Soundcards that import new sounds?
  • 43 views sinds 30-01-2008
Some sound cards can import new sounds. They are simply downloaded to the sound card, which might have 512 KB (Sound Blaster AWE64) or 4 MB RAM (Sound Blaster AWE64 Gold) available for the user's own sounds.
Are there new soundcards with the same functionality? If yes, which one? If no, why?
Regards,
Kharmen
  • BCC
  • Laatst online: 19:10
BCC
You're referring to the use of a soundcard as a "poor-man's sampler". This is not very usefull anymore as computers have become faster. You can now have a complete software sampler + filters etc, with the same (or even less) delay as you had with the soundbanks on old soudcards. It's a matter of hardware being replaced by software, which gives you more flexibility.
I don't know if there are any cards out there that are still able to use soundbanks, but I think you would be much better of using things like reason as a sampler .. or buy a hardware sampler :)
[ Voor 21% gewijzigd door BCC op 01-08-2006 14:12 ]
  • Cyphax
  • Laatst online: 20:31
Cyphax
Moderator LNX/AI
Soundblaster Live, probably Audigy as well, support loading soundfonts similar to the AWE series.
  • BCC
BCC
Cyphax schreef op dinsdag 01 augustus 2006 @ 14:17:
Yeah, but I believe they now also use software (part of the driver) as their sampler. It's not a hardware solution like the AWE64.
  • Cyphax
Cyphax
Moderator LNX/AI
BCC schreef op dinsdag 01 augustus 2006 @ 14:30:
Hey, if it works, it works! ;)
  • BCC
BCC
Cyphax schreef op dinsdag 01 augustus 2006 @ 14:33:
Yeah, well it depends on what you are trying to achieve. If you need soundfonts for some reason or another, that works fine. If you are looking for a cheap sampler, better look for other software sollutions. Most software samplers can read Vienna soundbanks.
  • memphis
  • Laatst online: 19:57
memphis
48k was toen meer dan genoeg.
I wonder how it is done with the USB version of the soundblaster, maybe that thing has a memory for the soundbanks.
Otherwise you have to get an external MIDI box......
Er zijn mensen die mij een GOD vinden
  • DeeD2k2
  • Laatst online: 20-05 10:46
Welcome at GoT. Since GoT is a Dutch forum, the users should be able to write in Dutch. In case you aren't able to do so, you, unfortunately, have to search for an answer somewere else. Good luck in finding the right soundcard.
Only Irish coffee provides in a single glass all four essential food groups: alcohol, caffeine, sugar, and fat. - Alex Levine
