Asus P5W-DH wifi SLOW !
  • 50 views sinds 30-01-2008
Mhhh..
Got a P5w-dh + conroe since a week or so and I can't get good performances out of the built-it wifi client.
I'm using tkip encryption but that should not matter, I get 50% less throughput than my laptop in wifi ;-(
I get about 1.4 megs download from the internet with the wired cable, and it goes down to 500K/s if I switch to wireless .... I should not see so much difference.
Seems it locksup at 54g, good signal, no other client on the AP.
Anyone else is dis-apointed byt the builtin wifi and/or could fix it ?
Da Frog (feel free to reply in Dutch)
It's pretty standard that the wifi chip locks up @ 54G. You can only reach higher speeds with turbo wifi cards (or 802.11n).
  • BalusC
BalusC
Carpe diem
Je woont al ruim 3 jaar in Nederland of misschien zelfs langer. Waarom probeer je niet gewoon in het Nederlands te schrijven? Daar leer je juist het meeste van :) Anders komt er nog nooit wat van.
Maargoed, probeer het nogmaals, maar dan wel in het juiste subforum: Netwerken.
[ Voor 6% gewijzigd door BalusC op 21-08-2006 19:47 ]
