[MB] DFI LP UT NF590 voor AM2
hij is er _/-\o_
http://us.dfi.com.tw/Prod...&CATEGORY_TYPE=LP&SITE=US
De DFI LanParty UT NF590 SLI-M2R/G :9~
CPU support:
- AMD® Athlon 64 FX / Athlon 64 X2 / Athlon 64
- Socket AM2
- 2000MT/s HyperTransport interface
Chipset:
- NVIDIA nForce® 590 SLI MCP -
* Northbridge: NVIDIA® C51XE -
* Southbridge: NVIDIA® MCP55PXE
Memory:
- Four 240-pin DDR2 DIMM sockets
- Supports DDR2 533, DDR2 667 and DDR2 800 DIMMs
- Supports dual channel (128-bit wide) memory interface
- Supports up to 4GB system memory
Expansion Slots:
- 2 PCI Express x16 slots -
* In SLI or Normal mode, each slot operates at full speed x16 lanes.
* Use identical SLI-ready PCI Express x16 graphics cards
- 1 PCI Express x1 slot
- 1 PCI Express x8 slot
- 3 PCI slots
BIOS:
- Award BIOS
- CMOS Reloaded
- CPU/DRAM overclocking
- CPU/DRAM/Chipset overvoltage
- 4Mbit flash memory
Power Management:
- ACPI and OS Directed Power Management
- ACPI STR (Suspend to RAM) function
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-LAN
- RTC timer to power-on the system
- AC power failure recovery
Hardware Monitor:
- Monitors CPU/system/chipset temperature
- Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
- Monitors the speed of the cooling fans
- CPU Overheat Protection function monitors CPU temperature during system boot-up
Audio:
- Karajan audio module
* Realtek ALC885 8-channel High Definition Audio CODEC
* 6 audio jacks - 1 CD-in connector
* 1 front audio connector
- DAC SNR/ADC SNR of 106dB/101dB
- Full-rate lossless content protection technology
- S/PDIF-in/out interface
LAN:
- NVIDIA® MCP55PXE integrated with Gigabit MAC (Media Access Control) technology
- Two Vitesse VSC8601 Gigabit Phy chips
- Fully compliant to:
* IEEE 802.3 (10BASE-T)
* 802.3u (100BASE-TX)
* 802.3ab (1000BASE-T)
IDE:
- One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
- Six Serial ATA ports supported by NVIDIA® MCP55PXE
* SATA speed up to 3Gb/s
* RAID 0, RAID 1, RAID 0+1 and RAID 5
- Two Serial ATA ports supported by Silicon Image SiI 3132
* RAID 0, RAID 1 and RAID 0+1
IEEE 1394:
- VIA VT6307
- Supports two 100/200/400 Mb/sec ports
Rear Panel I/O Ports:
- 1 mini-DIN-6 PS/2 mouse port
- 1 mini-DIN-6 PS/2 keyboard port
- 2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
- Karajan audio module (6 audio jacks)
- 1 IEEE 1394 port
- 2 RJ45 LAN ports
- 6 USB 2.0/1.1 ports
I/O Connectors:
- 2 connectors for 4 additional external USB 2.0/1.1 ports
- 1 connector for 1 external IEEE 1394 port
- 1 connector for 1 external serial port
- 1 connector for the Karajan audio module
- 1 front audio connector for external line-out and mic-in jacks (on the Karajan audio module)
- 1 CD-in internal audio connector (on the Karajan audio module)
- 1 S/PDIF connector for optical cable connection
- 1 IrDA connector
- 1 CIR connector
- 8 Serial ATA connectors
- 1 IDE connector
- 1 floppy connector
- 1 24-pin ATX power connector
- 1 8-pin ATX 12V power connector
- 1 4-pin 5V/12V power connector (FDD type)
- 1 front panel connector
- 5 fan connectors
- 1 Debug LED
- EZ touch switches (power switch and reset switch)
PCB:
- ATX form factor
- 24cm (9.45") x 30.5cm (12")
specificaties overgenomen van DFI's site
Voor meer foto's:
http://forums.vr-zone.com...ad.php?p=2285972&posted=1
Linkje op DFI Street:
http://www.dfi-street.com...bf81092a2d818aa65&t=56527
[ Voor 91% gewijzigd door Verwijderd op 26-08-2006 16:52 ]
  • ZandBak
  • Laatst online: 09-06-2023
Afbeeldingslocatie: http://us.dfi.com.tw/Upload/Product_Picture/NF590-SLI-M2R-G_L.jpg
1337
