1 Wsus-client : Not yet Reported
  • 242 views sinds 30-01-2008
Goedenmiddag,
ik heb hier WSUS goed draaien. Zo`n 30 clients die netjes zichtbaar zijn binnen WSUS.
Echter heb ik 1 client die maar blijft staan : Not yet Reported
Windows XP Sp1 (net als alle andere clients)
Gpupdate /force en wuauclt.exe /detectnow al uitgevoerd
Log windowsupdate.log:
2006-06-20 15:04:10 1232 6d0 Setup *********** Setup: Checking whether self-update is required ***********
2006-06-20 15:04:10 1232 6d0 Setup * Inf file: C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wusetup.inf
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\cdm.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\iuengine.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuapi.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuauclt.exe: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuauclt1.exe: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuaucpl.cpl: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuaueng.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuaueng1.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wucltui.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wups.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wups2.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup Update NOT required for C:\WINDOWS\System32\wuweb.dll: target version = 5.8.0.2607, required version = 5.8.0.2607
2006-06-20 15:04:10 1232 6d0 Setup * IsUpdateRequired = No
2006-06-20 15:04:11 1232 6d0 PT +++++++++++ PT: Synchronizing server updates +++++++++++
2006-06-20 15:04:11 1232 6d0 PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://nij-sys001/ClientWebService/client.asmx
2006-06-20 15:04:11 1232 6d0 PT Initializing simple targeting cookie, clientId = 0df58a0d-3025-4da5-a132-0a9763262edc, target group = , DNS name = nij-nb0006.nl-nij-hartmann.corp.intl
2006-06-20 15:04:11 1232 6d0 PT Server URL = http://nij-sys001/SimpleAuthWebService/SimpleAuth.asmx
2006-06-20 15:04:12 1232 6d0 PT WARNING: GetCookie failure, error = 0x8024400D, soap client error = 7, soap error code = 300, HTTP status code = 200
2006-06-20 15:04:12 1232 6d0 PT WARNING: SOAP Fault: 0x00012c
2006-06-20 15:04:12 1232 6d0 PT WARNING: faultstring:Fault occurred
2006-06-20 15:04:12 1232 6d0 PT WARNING: ErrorCode:ServerChanged(4)
2006-06-20 15:04:12 1232 6d0 PT WARNING: Message:Server rolled back since last call to GetCookie
2006-06-20 15:04:12 1232 6d0 PT WARNING: Method:"http://www.microsoft.com/SoftwareDistribution/Server/ClientWebService/GetCookie"
2006-06-20 15:04:12 1232 6d0 PT WARNING: ID:e86f4935-3295-41a8-b451-3dafb2f913ad
2006-06-20 15:04:12 1232 6d0 PT WARNING: Sync of Updates: 0x80244015
2006-06-20 15:04:12 1232 6d0 PT Initializing simple targeting cookie, clientId = 0df58a0d-3025-4da5-a132-0a9763262edc, target group = , DNS name = nij-nb0006.nl-nij-hartmann.corp.intl
2006-06-20 15:04:12 1232 6d0 PT Server URL = http://nij-sys001/SimpleAuthWebService/SimpleAuth.asmx
2006-06-20 15:04:29 1232 6d0 Agent * WARNING: Failed to synchronize, error = 0x80244015
2006-06-20 15:04:29 1232 6d0 DnldMgr File locations for service 3DA21691-E39D-4DA6-8A4B-B43877BCB1B7 changed
2006-06-20 15:04:29 1232 6d0 Agent Server changed and need resyncing with server
2006-06-20 15:04:29 1232 6d0 PT +++++++++++ PT: Synchronizing server updates +++++++++++
2006-06-20 15:04:29 1232 6d0 PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://nij-sys001/ClientWebService/client.asmx
2006-06-20 15:04:57 1232 6d0 PT +++++++++++ PT: Synchronizing extended update info +++++++++++
