[XP] Windows update werkt niet via IE, wel via built-in*
  • BasieP
  • Laatst online: 19-10-2025
beste mensen en mensinnen
ik heb een probleempje..
sinds een tijdje kan ik windows update niet meer uitvoeren. Ik deed dit altijd handmatig (www.windowsupdate.com) en dat ging altijd goed. Echter nu krijg ik deze melding:
[Error number: 0x8DDD0018]
The site cannot continue because one or more of these Windows services is not running:
Automatic Updates (allows the site to find, download and install high-priority updates for your computer)
Background Intelligent Transfer Service (BITS) (helps updates download more quickly and without problems if the download process is interrupted)
Event Log (keeps a record of updating activities to help with troubleshooting, if needed)
To make sure these services are running:
1. Click Start, and then click Run.
2. Type services.msc and then click OK.
3. In the list of services, double-click on Automatic Updates and then click Properties.
4. In the Startup type list, select Automatic and click Apply.
5. Verify that the Service status is started, if the Service Status is Stopped click on the Start Button.
6. In the list of services, double-click on Background Intelligent Transfer Service (BITS) and then click Properties.
7. In the Startup type list, select Manual and click Apply.
8. Verify that the Service status is started, If the Service Status is Stopped click on the Start Button.
9. In the list of services, double-click on Event Log and then click Properties.
10. In the Startup type list, select Automatic and click Apply.
11. Verify that the Service status is started, If the Service Status is Stopped click on the Start Button.
If this does not resolve the problem you may request help from one of the following resources.
For self-help options:
Frequently Asked Questions
Find Solutions
Windows Update Newsgroup
For assisted support options:
Microsoft Online Assisted Support (no-cost for Windows Update issues)
echter, de services draaien wel gewoon, en zelfs na restart of stop en dan start werkt windows update nog steeds niet.
ik heb geen firewalls, en heb op me router inmiddels al DMZ naar me pc ingesteld.
Binnenkort lan, en ik zou wel graag up-to-date zijn aldaar.
iemand nog tips?
ik kan in de got search de hele error niet vinden, en in de links die op de MS site staan zeggen allemaal dat de services moeten starten, maar dat weet ik onderdehand wel.
edit: owja even voor de volledigheid:
IE 6.x en XP met SP2
[ Voor 3% gewijzigd door BasieP op 13-07-2006 21:19 ]
This message was sent on 100% recyclable electrons.
  • Invisible_man
  • Laatst online: 14:44
Al eens een update vanuit windows zelf geprobeerd?
  • BasieP
Invisible_man schreef op donderdag 13 juli 2006 @ 21:21:
ja heb een uurtje terug die optie weer aangezet, maar ik zie geen icoontje in me system tray.. dus of hij vind niks of hij is helemaal niet gestart zoals ik aangevinkt heb
  • Invisible_man
Afhankelijk van hoe je het ingesteld hebt, kan het even duren voordat hij met een melding komt omdat hij dan eerst de updates gaat downloaden. Of hij vind dat je systeem up to date is.
Voor een LAN kan je er trouwens beter voor zorgen dat je virusscanner in orde is. Vooral gezien je vrij recent nog wel een windows update hebt gehad hoef je je voor de LAN nog niet zo druk te maken.
  • pistole
  • Laatst online: 19:59
pistole
Frutter
Invisible_man schreef op donderdag 13 juli 2006 @ 21:29:
wuauclt.exe /detectnow
Als ie gaat downloaden dan zie je het icoon al in de systray.
Ik frut, dus ik epibreer
  • BasieP
ik zie geen icoontje in me systay, ook niet na 'wuauclt.exe /detectnow'
verder is mijn laatste update niet zo heel recent.. aangezien ik die handmatige check volgens mij voor het laatst een half jaar terug heb uitgevoerd
wuauclt.exe is nu trouwens wel actief (proces draait) en vreet 10 mb ram (een van de redenen dat ie dus uit staat hier)
[ Voor 24% gewijzigd door BasieP op 13-07-2006 21:45 ]
  • pistole
pistole
Frutter
BasieP schreef op donderdag 13 juli 2006 @ 21:44:wuauclt.exe is nu trouwens wel actief (proces draait) en vreet 10 mb ram (een van de redenen dat ie dus uit staat hier)
Je doet zeker ook boodschappen bij de Aldi ;)
Maar zonder dollen, dat is natuurlijk de service van Automatic Updates. Heb je niet toevallig een niet-geheel legale versie van Windows. Heb je het Security Center gecheckt? Staan er meldingen in je eventlog (logboeken)?
correctie, wuauclt.exe is het proces dat check of er iets nieuws is; de service zelf draait onder een svchost.exe
[ Voor 13% gewijzigd door pistole op 13-07-2006 21:51 ]
  • BasieP
pistole schreef op donderdag 13 juli 2006 @ 21:49:
dat lijkt me een beetje een non-vraag
security center zegt niks. dat zijn 3 icoontjes, die gewoon wijzen naar firewall/updates en iets loos van IE
logboeken zeggen dit:
Installation Ready: The following updates are downloaded and ready for installation. To install the updates, an administrator should log on to this computer and Windows will prompt with further instructions:
- Security Update for Windows XP (KB914389)
- Cumulative Security Update for Internet Explorer for Windows XP (KB916281)
- Windows Malicious Software Removal Tool - July 2006 (KB890830)
- Update for Windows XP (KB916595)
- Security Update for Windows XP (KB917953)
- Security Update for Windows Media Player 10 for Windows XP (KB917734)
For more information, see Help and Support Center at
en dat zo'n 100x.. (in hetzelfde uur)
dus mooi, ik kan iig updaten... :)
echter, dat verklaard nog niet waarom de website het niet doet.. ik heb geen zin om die services aan te houden wanneer dat niet nodig is,en wil eigenlijk weer via de website updaten...
  • frickY
  • Laatst online: 03-10 19:20
Heb me ook eens weken lopen rotzoeken waarom mijn systeem (ik meen win98) niet wilde updaten. De systeemdatum bleek ver in het verleden te staan vanwege een lege BIOS-batterij.
Ondanks dat het me stug lijkt, opper ik het toch maar; Staat je systeemtijd correct ingesteld?
  • Invisible_man
Ik kon ooit onder win2000 niet updaten omdat ik daar eerst een nieuwere ie voor moest instaleren. Alleen had die pc te weinig geheugen om die ie te kunnen installeren, dus kon ook niet updaten.
Maar goed, dit is een ander probleem.
  • elevator
elevator
Officieel moto fan :)
BasieP schreef op donderdag 13 juli 2006 @ 22:00:
Die services heb je denk ik gewoon nodig - je kan toch ze 'on demand' starten (eventueel met een batch file) en dan de automatic updates client zo instellen dat hij niks automatisch download? :)
geen admin = geen updates draaien
