[.Net]Wil geen video of audio meer afspelen,normale apps wel
  • 127 views sinds 30-01-2008
  • Belial_666
  • Laatst online: 27-09 20:19
Ik gebruik Media portal, dit is een Media Center programma dat gemaakt is in .Net :(
Nu wil, na een windows update die 3 updates voor .Net bevatte, Media Portal geen Direct Show filters meer gebruiken. Media player classic speelt wel alle fims en muziek af, Dus het is iets met .Net dat er voor zorgt dat MP geen films of mp3's kan afspelen
Mediaportal/log
18-Jul-06 18:36:58 OnMessage exception:System.IO.FileNotFoundException: The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
at System.Runtime.InteropServices.ComTypes.IRunningObjectTable.Register(Int32 grfFlags, Object punkObject, IMoniker pmkObjectName)
at DirectShowLib.DsROTEntry..ctor(IFilterGraph graph)
at MediaPortal.Player.VideoPlayerVMR7.Play(String strFile)
at MediaPortal.Player.g_Player.Play(String strFile)
at MediaPortal.Playlists.PlayListPlayer.FakePlayer.MediaPortal.Playlists.PlayListPlayer.IPlayer.Play(String strFile)
at MediaPortal.Playlists.PlayListPlayer.Play(Int32 iSong)
at MediaPortal.Playlists.PlayListPlayer.PlayNext()
at MediaPortal.GUI.Video.GUIVideoFiles.PlayMovieFromPlayList(Boolean askForResumeMovie, Int32 iMovieIndex)
at MediaPortal.GUI.Video.GUIVideoFiles.OnClick(Int32 iItem)
at MediaPortal.GUI.Video.GUIVideoBaseWindow.OnClicked(Int32 controlId, GUIControl control, ActionType actionType)
at MediaPortal.GUI.Library.GUIWindow.OnMessage(GUIMessage message)
18-Jul-06 18:36:58 1 VMR9Helper: playing->repaint 0
18-Jul-06 18:36:58 g_Player.Process() player stopped...
18-Jul-06 18:36:58 g_Player.Stop()
18-Jul-06 18:36:58 VideoPlayer9:cleanup DShow graph
18-Jul-06 18:36:58 state:Stopped 0
18-Jul-06 18:36:58 1 vmr9:Dispose
18-Jul-06 18:36:58 VMR9: not active
18-Jul-06 18:36:58 planescene: PresentImage()
18-Jul-06 18:36:58 PlaneScene: PresentImage() dispose surfaces
18-Jul-06 18:36:58 1 VMR9:ReleaseComObject():0
18-Jul-06 18:36:58 VideoPlayerVMR9: Disabling DX9 exclusive mode
18-Jul-06 18:36:58 Main: DX exclusive mode: False
18-Jul-06 18:36:58 Main: Goto windowed mode: False
18-Jul-06 18:36:58 D3D: Switch to windowed mode - Playing media: False
18-Jul-06 18:36:58 D3D: Switched to windowed mode successfully
Error.log
VMR9 Log:
18-07-2006 18:36:55 [2b0]----------v0.37---------------------------
18-07-2006 18:36:55 [2b0]vmr9:AdviseNotify()
18-07-2006 18:36:56 [2b0]vmr9:TerminateDevice()
18-07-2006 18:36:56 [2b0]vmr9:DeleteSurfaces()
18-07-2006 18:36:57 [2b0]vmr9:TerminateDevice()
18-07-2006 18:36:57 [2b0]vmr9:DeleteSurfaces()
18-07-2006 18:36:57 [2b0]vmr9:InitializeDevice() 640x368 AR 640:368 flags:24 buffers:1 fmt:(32315659) YV12
18-07-2006 18:36:57 [2b0]vmr9:flags:
18-07-2006 18:36:57 [2b0]vmr9: OffscreenSurface
18-07-2006 18:36:57 [2b0]vmr9: RGBDynamicSwitch
18-07-2006 18:36:57 [2b0]vmr9:InitializeDevice() done()
18-07-2006 18:36:57 [2b0]vmr9:SetDeinterlace() SetDeinterlaceMode(0)
18-07-2006 18:36:57 [2b0]vmr9:SetDeinterlace() failed hr:0x80070057
18-07-2006 18:36:57 [2b0]vmr9:SetDeinterlace() deinterlace mode OFF: 0x0-0x0-0x0-0x0-0x0-0x0-0x0-0x0-0x0-0x0-0x0
18-07-2006 18:36:58 [2b0]vmr9:TerminateDevice()
18-07-2006 18:36:58 [2b0]vmr9:DeleteSurfaces()
18-07-2006 18:36:58 [2b0]CVMR9AllocatorPresenter::Release()
18-07-2006 18:36:58 [2b0]CVMR9AllocatorPresenter::Cleanup()
18-07-2006 18:36:58 [2b0]Vmr9Deinit:m_vmr9Presenter release:0
Heb de google, IRC van MP en newsgroeps al gezocht maar kan niets vinden. updates gedeinstallerd en .net op nieuw geinstaleerd maar geen effect
Wie kan mijn helpen,m heb geen zin om door .Net (.NOT) windows opnieuw te moeten instalerne
  • Morax
  • Laatst online: 16:28
Ik heb totaal geen ervaring met .NET, maar als ik die melding lees zie ik toch een paar keer een duidelijke melding voorbij komen:
Dus ik weet niet of er een fout zit bij het starten van een niet bestaand filmpje ofzo? :)
What do you mean I have no life? I am a gamer, I got millions!
  • Belial_666
nice1 maar wat zou de oplossing zijn dan, Mediaportal ziet de file gewoon staan
Mp ziet alle .avi of mpg files gewoon staaan alleen speelt ie ze niet af
  • Morax
Misschien een probleem met hoofdletters en dergelijke. Zet het programma misschien alles om naar lower-caps, en kloppen de hoofdletters niet meer oid.
Nogmaals, ik heb geen ervaring met .NET in enige zin, dus ik gooi zomaar een balletje op ;)
