[MCE/XBOX] App disconnects MCE & Xbox360 after playing vid
I use XBOX 360 as extender of XP Media Center Edition.
Media streaming between PC and Xbox is working well. One problem though.
When a movie ends or is stopped the connection is lost. The message that is generated by MCE and that appears on the TV reads: "another user or application on the windows media center-based PC has disconnected this device". I have to exit Media Center and launch it again to watch another wmv file.
The PC system event logs the following events after during this disconnect:
Application popup: ehshell.exe - Common Language Runtime Debugging Services : Application has generated an exception that could not be handled.
Application popup: verclsid.exe - DLL Initialization Failed : The application failed to initialize because the window station is shutting down.
Application popup: rundll32.exe - DLL Initialization Failed : The application failed to initialize because the window station is shutting down.
I've searched the internet for a solution but came up with nothing.
Please help. Thank you. Arjan
Patches en Programs that are installed on my system:
- .Net Framework 1.0 (Hotfix KB887998)
- .Net Framework 1.1
- .Net Framework 1.1 (Hotfix KB886903)
- .Net Framework 2.0
- Windows XP Media Center Edition 2005
- Update Rollup 2
- Windows XP Media Center Edition 2005 (KB905589)
- Windows XP Media Center Edition 2005 (KB914548)
- All sorts of Windows XP updates & Hotfixes
