FILE_IN_NON_PAGED_AREA-probleem
  • 30 views sinds 30-01-2008
Ik heb een heel raar probleem. Normaal loopt mijn pc helemaal toppie, maar als ik een dingetje fout doe [maakt niet uit hoe of wat] dan krijg ik een FILE_IN_NON_PAGED_AREA bsod!
Ik weet niet of men hier iets aan heeft, maar ik post het er ff bij.
Microsoft (R) Windows Debugger Version 6.6.0003.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini051606-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d4000 PsLoadedModuleList = 0x8054a230
Debug session time: Tue May 16 23:43:51.140 2006 (GMT+2)
System Uptime: 0 days 3:46:41.937
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {aedb0dfe, 0, 805178c0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Probably caused by : ntoskrnl.exe ( nt+438c0 )
Followup: MachineOwner
Beschadigde kernel, fout ram-geheugen [2 weken geleden gekocht :S] foute voeding,
wat kan het zijn?! Werkt normaal foutloos : :?
WIE KENT DIT PROBLEEM?!? IK RAAK ER HELEMAAL GESTRESST VAN :(
Specs: P4 3.0 ghz
160 gb HD Seagate
1024 mb Kingston [2x512 MB]
MS7042 mobo
  • Thandor
  • Laatst online: 17:36
Thandor
SilverStreak
Wie, wat, waar is 'fout' ?
Wees zo precies mogelijk over 'wanner het fout gaat'. ;)
Wat heb je hier aan getest ?
Probeer eens één DIMM (zowel beide los testen)
Loop ook de Hangen en Opstartproblemen troubleshooter eens door. Daar staat veel in. Zo ook over de voeding. Bekijk of de voeding nog in orde is a.d.v. de voltages. (Overigens, welke voeding?)
Andere tip is : Haal de overbodige hardware uit het systeem. Mocht het systeem kaal wel draaien dan is het slechts een kwestie van één voor één de hardware terugplaatsen totdat het probleem zich weer voordoet.
Naast bovenstaande neem ik aan dat je het systeem reeds een herinstallatie hebt gegeven en zowel nieuwere als oudere drivers hebt geprobeerd ? Immers kan het ook aan de software liggen :)
[ Voor 3% gewijzigd door Thandor op 17-05-2006 00:21 ]
  • dion_b
  • Laatst online: 13:16
dion_b
say Baah
Hangen en Opstartproblemen troubleshooter idd.
Zie ook PMG Beleid:
Indien je een topic opent omdat bovenstaande stappen je geen soelaas hebben kunnen bieden, dien je compleet te zijn!
Geef een exacte omschrijving van het probleem, compleet met de eventuele foutmeldingen, en wanneer het zich voor doet.
Geef de geschiedenis van het probleem aan (was het altijd al zo of is het iets van de laatste tijd en zo ja, welke eventuele veranderingen hebben zich voorgedaan voorafgaand aan de eerste maal dat het probleem optrad?).
Geef een exacte omschrijving van de hardware (mobo, CPU, koeler, geheugen, opschrift geheugenchips indien geheugengerelateerd, voeding, videokaart, geluid/netwerkkaart, etc.), noem wel de officiële merknamen en type-aanduidingen en geef beslist géén ellenlange uitdraai van een of ander diagnoseprogramma, zoals Sisoft Sandra.
Geef duidelijk aan welke software (OS, drivers) je gebruikt.
Geef aan welke BIOS instellingen je gebruikt (met name als het een geheugengerelateerd probleem is).
Vergeet vooral niet te vermelden wat je allemaal al hebt getroubleshoot met de Hangen en opstartproblemen troubleshooter en wat de resultaten ervan zijn.
En niet onbelangrijk: vat het probleem samen in een zo duidelijk mogelijk topictitel. Dus niet "pc probleem", maar bijvoorbeeld "Asus P4P800 Deluxe crasht met BAD_POOL_CALLER".
Oslik, blyat! Oslik!
