[PHP/AJAX] POST data komt niet door
  • 364 views sinds 30-01-2008
  • Kvn
  • Laatst online: 19-10 13:04
Na het doorlezen van wat A.J.A.X. tutorials ben ik begonnen aan een login form.
Helaas wil mn postdata niet doorkomen.
De (x)HTML en Javascript code
index.html
HTML:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
   "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
<head>
    <title>Asynchronous Javascript (and XML) - POST Test</title>
    <script type="text/javascript">
    // Creert XMLHTTP Object
    function createRequestObject() {
        var ro;
        var browser = navigator.appName;
        if(browser == "Microsoft Internet Explorer"){
            ro = new ActiveXObject("Microsoft.XMLHTTP");
        }else{
            ro = new XMLHttpRequest();
        return ro;
    var xmlhttp = createRequestObject();
    // Formvalues uitlezen
    function getFormValues(obj) {
    var queryStr = "";
    for (i = 0; i < obj.childNodes.length; i++) {
        if (obj.childNodes[i].tagName == "input") {
            if (obj.childNodes[i].type == "text" || obj.childNodes[i].type == "hidden" ) {
               queryStr += obj.childNodes[i].name + "=" + obj.childNodes[i].value + "&";
            if (obj.childNodes[i].type == "checkbox") {
               if (obj.childNodes[i].checked) {
               } else {
                  queryStr += obj.childNodes[i].name + "=&";
            if (obj.childNodes[i].type == "radio") {
        if (obj.childNodes[i].tagName == "select") {
            var sel = obj.childNodes[i];
            queryStr += sel.name + "=" + sel.options[sel.selectedIndex].value + "&";
    queryStr = queryStr.substr(0, (queryStr.length - 1));
    return queryStr;
    // Afhandelen readyStates
    function handler() {
      if (xmlhttp.readyState == 4) {
         if ( xmlhttp.status == 200) {
            alert(xmlhttp.responseText);
         } else {
            alert("Connectie mislukt");
    // Inloggen
    function doLogin(frmObj) {
        var url = "post.php";
        var data = getFormValues(frmObj);
        xmlhttp.onreadystatechange = handler;
        xmlhttp.open("POST", url, true);
        xmlhttp.setRequestHeader("Content-Type", "application/x-www-form-urlencoded; charset=UTF-8");
        xmlhttp.send(data);
    </script>
</head>
<body>
        <form>
            <input type="text" name="userName" /> <br/>
            <input type="text" name="userPass" /> <br/>
            <br/>
            <input type="button" value="Login" onclick="doLogin(this.parentNode)" />
        </form>
</body>
</html>
De code in post.php
PHP:
<?php
    echo "Login geslaagd! \n\n";
    print_r($_POST);
Allemaal niet zo spannend dus.. Helaas komt de data toch echt niet door.
De fout lijkt in het getFormValues gedeelte te liggen, een handmatige Querystring
komt wel goed door.
[ Voor 11% gewijzigd door Kvn op 24-07-2006 17:01 ]
Misschien deze spatie die er teveel staat?
sel.options[sel.selectedIndex ]
  • Kvn
Even aangepast, helaas zat daar de bug fout niet in... Toch bedankt :)
[ Voor 9% gewijzigd door Kvn op 24-07-2006 17:01 ]
  • The_Light
  • Laatst online: 06-10 18:31
De controles in de functie getFormValues zijn case sensitive. Je moet dus even van bijvoorbeeld input, INPUT maken.
  • Kvn
Eh mn Javascript code en html zijn beide lowercase :*)
  • André
  • Laatst online: 19-10 13:51
André
Analytics dude
En zo dan?
HTML:
  var data = getFormValues(document.forms[frmObj]);
  xmlhttp.send(data);
</script>
<form>
  <br/>
  <input type="button" value="Login" onclick="doLogin('formulier')" />
</form>
Ander zou je de functie getFormValues eens moeten debuggen.
/edit:
En wat The_Light bedoel: in js geeft tagName hoofdletters terug ;) Dus in het geval van een input geeft hij "INPUT" terug.
