MSDE 2000 Installatie errors
Ik heb installatie problemen met MSDE 2000 op een windows 2000 server.
Wat is het probleem
Zie log file
Wat ik oa geprobeerd heb:
Handmatig gedeinstalleerd http://support.microsoft.com/kb/320873/EN-US/
Op google naar oplossingen gezocht
Herstellen via configuratiescherm software.
Heeft iemand een idee hoe ik dit probleem asap op kan lossen ?
Installatie Log File
2006-06-19 14:27:08.07 server Microsoft SQL Server 2000 - 8.00.760 (Intel X86)
Dec 17 2002 14:22:05
Copyright (c) 1988-2003 Microsoft Corporation
Desktop Engine on Windows NT 5.0 (Build 2195: Service Pack 4)
2006-06-19 14:27:08.07 server Copyright (C) 1988-2002 Microsoft Corporation.
2006-06-19 14:27:08.07 server All rights reserved.
2006-06-19 14:27:08.07 server Server Process ID is 4016.
2006-06-19 14:27:08.07 server Logging SQL Server messages in file 'C:\Program Files\Microsoft SQL Server\MSSQL\LOG\ERRORLOG'.
2006-06-19 14:27:08.09 server SQL Server is starting at priority class 'normal'(2 CPUs detected).
2006-06-19 14:27:08.12 server Performance monitor shared memory setup failed: -1
2006-06-19 14:27:08.21 server SQL Server configured for thread mode processing.
2006-06-19 14:27:08.21 server Using dynamic lock allocation. [500] Lock Blocks, [1000] Lock Owner Blocks.
2006-06-19 14:27:08.31 spid4 Warning ******************
2006-06-19 14:27:08.31 spid4 SQL Server started in single user mode. Updates allowed to system catalogs.
2006-06-19 14:27:08.40 spid4 Starting up database 'master'.
2006-06-19 14:27:08.71 server Using 'SSNETLIB.DLL' version '8.0.766'.
2006-06-19 14:27:08.71 spid5 Starting up database 'model'.
2006-06-19 14:27:08.87 spid4 Server name is 'BOTTEL01'.
2006-06-19 14:27:08.89 spid4 Skipping startup of clean database id 5
2006-06-19 14:27:08.89 spid4 Skipping startup of clean database id 6
2006-06-19 14:27:08.89 spid4 Starting up database 'msdb'.
2006-06-19 14:27:09.01 server SQL server listening on Shared Memory.
2006-06-19 14:27:09.03 server SQL Server is ready for client connections
2006-06-19 14:27:09.09 spid5 Clearing tempdb database.
2006-06-19 14:27:10.51 spid5 Starting up database 'tempdb'.
2006-06-19 14:27:10.64 spid4 Warning ******************
2006-06-19 14:27:10.64 spid4 Attempting to change default collation to Latin1_General_CI_AS.
2006-06-19 14:27:13.49 spid4 Clustered index restored for master.sysdatabases.
2006-06-19 14:27:13.56 spid4 Non-clustered index restored for master.sysobjects.
2006-06-19 14:27:13.59 spid4 Non-clustered index restored for master.sysobjects.
2006-06-19 14:27:13.60 spid4 index restored for master.syscolumns.
2006-06-19 14:27:13.63 spid4 index restored for master.systypes.
2006-06-19 14:27:13.65 spid4 index restored for master.sysusers.
2006-06-19 14:27:14.56 spid4 index restored for master.sysproperties.
2006-06-19 14:27:14.73 spid4 index restored for master.sysfulltextcatalogs.
2006-06-19 14:27:15.60 spid4 index restored for master.sysxlogins.
2006-06-19 14:27:15.64 spid4 index restored for master.sysdevices.
2006-06-19 14:27:15.79 spid4 index restored for master.sysservers.
2006-06-19 14:27:18.65 spid4 index restored for master.syslanguages.
2006-06-19 14:27:18.68 spid4 index restored for master.syscharsets.
2006-06-19 14:27:18.73 spid4 index restored for master.sysfilegroups.
2006-06-19 14:27:19.00 spid4 index restored for master.spt_values.
2006-06-19 14:27:19.01 spid4 index restored for master.MSreplication_options.
2006-06-19 14:27:19.06 spid4 index restored for master.spt_datatype_info_ext.
2006-06-19 14:27:19.07 spid4 index restored for master.spt_datatype_info.
2006-06-19 14:27:19.37 spid4 Non-clustered index restored for tempdb.sysobjects.
2006-06-19 14:27:19.39 spid4 Non-clustered index restored for tempdb.sysobjects.
2006-06-19 14:27:19.40 spid4 index restored for tempdb.syscolumns.
2006-06-19 14:27:19.42 spid4 index restored for tempdb.systypes.
2006-06-19 14:27:19.42 spid4 index restored for tempdb.sysusers.
2006-06-19 14:27:19.42 spid4 index restored for tempdb.sysproperties.
2006-06-19 14:27:19.42 spid4 index restored for tempdb.sysfulltextcatalogs.
2006-06-19 14:27:19.42 spid4 index restored for tempdb.sysfilegroups.
