[posfix] match_list_parse problemen
  • Boudewijn
Boudewijn
omdat het kan
Hoi
Ik heb weer eens wat leuke problemen met een verse postfix install.
Het gaat om een amd64 gentoo box, volgens deze guide opgezet: http://www.gentoo.org/doc/en/virt-mail-howto.xml
ik heb de volgende config aangemaakt ervoor:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
myhostname = krab. <domein>
mydomain =  <domein>
inet_interfaces = all
mydestination = localhost, localhost. <domein>,  <domein>
mynetworks = 127.0.0.0/8, 192.168.4.0/24
local_destination_concurrency_limit = 2
default_destination_concurrency_limit = 10
queue_directory = /var/spool/postfix
command_directory = /usr/sbin
daemon_directory = /usr/lib/postfix
mail_owner = postfix
unknown_local_recipient_reject_code = 550
debug_peer_level = 5
debugger_command =
         PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
         xxgdb $daemon_directory/$process_name $process_id & sleep 5
debug_peer_list = 127.0.0.1
sendmail_path = /usr/sbin/sendmail
newaliases_path = /usr/bin/newaliases
mailq_path = /usr/bin/mailq
setgid_group = postdrop
html_directory = /usr/share/doc/postfix-2.2.5/html
manpage_directory = /usr/share/man
sample_directory = /etc/postfix
readme_directory = /usr/share/doc/postfix-2.2.5/readme
home_mailbox = .maildir/
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
broken_sasl_auth_clients = yes
smtpd_sasl_local_domain =
smtpd_recipient_restrictions =
        permit_sasl_authenticated,
        permit_mynetworks,
        reject_unauth_destination
smtp_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_use_tls = yes
#smtpd_tls_auth_only = yes
smtpd_tls_key_file = /etc/postfix/newreq.pem
smtpd_tls_cert_file = /etc/postfix/newcert.pem
smtpd_tls_CAfile = /etc/postfix/cacert.pem
smtpd_tls_loglevel = 3
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
alias_maps = mysql:/etc/postfix/mysql-aliases.cf
relocated_maps = mysql:/etc/postfix/mysql-relocated.cf
local_transport = local
local_recipient_maps = $alias_maps $virtual_mailbox_maps unix:passwd.byname
virtual_transport = virtual
virtual_mailbox_domains = <domein>
                virtual_minimum_uid = 1000
                virtual_gid_maps = static:1001
                virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual-maps.cf
                virtual_alias_maps = mysql:/etc/postfix/mysql-virtual.cf
                virtual_uid_maps = static:1001
                virtual_mailbox_base = /
                #virtual_mailbox_limit =
ik werk dus met een mysql DB op de achtergrond, ik kan daar ook prima mee connecten vanuit de CLI.
Echter weigert de setup goed te starten:
Jun 13 15:00:17 krab postfix/pickup[25107]: B85B713F621: uid=0 from=<root>
Jun 13 15:00:17 krab postfix/trivial-rewrite[25115]: fatal: match_list_parse: read file /home/vmail: Is a directory
Jun 13 15:00:18 krab postfix/master[25106]: warning: process /usr/lib/postfix/trivial-rewrite pid 25115 exit status 1
Jun 13 15:00:18 krab postfix/master[25106]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Zowel inbound als outbound doet de setup helemaal niets :(
Het lijkt te liggen aan:
Dit is het beginpad voor de maildirs , voorzover ik het in de documentatie kan zien. Echter worden in de DB de paden gewoon absoluut aangegeven door mij :
/home/vmail/<domein>/<user>/.maildir/
Dat idee dus.
Maar goed, na een paar nachten googlen ben ik er niet uit waarom hij dit afwijst... ook /home/vmail gebruiken werkt niet :(
Dit zijn btw de rechten:
drwxr-xr-x 10 vmail       vmail 4096 May 28 17:08 vmail
uit /home dus.
Heeft iemand een idee?
ik heb ondertussen de tijd op die box ook maar goed gezet :+
[ Voor 3% gewijzigd door Boudewijn op 13-06-2006 13:03 ]
  • Boudewijn
Boudewijn
omdat het kan
ik schop hem eens een keer ... ben er nog steeds niet uit, en het is >30 uur later.
@modje: zou je even s/posfix/postfix in de titel willen doen? Thanks
[ Voor 33% gewijzigd door Boudewijn op 14-06-2006 21:20 ]