[ Voor 11% gewijzigd door André op 24-07-2006 20:40 ]
  • Kvn
Niet meer nodig :-)
[ Voor 97% gewijzigd door Kvn op 24-07-2006 20:54 . Reden: Overbodig :-) ]
  • Kvn
Ahh... Grrmbl :p Dat maakte ik daar dus niet uit op. Ik dacht hij doelde op een verschil tussen mn Javascript en HTML.. Het was inderdaad de oplossing.. Doh! :)
Bij deze, bedankt _/-\o_
  • crisp
crisp
Devver
Pixelated
Enkel een doctype maakt het nog geen XHTML; in echt XHTML zou de tagName wel lowercase zijn geweest bij het uitvragen in javascript.
Overigens vind ik de code erg rommelig en slordig en op sommige punten zelfs incorrect; ik zal eens kijken of ik zo dadelijk een 'nette' versie kan maken ter leering ende vermaeck :)
Intentionally left blank
  • Kvn
Hmm prima, maar dan wil ik toch wel weten wat hier 'niet' XHTML aan is. Immers, de pagina valideerd toch zeker als XHTML Strict, waarom zou dit dan niet zo zijn? :)
  • crisp
crisp
Devver
Pixelated
Kvn schreef op maandag 24 juli 2006 @ 21:57:
Omdat validatie enkel iets zegt over syntax, een browser bepaald echter aan de hand van het mime-type welke parser hij gebruikt. Als je een document verstuurd met het text/html mimetype dan zal een browser het dus gewoon als HTML behandelen (en error-correctie toepassen waar nodig aangezien XHTML syntax vaak niet valid HTML syntax is).
Ik zeg daarom ook altijd: als je een XHTML document als HTML verstuurd dan is het een HTML document met verkeerde DOCTYPE - blijkbaar heb je dan ook geen XHTML nodig en heb je dus een verkeerde keuze gemaakt ;)
  • Kvn
Als niemand je erop wijst dat het op deze manier fout is, kan je ook geen verkeerde keuze maken ;)
Dus bij deze, bedankt!
Overigens vind ik de gehele syntax van XHTML een stuk prettiger, en bovendien netter. Ik ga dan ook gewoon verder zo :)
  • crisp
crisp
Devver
Pixelated
Hier een voorbeeld van hoe ik het aan zou pakken; by no means compleet en houd ook geen rekening met eventuele character-encoding (zou bij UTF-8 ook geen probleem mogen zijn), dus puur als voorbeeld. Je ziet hier ook dat ik de Ajax-functionaliteit non-obtrusive heb gemaakt; als een client geen Ajax-ondersteuning of helemaal geen javascript-ondersteuning biedt wordt er een gewone POST gedaan:
HTML:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html lang="en">
<head>
    //-- wrapper for IE
    if (!window.XMLHttpRequest)
        window.XMLHttpRequest = function()
            var types = [
                'Microsoft.XMLHTTP',
                'MSXML2.XMLHTTP.5.0',
                'MSXML2.XMLHTTP.4.0',
                'MSXML2.XMLHTTP.3.0',
                'MSXML2.XMLHTTP'
            for (var i = 0; i < types.length; i++)
                try
                    return new ActiveXObject(types[i]);
                catch(e) {}
            return undefined;
    function createQueryString(frmObject)
        var query = '', queryElements = [];
        var frmEl, i = 0;
        // loop through all form-elements
        while ((frmEl = frmObject.elements[i++]))
            // only active elements that have a non-empty name-attribute
            if (frmEl.name && !frmEl.disabled)
                query = frmEl.name + '=';
                switch (frmEl.tagName.toLowerCase())
                    case 'input':
                        switch (frmEl.type)
                            case 'text':
                            case 'hidden':
                                query += encodeURIComponent(frmEl.value);
                                break;
                            case 'checkbox':
                            case 'radio':
                                if (!frmEl.checked) continue;
                                if (frmEl.hasAttribute('value'))
                                else
                                    query += 'on';
                                break;
                            case 'submit':
                            case 'reset':
                            case 'button':
                            default:
                                // not implemented
                                continue;
                        break;
                    case 'select':
                        if (frmlEl.multiple)
                            // not implemented
                            continue;
                        else
                            if (frmEl.options[frmEl.selectedIndex].hasAttribute('value'))
                                query += encodeURIComponent(frmEl.options[frmEl.selectedIndex].value);
                            else
                                query += encodeURIComponent(frmEl.options[frmEl.selectedIndex].text);
                        break;
                    case 'button':
                    default:
                        // not implemented
                        continue;
                queryElements.push(query);
        return queryElements.join('&');
    // Inloggen
        var url = frmObj.action;
        var data = createQueryString(frmObj);
        var xmlhttp = new XMLHttpRequest();
        if (xmlhttp)
            // closure!
