
NS1.Domain.Com : Replies with Record for www and gives TTL (Time To Live - A count down timer in effect)
Local DNS : Returns Answer to Client and Holds onto Record until TTL Expires
Now... If you configure fowarders all the actual work is handed off to the server you forward to. In effect this adds an extra step into the conversation:
Local DNS : Checks it isn't Authoritative
Local DNS : Asks Forwarder
At that point the Forwarder checks it's local cache, if it doesn't have an answer it does all the running around looking for it.
So.... Yes... if Forwarders are configured you don't use Root Hints.
En wat kan je beter gebruiken, Root Hints of een Forwarder naar je ISP?
  • Grolsch
  • Laatst online: 00:09
Verwijderd schreef op woensdag 30 augustus 2006 @ 11:21:
als je een forwarder gebruikt wordt het voornaamste denkwerk gedaan door de DNS van je ISP.
Als je Root Hints gebruikt zul je minder last van vertraging hebben bij DNS updates ivm caches bij je provider.
Normaal gesproken zou ik altijd een (meerdere) forwarder(s) gebruiken.
PVOUPUT - 13.400WP - Twente
Grolsch schreef op woensdag 30 augustus 2006 @ 12:17:
Je bedoelt als je Forwarders gebruikt zul je minder last van vertraging hebben bij DNS updates ivm caches bij je provider?
  • Grolsch
Verwijderd schreef op woensdag 30 augustus 2006 @ 12:28:
nee, als je forwarders gebruikt, gebruik je dus de DNS server van je provider als forwarder.
hier KAN vertraging ontstaan als je provider DNS gegevens cached voor een bepaalde tijd.
dus wat vertraging betreft zijn roothints in theorie sneller.
praktisch heb ik hier nog nooit hinder van ondervonden, hoevaak wijzigen nu DNS records zodat je er last van hebt. De profesionale organisaties regelen dit van te voren.
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Je kan beter een zoekmachine gebruiken. Vraag raak voor een knaak is een paar deuren verderop. Algemene gedragsregels (Netiquette)
Mijn spoorwegfotografie
