[XML & JS] in Firefox doet ie het niet
XML:
<?xml version="1.0"?>
<news>
    <item>
        <id>1</id>
        <date>Datum1</date>
        <title>Titel1</title>
        <msg>Msg1</msg>
    </item>
    <item>
        <id>2</id>
        <date>Datum2</date>
        <title>Titel2</title>
        <msg>Msg2</msg>
    </item>
    <item>
        <id>3</id>
        <date>Datum3</date>
        <title>Titel3</title>
        <msg>Msg3</msg>
    </item>
</news>
[code=js]
function importNews(xmlFile)
if (document.implementation && document.implementation.createDocument)
xmlDoc = document.implementation.createDocument("", "", null);
xmlDoc.onload = createNewsTable;
else if (window.ActiveXObject)
xmlDoc = new ActiveXObject("Microsoft.XMLDOM");
xmlDoc.onreadystatechange = function () {
if (xmlDoc.readyState == 4) createNewsTable()
else
alert('Uw browser ondersteunt geen XML');
return;
xmlDoc.load(xmlFile);
function createNewsTable()
var x = xmlDoc.getElementsByTagName('item');
for (i=0;i<x.length;i++)
var datum = x[i].childNodes[1].firstChild.nodeValue +": ";
var titel = x[i].childNodes[2].firstChild.nodeValue;
var bericht = x.childNodes[3].firstChild.nodeValue;
var table = document.createElement('TABLE');
table.setAttribute('class','tblXMLNews');
var tbody = document.createElement('TBODY');
table.appendChild(tbody);
var tr1 = document.createElement('TR');
var tdDatum = document.createElement('TD');
tdDatum.appendChild(document.createTextNode(datum+""+titel));
tdDatum.setAttribute('id','tdXMLNewsDatum');
tr1.appendChild(tdDatum);
var tr2 = document.createElement('TR');
var tdBericht = document.createElement('TD');
tdBericht.appendChild(document.createTextNode(bericht));
tdBericht.setAttribute('colspan','2');
tr2.appendChild(tdBericht);
tbody.appendChild(tr1);
tbody.appendChild(tr2);
document.getElementById('divXMLNews').appendChild(table);
HTML:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    <title>Project Ieper</title>
    <link type="text/css" rel="stylesheet" href="opmaak.css" />
    <script type="text/javascript" src="functions.js"></script>
</head>
<body id="pgXmlNews" onload="importNews('news.xml');">
    <div class="divPgTitel">NIEUWSBERICHTEN:</div>
    <div id="divXMLNews"></div>
</body>
</html>
Dit werkt perfect in IE, niet in FF. Wat doe ik verkeerd?
Ook krijg ik soms de melding "[element] 'has no properties' " Wat is hiervan de oorzaak?
Alvast bedankt voor de hulp!
[ Voor 73% gewijzigd door Verwijderd op 20-04-2006 17:31 ]
  • BtM909
BtM909
Watch out Guys...
En toen je begon te debuggen in Firefox welke errors zag je verschijnen? :)
Overigens is het makkelijk om je code tussen bijbehorende code blokken te zetten:
[code=xml][/]
[code=js][/]
[code=html][/]
Verkregen errors in FF:
  1. x[i].childNodes[2].firstChild has no properties
  2. td.firstChild.style has no properties
  3. td.firstChild.style has no properties (6 regels verder)
Ik vermoed dat dit te maken heeft met de verschillen in whitespace-afhandeling tussen IE en FF. Verwijder eens alle whitespace uit je XML document en probeer het nog eens.
En toen zag hij dat het goed was....
Mijn xml structuur is nu wel om zeep, maar het werkt!
Thx !
  • BtM909
BtM909
Watch out Guys...
Of je zoekt even door en vind andere oplossingen om whitespaces te negeren en door te gaan ;)
  • crisp
  • Laatst online: 08:21
crisp
Devver
Pixelated
Deze hoort daarom ook in je bookmarks te staan: http://developer.mozilla.org/en/docs/Whitespace_in_the_DOM ;)
Intentionally left blank
