Visual Studio 2005 express, publish programma, foutmelding
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Ik krijg de melding "Application cannot be started. Contact the application vendor." wanneer ik op setup.exe klik van een project wat ik in visual studio 2005 express heb gemaakt. Dit heb ik middels 'Build -> Publish whois' gepubliceerd naar een network share.
Als ik op details klik zie ik de volgende log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
PLATFORM VERSION INFO
    Windows             : 5.1.2600.131072 (Win32NT)
    Common Language Runtime     : 2.0.50727.42
    System.Deployment.dll       : 2.0.50727.42 (RTM.050727-4200)
    mscorwks.dll            : 2.0.50727.42 (RTM.050727-4200)
    dfdll.dll           : 2.0.50727.42 (RTM.050727-4200)
    dfshim.dll          : 2.0.50727.42 (RTM.050727-4200)
SOURCES
    Deployment url          : file:///W:/Systeembeheer/Projecten/Whois%20&%20DNS%20info/whois.application
    Application url         : file:///W:/Systeembeheer/Projecten/Whois%20&%20DNS%20info/whois_1_0_0_2/whois.exe.manifest
IDENTITIES
    Deployment Identity     : whois.application, Version=1.0.0.2, Culture=neutral, PublicKeyToken=fc246f083a3e37f5, processorArchitecture=msil
    Application Identity        : whois.exe, Version=1.0.0.2, Culture=neutral, PublicKeyToken=fc246f083a3e37f5, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
    * Online only application.
ERROR SUMMARY
    Below is a summary of the errors, details of these errors are listed later in the log.
    * Activation of W:\Systeembeheer\Projecten\Whois & DNS info\whois.application resulted in exception. Following failure messages were detected:
        + Value does not fall within the expected range.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
    No transaction error was detected.
WARNINGS
    There were no warnings during this operation.
OPERATION PROGRESS STATUS
    * [11-8-2006 10:09:30] : Activation of W:\Systeembeheer\Projecten\Whois & DNS info\whois.application has started.
    * [11-8-2006 10:09:30] : Processing of deployment manifest has successfully completed.
    * [11-8-2006 10:09:30] : Installation of the application has started.
    * [11-8-2006 10:09:30] : Processing of application manifest has successfully completed.
ERROR DETAILS
    Following errors were detected during this operation.
    * [11-8-2006 10:09:31] System.ArgumentException
        - Value does not fall within the expected range.
        - Source: mscorlib
        - Stack trace:
            at System.Deployment.Internal.Isolation.IDefinitionAppId.EnumAppPath()
            at System.ActivationContext.CreateFromNameAndManifests(ApplicationIdentity applicationIdentity, String[] manifestPaths)
            at System.Deployment.Application.ActivationDescription.ToActivationContext()
            at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
            at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState subState, ActivationDescription actDesc)
            at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut)
            at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
    No transaction information is available.
Wat is er mis? Hoe kan ik mijn programma runnen? Belangrijkste hier lijkt me die "Value does not fall within the expected range." melding..
  • whoami
  • Laatst online: 01:04
-> DT&E
https://fgheysels.github.io/
