[Qube3] Rackstar
  • sariel
  • Laatst online: 22-09 15:35
Ik heb Rackstar 1.0 op m'n qube 3 geinstalleerd (k6-450, 512mb mem, 40ghd). Dit ging allemaal prima, installatie ging als een zonnetje.
Echter, nu ik m'n qube probeer te booten, gaat het wat lastiger. Ik kom niet verder dan "Booting..." op m'n LCD schermpje, en de volgende tekst op de serial console:
First stage kernel: Decompressing - done
Second stage kernel: Decompressing - done
Linux version 2.2.16C28 (konkers@unicron.cobalt.com) (gcc version egcs-2.91.66 1
9990314/Linux (egcs-1.1.2 release)) #4 (ROM kernel) Mon Jun 18 22:49:24 PDT 2001
Ignoring bogus EBDA pointer 3FFF000
Detected 298807 kHz processor.
Pending 0x00
Calibrating delay loop... 596.38 BogoMIPS
Memory: 517012k/524288k available (1344k kernel code, 416k reserved, 5440k data,
 76k init)
Dentry hash table entries: 65536 (order 7, 512k)
Buffer cache hash table entries: 524288 (order 9, 2048k)
Page cache hash table entries: 131072 (order 7, 512k)
VFS: Diskquotas version dquot_6.4.0 initialized
CPU: L1 I Cache: 32K  L1 D Cache: 32K
CPU: AMD AMD-K6(tm) 3D processor stepping 0c
Checking 386/387 coupling... OK, FPU using exception 16 error reporting.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.35a (19990819) Richard Gooch (rgooch@atnf.csiro.au)
PCI: Using configuration type 1
PCI: Probing PCI hardware
Linux NET4.0 for Linux 2.2
Based upon Swansea University Computer Society NET3.039
NET4: Unix domain sockets 1.0 for Linux NET4.0.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
TCP: Hash tables configured (ehash 524288 bhash 65536)
IPv4 over IPv4 tunneling driver
early initialization of device tunl0 is deferred
GRE over IPv4 tunneling driver
early initialization of device gre0 is deferred
NET4: AppleTalk 0.18 for Linux NET4.0
Initializing RT netlink socket
Starting kswapd v 1.5
Cobalt I2C bus initialized
Cobalt temperature sensor v1.3 enabled
Serial driver version 4.27 with no serial options enabled
keyboard: Timeout - AT keyboard not present?
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
pty: 256 Unix98 ptys configured
Real Time Clock Driver v1.09
lcd: Cobalt LCD Driver v3.12
serialnumber: Version 1.9 initialized. Serial number=bf000007c5fe7401.
Copyright (c)1994-2000 Axent Technologies, Inc.
RAM disk driver initialized:  16 RAM disks of 4096K size
loop: registered device at major 7
Uniform Multi-Platform E-IDE driver Revision: 6.30
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ALI15X3: IDE controller on PCI bus 00 dev 78
ALI15X3: chipset revision 193
ALI15X3: 100% native mode on irq 14
    ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
    ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
hda: Maxtor 6E040L0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: Maxtor 6E040L0, 39205MB w/2048kB Cache, CHS=79656/16/63, UDMA(33)
md driver 0.90.0 MAX_MD_DEVS=256, MAX_REAL=12
translucent personality registered
linear personality registered
raid0 personality registered
raid1 personality registered
raid5 personality registered
raid5: measuring checksumming speed
raid5: MMX detected, trying high-speed MMX checksum routines
   pII_mmx   :   758.571 MB/sec
   p5_mmx    :   701.040 MB/sec
   8regs     :   321.564 MB/sec
   32regs    :   199.263 MB/sec
using fastest function: pII_mmx (758.571 MB/sec)
sym53c8xx: at PCI bus 0, device 14, function 0
sym53c8xx: 53c875 detected
sym53c875-0: rev 0x4 on pci bus 0 device 14 function 0 irq 12
sym53c875-0: ID 7, Fast-20, Parity Checking
scsi0 : sym53c8xx-1.7.3a-20010304
scsi : 1 host.
scsi : detected total.
