[FLASH] loadclip + dimensions
  • 55 views sinds 30-01-2008
Hi all!!!
I've finaly made my component but can accross the issue of aligning the
newly loaded content...
I can align correctly images but swf is a bit complicated...
1. If I load a SWF that the stage is 300*300 but on frame 1 there is
only 1 MC of 100*100, the with of the newly loaded SWF is 100*100 like
it does'nt take into account the stage dimensions!
2. If I load the same SWF but with content outside its stage borders
(-100,-100), the dimention are now 200*200....
How can I center it now?!?!?!?
Is there a way to know once loaded the stage dimentions of the newly
loaded SWF... (even the _lockroot does not function....)
There will be SWF files that will be produced by third parties!
Thanks a million.
  • BtM909
BtM909
Watch out Guys...
Als je niet eens de moeite neemt om gewoon Nederlands te typen op een Nederlands forum dan neem ik die moeite ook niet :/