2006-06-19 14:27:19.45 spid4 Non-clustered index restored for model.sysobjects.
2006-06-19 14:27:19.46 spid4 Non-clustered index restored for model.sysobjects.
2006-06-19 14:27:19.54 spid4 index restored for model.syscolumns.
2006-06-19 14:27:19.57 spid4 index restored for model.systypes.
2006-06-19 14:27:19.65 spid4 index restored for model.sysusers.
2006-06-19 14:27:19.67 spid4 index restored for model.sysproperties.
2006-06-19 14:27:19.67 spid4 index restored for model.sysfulltextcatalogs.
2006-06-19 14:27:19.67 spid4 index restored for model.sysfilegroups.
2006-06-19 14:27:20.07 spid4 Non-clustered index restored for msdb.sysobjects.
2006-06-19 14:27:20.09 spid4 Non-clustered index restored for msdb.sysobjects.
2006-06-19 14:27:20.12 spid4 index restored for msdb.syscolumns.
2006-06-19 14:27:20.12 spid4 index restored for msdb.systypes.
2006-06-19 14:27:20.12 spid4 index restored for msdb.sysusers.
2006-06-19 14:27:20.14 spid4 index restored for msdb.sysproperties.
2006-06-19 14:27:20.14 spid4 index restored for msdb.sysfulltextcatalogs.
2006-06-19 14:27:20.15 spid4 index restored for msdb.sysfilegroups.
2006-06-19 14:27:20.17 spid4 index restored for msdb.sysjobschedules.
2006-06-19 14:27:20.17 spid4 index restored for msdb.syscategories.
2006-06-19 14:27:20.18 spid4 index restored for msdb.systargetservers.
2006-06-19 14:27:20.18 spid4 index restored for msdb.systargetservergroups.
2006-06-19 14:27:21.32 spid4 index restored for msdb.sysalerts.
2006-06-19 14:27:21.32 spid4 index restored for msdb.sysoperators.
2006-06-19 14:27:21.32 spid4 index restored for msdb.syscachedcredentials.
2006-06-19 14:27:21.35 spid4 index restored for msdb.logmarkhistory.
2006-06-19 14:27:21.35 spid4 index restored for msdb.sysdtscategories.
2006-06-19 14:27:21.35 spid4 index restored for msdb.sysdbmaintplan_databases.
2006-06-19 14:27:21.35 spid4 index restored for msdb.mswebtasks.
2006-06-19 14:27:21.35 spid4 index restored for msdb.sysdownloadlist.
2006-06-19 14:27:21.35 spid4 index restored for msdb.sysjobs.
2006-06-19 14:27:21.35 spid4 index restored for msdb.sysjobsteps.
2006-06-19 14:27:22.99 spid4 Default collation successfully changed.
2006-06-19 14:27:23.01 spid4 Recovery complete.
2006-06-19 14:27:23.03 spid4 Warning: override, autoexec procedures skipped.
2006-06-19 14:29:03.87 spid4 SQL Server is terminating due to 'stop' request from Service Control Manager.
iemand een idee ?
  • MAX3400
  • Laatst online: 09:42
MAX3400
XBL: OctagonQontrol
En, valt er nog iets terug te vinden in je EventLogs hierover? En zo ja, heb je dan de events weer via www.eventid.net of www.microsoft.com/support teruggezocht?
  • TeeDee
  • Laatst online: 22:29
TeeDee
CQB 241
From BOL:
You can configure an instance of SQL Server to start automatically each time you start the Microsoft Windows NT® 4.0 or Windows® 2000 operating system.
Since the OS did not restart, then SQL Server did not restart.
en anders deze Google opdracht.
Heart..pumps blood.Has nothing to do with emotion! Bored
  • TeeDee
TeeDee
CQB 241
En? Is het opgelost?
Ik kan niks in de logboeken vinden, en de oplossingen via google bieden tot op heden ook nog niet het gewenste resultaat
We hebben nog diversen dingen probeerd, maar niks helpt.
[ Voor 25% gewijzigd door Verwijderd op 21-06-2006 11:40 ]
  • Mickman
  • Laatst online: 29-03 18:11
Wordt het zowieso ondersteund. MSDE op een server?
Het niet natuurlijk niet voor niets Microsoft SQL Server Desktop Engine
Heb je SQL Server 2005 Express Edition al geprobeerd?
[ Voor 18% gewijzigd door Mickman op 22-06-2006 09:20 ]
  • docftp
Het wordt wel ondersteund op een Windows 2000 server, wij hebben hier meerdere machines die software draaien waar de MSDE wordt meegeleverd en dat gaat feilloos.
Dus dat zal het probleem niet zijn.
En het verschil tussen Enterprise en Standard is ook niet van toepassing.
DataCenter kan ik geen oordeel over trekken, want die heb ik zelfs nog nooit van dichtbij gezien.
Zou het een probleem zijn als ik een IQ zou hebben van een glas water?
Mickman schreef op donderdag 22 juni 2006 @ 09:18:
Is SQL Server 2005 Express Edition gratis ?