PPP: version 2.3.7 (demand dialling)
TCP compression code copyright 1989 Regents of the University of California
PPP line discipline registered.
eth0: National Semiconductor MacPhyter (dp83815)
eth0:   bus=0 func=128 io=0x6200 irq=11 ver=3.2
eth0:   ethernet addr=00:10:e0:04:7d:5e
eth1: National Semiconductor MacPhyter (dp83815)
eth1:   bus=0 func=144 io=0x6300 irq=10 ver=3.2
eth1:   ethernet addr=00:10:e0:04:7d:61
md.c: sizeof(mdp_super_t) = 4096
Partition check:
 hda: [PTBL] [1027/255/63] hda1 hda2 hda3 hda4 < hda5 hda6 >
autodetecting RAID arrays
autorun ...
... autorun DONE.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 76k freed
Warning: unable to open an initial console.
De qube is geflashed met de laatste qube3 rom, en zou prima moeten werken......dacht ik.....
Copy.com
  • sariel
De kernel die geladen wordt is blijkbaar 2.2.16, terwijl er 2.6.15 op de disk staat. Hoe kan ik er voor zorgen dat ie die van disk laadt, in plaats die van rom? Ik heb al "bfd" gekozen ipv "bfr"
Copy.com
  • sariel
Iemand?
Copy.com
  • sariel
Verdacht stil.....
Copy.com
  • zomertje
  • Laatst online: 17-02 12:22
zomertje
Barisax knorretje
Het is niet de bedoeling je topic te kicken binnen 24 uur. Je zal even geduld moeten hebben of er hier iemand is die er ervaring mee heeft. En verder zou ik ook even Google raadplegen, een beetje eigen inzet verwachten we wel :)
het ultieme jaargetijde.... | #!/usr/bin/girl | Art prints and fun
  • sariel
Het is toch binnen 1 uur? Maar goed, ja, ik heb gekeken op het net, maar er is niet al te veel te vinden over rackstar, zeker wat betreft root ww, en foutief booten van verkeerder kernels...zijn wel een aantal mensen die hetzelfde opgemerkt hebben, maar niet die het opgelost hebben.
Copy.com
Heb je de instructies op de site wel goed opgevolgd?
En welke ROM heb je? Anders adviseer ik je de ROM te laten upgraden ... (CLICK HIER
Probeer ook dit eens in je hyperterm.
Reboot, op een gegeven moment staat er iets van "druk op spatie" (na 5 sec ongeveer).
[SPATIE]
boot
set_boot_dev hda1
set_root_dev hda1
set_boot_type disk
bfd
  • sariel
         Cobalt Networks, Inc. - Connecting the Dots
                  Firmware version 2.3.40
Current date: Jun 08 18:17:22 UTC 2006
ROM build info: Tue Jun 19 01:18:56 PDT 2001 unicron.cobalt.com
System serial number: invalid csum!
Memory found: 512 MB
Initializing I2C bus: done
Scanning PCI bus: done
Initializing IDE: waiting to spinup second channel...done
  IDE 0 master: found
Initializing SCSI: done
Initializing ethernet: 2 ethernet controllers installed - done
  National Semiconductor DP83815 Found at port 0x6200, MAC: 00:10:e0:04:7d:5e
  National Semiconductor DP83815 Found at port 0x6300, MAC: 00:10:e0:04:7d:61
Initializing flash: done
  Flash bank 0: AMD AM29F080B 1MB (1:d5)
  Flash bank 1: not installed.
Initializing USB: done
Mounting rom_fs: done
Initializing i18n - language "en": done
Press spacebar to enter ROM mode
Cobalt:Main Menu> boot
Cobalt:Boot Menu> set_boot_dev hda1
Cobalt:Boot Menu> set_root_dev hda1
Invalid command
Cobalt:Boot Menu> set_boot_type disk
Cobalt:Boot Menu> bfd
Linux version 2.2.16C28 (konkers@unicron.cobalt.com) (gcc version egcs-2.91.66 1 9990314/Linux (egcs-1.1.2 release)) #4 (ROM kernel) Mon Jun 18 22:49:24 PDT 2001
Detected 298812 kHz processor.
Pending 0x00
Memory: 517012k/524288k available (1344k kernel code, 416k reserved, 5440k data, 76k init)
Zoals te zien is, is het een 2.3.40 ROM versie, de laatste die ik kon vinden.
Ik heb geprobeerd wat je suggereerde, maar set_root_dev lijkt niet te werken.....
dit ook nog geprobeerd:
Cobalt:Boot Menu> set_params root=/dev/hda1
Cobalt:Boot Menu> read_boot_dev
hda1
Detected 298813 kHz processor.
Pending 0x00
steeds weer wil ie alleen maar met de ROM kernel booten :(
Copy.com
  • Jesse
  • Laatst online: 16-10 15:41
Versie is te oud.