            xmlhttp.onreadystatechange = function()
                    if (xmlhttp.status == 200)
                    else
                        alert('Connectie mislukt');
            xmlhttp.open('POST', url, true);
            xmlhttp.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
            xmlhttp.send(data);
            // cancel form submit
            return false;
        else
            alert('Not Ajax-capable, trying normal form-submit');
        return true;
    </script>
</head>
<body>
    <form action="http://localhost/login.php" onsubmit="return doLogin(this)">
        <fieldset>
            <legend>Login form</legend>
            <label for="userName">Username: </label><input type="text" name="userName" id="userName">
            <label for="userPass">Password: </label><input type="text" name="userPass" id="userPass">
            <input type="submit" value="Login">
        </fieldset>
    </form>
</body>
</html>
Kvn schreef op maandag 24 juli 2006 @ 22:24:
Tsja, in HTML kan je ook netjes coden - qua syntax zijn de verschillen verder ook niet zo groot behalve dat je sommige elementen in HTML geen close-tag hebben. Vertrouwen op error-correctie van browsers (welke niet gedefinieerd is voor HTML) vind ik op z'n minst onverstandig. Daarbij loop je het risico dat wanneer je besluit om je XHTML ook echt als XHTML te gaan versturen er toch zaken anders blijken te zijn waardoor je document niet eens een werkend XHTML-document blijkt te zijn.
Je neemt enkel jezelf in de maling als je XHTML verstuurd als HTML ;)
  • aex351
  • Laatst online: 00:34
aex351
I am the one
Er zijn simpele javascript libs op het internet te downloaden waarmee je deze process kan versimpelen. Zelf het wiel uitvinden is natuurlijk ook leuk, maar het is maar een idee voor je huidige probleem.
< dit stukje webruimte is te huur >
  • crisp
crisp
Devver
Pixelated
aex351 schreef op maandag 24 juli 2006 @ 23:50:
Inderdaad, maar veel van deze script-libraries zijn ook incompleet of incorrect ;)
  • aex351
aex351
I am the one
crisp schreef op maandag 24 juli 2006 @ 23:56:
Klopt ik deel die mening, ik code daarom ook veel zelf en heb de neiging open source projecten van mij af te schuiven. Maar libs als prototype kan je heel goed op bouwen.
Als licht gewicht ajax libary gebruik ik momenteel nu netlobo http://www.netlobo.com/ajax_function.html .
  • crisp
crisp
Devver
Pixelated
aex351 schreef op dinsdag 25 juli 2006 @ 00:10:
Zowel prototype als de library die jij noemt verwachten dat de POST-body al kant-en-klaar wordt aangeleverd en kan deze niet vanuit een form samenstellen ;)
zie ik daar allemaal eval()'s? :/
[ Voor 4% gewijzigd door crisp op 25-07-2006 00:14 ]
  • aex351
aex351
I am the one
crisp schreef op dinsdag 25 juli 2006 @ 00:13:
Wat bedoel je precies met de POST-body al kant en klaar moet worden aangeleverd ten opzichte van wat de topic starter precies wilt.
  • crisp
crisp
Devver
Pixelated
aex351 schreef op dinsdag 25 juli 2006 @ 00:25:
Het samenvoegen van de form-data om uiteindelijk in je Ajax-request op te sturen:
JavaScript:
xmlhttp.send(data);
