Maxtor Personal storage 3200 (USB 2.0) niet te formatteren
  • 1.349 views sinds 30-01-2008
  • compu_kneus
  • Laatst online: 15-03 09:03
Heren en dames,
Ik heb vandaag gekocht de Maxtor personal storage 3200 USB maar tijdens het inpluggen kreeg ik de melding dat ik een oude USB versie gebruik en hierdoor trage overdracht krijg. Nou daar zou ik mee kunnen leven alleen zie ik in mijn mappen bij Windows Verkenner heel de externe harde schijf niet terug???
Nu heb ik de site van Maxtor erop nageslagen en die zeiden het volgende :
Windows XP & 2000 support for USB2.0
Question
After installing the USB external hard drive - Device Manager may display a yellow exclamation mark beside the device and/or USB2 PCI Adapter Card.
How to open Device Manager.
When checking device status you may receive this message:
Universal Serial Bus (USB) Controller. The drivers for this device are not installed (code 28).
Answer
Microsoft provides USB 2.0 support for Windows XP and Windows 2000. Microsoft does not provide USB 2.0 support for previous version of Windows.
To install support for USB 2.0 in Windows XP, visit the Windows Update Web site. Install the Microsoft USB Driver driver from the 'Driver Updates' section:
Microsoft Usb Driver Version 5.1.2600.0 Download size: 290 KB (File version numbers are the same for Windows XP and Windows 2000. A visible difference is the Windows 2000 version of this driver is 107 KB in size).
Note: USB2.0 drivers will load automatically if the computer is connected to the Internet with a USB controller already installed. The plug and play software wizard will find the new hardware and automatically install drivers for the USB2 controller. The Microsoft USB 2.0 driver may not be listed if third-party USB 2.0 drivers are installed. First remove all third-party USB 2.0 drivers, then install the Microsoft USB 2.0 driver from the Windows Update site.
For additional information on USB 2.0 please visit the following Microsoft knowledge base articles:
Q312370 Universal Serial Bus 2.0 support in Windows XP
Q319973 Universal Serial Bus 2.0 support in Windows 2000
Probleem is nu dat ik die service packs niet kan downloaden (jullie begrijpen wel waarom ;-) ) en dus niet de juiste driver kan downloaden. Microsoft Usb Driver Version 5.1.2600.0
Wie o wie kan mij hieraan helpen.
Mijn computer is wel 2.0 compatible.
Groeten,
Compu-Kneus
  • roelio
roelio
fruitig, en fris.
Als je XP hebt, installeer Windows XP ServicePack 2 en het zou moeten werken :)
Die kun je evt ook op een andere PC downloaden (;))
[ Voor 26% gewijzigd door roelio op 10-07-2006 19:45 ]
  • The Eagle
  • Laatst online: 17:53
The Eagle
I wear my sunglasses at night
Tsja, als jij zegt
omdat je met een illegale versie draait, dan is dat toch echt jouw probleem.
Dan kunnen wij niet helpen, zie ook Het algemeen beleid #copyright
En ook logisch: XP ondersteunt USB 2.0 alleen vanaf SP2. Dus hoe je het ook wend of keert, nodig heb je dat toch. Hoe je er aan komt is jouw probleem.
  • jimbojansen
  • Laatst online: 11-10 19:31
Dit topic hoort niet op GoT.. zie kerel boven mij..
[ Voor 98% gewijzigd door jimbojansen op 10-07-2006 20:09 ]
  • BalusC
BalusC
Carpe diem
De oplossing is om minimaal SP1 te installeren. Dat je een illegale Windows hebt kunnen we weinig aan doen.
