[tomcat] Opstarterror "InvocationTargetException"
  • Mephisteus
Dit is wat ik krijg wanneer ik tomcat opstart
29
30
31
32
33
34
35
36
37
38
39
C:\Werk\tomcat\bin>catalina.bat debug
Using CATALINA_BASE:   c:\Werk\tomcat
Using CATALINA_HOME:   c:\Werk\tomcat
Using CATALINA_TMPDIR: c:\Werk\tomcat\temp
Using JAVA_HOME:       c:\Program Files\Java\jdk1.5.0_07
Initializing jdb ...
> run
run org.apache.catalina.startup.Bootstrap start
Set uncaught java.lang.Throwable
Set deferred uncaught java.lang.Throwable
VM Started: 30-jun-2006 23:58:17 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-80
30-jun-2006 23:58:18 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8443
30-jun-2006 23:58:18 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2719 ms
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:585)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:271)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:409)
Caused by: java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
        at org.apache.naming.NamingContext.<clinit>(NamingContext.java:57)
        at org.apache.catalina.core.NamingContextListener.lifecycleEvent(NamingC
ontextListener.java:207)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:119)
        at org.apache.catalina.core.StandardServer.start(StandardServer.java:676
        at org.apache.catalina.startup.Catalina.start(Catalina.java:537)
        ... 6 more
The application exited
Weet iemand hoe ik dit kan fixen? Ik heb de omgevingsvariabelen gecontroleerd, heb tomcat opnieuw geinstalleerd, heb java opnieuw geinstalleerd en nog doet hij het niet. Blijkbaar is commons-logging-api.jar de schuldige maar die staat gewoon in de bin directory en ik krijg ook de error nadat ik een nieuwe heb gedownload.
Het is misschien handig om te weten dat hij het eerst wel deed. Maar ik heb sindsdien dus alles terug gezet naar hoe het was en nog doet hij het niet. Heeft iemand een idee?