Be advised: Wij hebben een speciale ROM versie gemaakt hiervoor...
  • CopyCatz
  • Laatst online: 22:22
Ik heb 'm werkend op de Qube 3. Je hebt een recentere rom nodig die een 2.6 kernel kan booten. Uitleg vind je hier: http://gentoo.404ster.com/texts.php?action=view&id=5. Met het 2.10.3 rom lukt booten wel, alleen zorgen dat je 't juiste device kiest in het lcd menu (single drive of raid). Ik heb wel vaak problemen met een reboot vanuit rackstar, dan wil ie nog wel eens hangen, en een shutdown vanuit het menu werkt sowieso niet = altijd reboot. Dat zal wel aan de qube 3 hardware liggen. Maar over het algemeen ben ik zeer tevreden met rackstar op m'n qube 3.
[ Voor 9% gewijzigd door CopyCatz op 09-06-2006 00:41 ]
Klopt.
1 notitie.
Fout flashen (en het gebeurt toch nog veel te veel) is onherroepelijk de dood aan je RAQ/Qube. Compleet onbruikbaar. ROM moet vervangen worden. Dit is zelf amper te doen, tenzij je professioneel (lees ZEER professioneel) soldeerder bent... Het is zo miniscuul klein, dat lukt bijna niemand. Dat wordt dus opsturen naar een reparateur in de USA, etc etc... duur duur duur...
Maar ja, zoals met alles: Wil je geen centjes uitgeven moet je het zelf doen en risico's aanvaarden. Wil je de gemakkelijke weg kiezen en de verantwoordelijkheid (en aansprakelijkheid) verschuiven, kost het geld...
  • sariel
Tsja, inderdaad, het is duur als het opgestuurd moet worden naar de VS, om een nieuw chippie in te zetten. Maar voor een personal servertje, die niet 100% van de tijd aan staat, en druk bezig is, is de prijs mij iets te hoog van de upgrade van racktweak....als ik een bedrijf was, zou ik er niet eens over nagedacht hebben, en meteen die 125$ gelapt hebben....
ik neem dus maar het risico, en probeer de flash maar....
ik wist trouwens niet dat de 2.10 rom ook voor qubes te gebruiken was, want ik dacht dat het alleen voor raqs en zo was.....
Copy.com
  • sariel
En ik zie dat er een flink aantal ROMmetjes zijn. Welke is er te gebruiken voor een qube? de 1m of 2m versie? in welk opzicht is de SE versie anders dan de andere 2, die een filesystem-typering hebben?
Copy.com
  • Zwerver
sariel schreef op vrijdag 09 juni 2006 @ 14:50:
Gebruik nou eens de editknop want je kickt nu alweer binnen 24 uur....
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • CopyCatz
Kan me niet meer herinneren welke ik geflasht heb, maar de 2mb's, de -flat's en se's vallen af. Het was dus volgens mij de cobalt-2.10.3-ext3-1M.rom . Ext3 support is nodig voor rackstar, en de rom size moet 1MB zijn.
Als je de aanwijzingen volgt (zeker doen) zul je zien dat de backup die je eerst maakt ook dezelfde grootte heeft. Net zolang flashen tot er geen errors zichtbaar zijn, dan pas rebooten. Ging bij mij de eerste keer gewoon goed overigens.
[ Voor 6% gewijzigd door CopyCatz op 09-06-2006 20:44 ]
Je informatie klopt deels. Maar ook bij geen errors (weergegeven) kan je ROM verkloot zijn... Een gewaarschuwd mens.....
Gebruik je trouwens de verkeerde kun je nog wel eens een probleem hebben met software draaiende te krijgen, en kun je dus ook niet opnieuw flashen...
[ Voor 39% gewijzigd door Verwijderd op 10-06-2006 00:25 ]
  • sariel
Ok, ik zal de ext3 rom proberen.
raqtweak: ja, ik ben bekend met de risico's, en ben bereid die te nemen. op het ogenblik is het zo dat het ding of gaat werken met een nieuwe rom, of de vuilnisbak in gaat :'(.
Op het ogenblik staat ie toch uit, en doe ik er niets mee. Ik zou het ding heel graag willen gebruiken, maar als het niet mogelijk is (door een erg creatieve boot oplossing van cobalt), dan is het heel jammer, maar dan gaat ie er uit. Ik ga geen antieke linux draaien: er zijn al meer dan genoeg hack-paradijsjes op de wereld, een extra is niet nodig.
Copy.com
