GCC opeens verdwenen?
  • ufear
  • Laatst online: 19-10 14:33
Dit is het raarste wat ik tot nu toe in mijn overigens niet zeer lange linux-carriere heb meegemaakt. Ik dacht vanavond laat ik eens sBNC instaleren, die kan gebruiken maken van TCL scripts dus handig als dat geinstalleerd is. Systeem draait overigens Fedora Core 5 SMP.
[root@p2p-hosting lib]# uname --all
Linux p2p-hosting 2.6.15-1.2054_FC5smp #1 SMP Tue Mar 14 16:05:46 EST 2006 i686 i686 i386 GNU/Linux
Komt het dan
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
bash-3.1$ yum install tcl
Loading "installonlyn" plugin
You need to be root to perform this command.
bash-3.1$ exit
exit
[root@p2p-hosting home]# yum install tcl
Setting up Install Process
Setting up repositories
core        [1/3]
core                      100% |=========================| 1.1 kB    00:00
extras                                                               [2/3]
extras                    100% |=========================| 1.1 kB    00:00
updates                                                              [3/3]
updates                   100% |=========================|  951 B    00:00
Reading repository metadata in from local files
primary.xml.gz            100% |=========================| 1.1 MB    00:04
extras    : ################################################## 3269/3269
Added 139 new packages, deleted 74 old in 4.89 seconds
primary.xml.gz            100% |=========================| 325 kB    00:00
updates   : ################################################## 985/985
Added 40 new packages, deleted 22 old in 1.43 seconds
Parsing package install arguments
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for tcl to pack into transaction set.
tcl-8.4.12-4.i386.rpm     100% |=========================|  28 kB    00:00
---> Package tcl.i386 0:8.4.12-4 set to be updated
--> Running transaction check
Dependencies Resolved
 Package                 Arch       Version          Repository        Size
Installing:
 tcl                     i386       8.4.12-4         core              954 k
Transaction Summary
Install      1 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 954 k
Is this ok [y/N]: y
Downloading Packages:
(1/1): tcl-8.4.12-4.i386. 100% |=========================| 954 kB    00:22
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
  Installing: tcl                          ######################### [1/1]
/sbin/ldconfig: /lib/libstdc++.so.5 is not a symbolic link
Installed: tcl.i386 0:8.4.12-4
Complete!
So far so good eh?
[root@p2p-hosting home]# su cyber
bash-3.1$ ./configure
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking for C++ compiler default output file name... configure: error: C++ compiler cannot create executables
See `config.log' for more details.
Waar is mn GCC? :/
bash-3.1$ exit
exit
[root@p2p-hosting home]# yum install gcc
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   /lib/libgcc_s.so.1: version `GCC_3.3.1' not found (required by /usr/lib/librpmio-4.4.so)
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.4.2 (#1, Feb 12 2006, 03:59:46)
[GCC 4.1.0 20060210 (Red Hat 4.1.0-0.24)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://wiki.linux.duke.edu/YumFaq
Okay, wat is dit dan allemaal? yum opeens kapot na install van TCL? Enige error die ik kon vinden bij yum was de volgende.
Nouja, als jij een symlink wil maken wij die toch.
[root@p2p-hosting lib]# ldconfig
[root@p2p-hosting lib]# mv libstdc++.so.5 libstdc++.so.5.bak
[root@p2p-hosting lib]# ln -s libstdc++.so
libstdc++.so        libstdc++.so.5.0.3  libstdc++.so.5.bak
[root@p2p-hosting lib]# ln -s libstdc++.so.5.0.3 libstdc++.so.5
[root@p2p-hosting lib]# rpm
rpm: /lib/libgcc_s.so.1: version `GCC_3.3.1' not found (required by /usr/lib/librpmio-4.4.so)
rpm: /lib/libgcc_s.so.1: version `GCC_3.3' not found (required by /usr/lib/libstdc++.so.6)
rpm: /lib/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /usr/lib/libstdc++.so.6)
En nu heb ik geen idee waar ik dit verder nog moet gaan zoeken, blijkbaar is mn /lib/libgcc_s.so.1 kapot, al een andere versie uit /root/tmp/libgcc_so.so.1 geprobeerd, maar dat wou ook niet. Iemand enig idee?
  • Boudewijn
Boudewijn
omdat het kan
binaire tarball van gcc installeren?
(en daarna de zaak fixen natuurlijk, maar je hebt dan iig een compiler)
niet goed gelezen was dus onzin post
[ Voor 80% gewijzigd door Verwijderd op 21-05-2006 22:48 ]
  • Confusion
  • Laatst online: 01-07 21:46
Confusion
Fallen from grace
ufear schreef op zaterdag 20 mei 2006 @ 23:58:
Waarschijnlijk daarvoor ook al, alleen is dit de eerste keer dat je het merkt?
Wie trösten wir uns, die Mörder aller Mörder?