2006-06-20 15:04:57 1232 6d0 PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://nij-sys001/ClientWebService/client.asmx
2006-06-20 15:04:57 1232 6d0 PT WARNING: GetExtendedUpdateInfo failure, error = 0x8024400A, soap client error = 10, soap error code = 0, HTTP status code = 200
2006-06-20 15:04:57 1232 6d0 PT WARNING: Sync of Extended Info: 0x8024400a
2006-06-20 15:04:57 1232 6d0 Report *********** Report: Initializing static reporting data ***********
2006-06-20 15:04:57 1232 6d0 Report * OS Version = 5.1.2600.1.0.65792
2006-06-20 15:04:57 1232 6d0 Report * Computer Brand = Hewlett-Packard
2006-06-20 15:04:57 1232 6d0 Report * Computer Model = Pavilion ze8500 (DJ316A)
2006-06-20 15:04:57 1232 6d0 Report * Bios Revision = KF_KH.F.25
2006-06-20 15:04:57 1232 6d0 Report * Bios Name = PhoenixBIOS 4.0 Release 6.0
2006-06-20 15:04:57 1232 6d0 Report * Bios Release Date = 2005-05-03T00:00:00
2006-06-20 15:04:57 1232 6d0 Report * Locale ID = 1043
2006-06-20 15:04:57 1232 6d0 Agent * WARNING: Exit code = 0x8024400A
2006-06-20 15:04:57 1232 6d0 Agent *********
2006-06-20 15:04:57 1232 6d0 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2006-06-20 15:04:57 1232 6d0 Agent *************
2006-06-20 15:04:57 1232 6d0 Agent WARNING: WU client failed Searching for update with error 0x8024400a
2006-06-20 15:04:57 1232 6d0 AU >>## RESUMED ## AU: Search for updates [CallId = {52E2A717-E205-4AEE-9377-2114A64D2F40}]
2006-06-20 15:04:57 1232 6d0 AU # WARNING: Search callback failed, result = 0x8024400A
2006-06-20 15:04:57 1232 6d0 AU #########
2006-06-20 15:04:57 1232 6d0 AU ## END ## AU: Search for updates [CallId = {52E2A717-E205-4AEE-9377-2114A64D2F40}]
2006-06-20 15:04:57 1232 6d0 AU #############
2006-06-20 15:04:57 1232 6d0 AU AU setting next detection timeout to 2006-06-20 14:00:07
2006-06-20 15:05:02 1232 6d0 Report REPORT EVENT: {8F6969D5-6B63-4678-A409-EACA30CA41D1} 2006-06-20 15:04:57+0200 1 148 101 {00000000-0000-0000-0000-000000000000} 0 8024400a AutomaticUpdates Failure Software Synchronization Error: Agent failed detecting with reason: 0x8024400a
2006-06-20 15:13:26 1232 7f4 Report Uploading 1 events using cached cookie, reporting URL = http://nij-sys001/ReportingWebService/ReportingWebService.asmx
2006-06-20 15:13:26 1232 7f4 Report Reporter successfully uploaded 1 events.
  • marquis
  • Laatst online: 18-07 11:19
Jep, dit heb ik ook gehad, maar daar ging het om XP machines die een image hadden die nog op het oude NT domein waren gemaakt. Het leek of het systeem niet compatible was met een 2003 omgeving. Met systemen die een nieuwe image hadden, was er geen probleem. Heb je al eens de Windows Installer 3.1 gedraaid?
Ff een handige link naar de twee updates die het updaten wel bevorderen: http://support.microsoft.com/?kbid=842773
[ Voor 26% gewijzigd door marquis op 20-06-2006 15:31 ]
Adem in...... adem uit. Poeh, weer gered :-)
Installer 3.1 staat er op....
  • Nielson
  • Laatst online: 07:15
Draai op die pc eens ClientDiag en post even wat die aangeeft.
Vannocht heeft de betreffende pc ineens wel gerapporteerd. Waarom nu wel weet ik niet. Maar het resultaat is er...als iemand nog een tip heeft waarom nu wel hoor ik het graag. We hebben nl. nog 30 clients...en of die nu allemaal goed gaan??
  • marquis
Verwijderd schreef op woensdag 21 juni 2006 @ 08:46:
Misschien leuk om te melden of je wat aan die link heb gehad die ik je heb opgestuurd? Geeft mij ook een beetje voldoening? O-)
Goedenmorgen, heb je gelijk in.
Nee met link had ik nog niets gedaan.
Jammer dat ik nu nog steeds niet weet waarom het eerst nog niet werkte...
marquis schreef op woensdag 21 juni 2006 @ 12:33:
